Question about Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher
Bosh dishwasher dishwasher will not empty last couple of times the control was noisy now it will not empty do you think itsthe pump?
  • brunohagstro Dec 16, 2008
    Product: SHY 3306 UC. will not empty. Filters are clean. Could it be the pump? If so can I fix it myself?
DISHWASHER ONLY RUNS 2 HOUR CYCLE?
Posted on Mar 15, 2009
  • 22 Answers
Most probally
Posted on Nov 13, 2008
My bosh dishwasher beeped,showed a code of "24" said "watertap" and stopped working. What does that mean and what do I do now?
I would normally say it sounds like a water supply issue (solenoid etc), but have heard elsewhere that the issue is possibly linked to drainage. Does your Machine drain? Try emptying it out and refilling with hot water straight into the wash tank sump. Leave for a few minutes then run through a drain. After a few times this should clear any grease build up. If not draining at all after this then look for a solid blockage in the drain pipework or pump?
Nov 02, 2017 | Dishwashers
My Bosch does not wash well
Clean Your Dishwasher with Tang (yep - the citrus drink)
  1. Empty the dishwasher.
  2. Run the water in the kitchen faucet until it is hot. (He suggests you do that before running your dishwasher every time.)
  3. Turn the tap off and start the empty dishwasher.
  4. After two or three minutes, stop the dishwasher and add a container of Tang.
  5. Let it run the whole cycle.
Jan 01, 2014 | 1993 Mazda RX-7 Brake Pad Set Bosch
Bosh SHY56A Dishwasher - Loud Pop and Smoke While
Hey Matt,
Dishwashers are not that complicated.. Turn off the breaker, pull the machine out - away from the wall..(there will/should be at lest two screws in the top edge holding it to the counter.. remove them first.. then pull it out until you can turn off the water supply.. When you are able to completely remove the washer, you should be able (possibly)to see what happened.. Check to see if the washer arm (inside the washer) will turn, if not.. replace the motor.., check to see if the pump belt will turn?.. it could be the pump drive motor or the pump its self..(remove the belt), then see if the motor will turn, check to see if the pump will turn.
.. White smoke makes me think that the belt was turning and the pump NOT turning..that will cause the belt to smoke.. and smell like burning rubber..If the pump will not turn. you have found t he problem... Also ..Check to make sure there is not a knife or some other object lodged in the drain or pump
NOW -- With all this.. Sometimes REPLACING the machine is actually cheaper than repairing the old one!!! Your wife deserves a NEW one!!
Jun 28, 2017 | Dishwashers
Dishwasher very noisy as it goes through it cycle. think its the water pump? sounds like bearings or impeller rubbing off the housing? not as noisy when the machine is cycling empty?
Could be bearings or something caught inside the impellar. If you take the wash arms off and run a cycle with water, it will "sometimes" blow out anything in the impellar. Undercounter machines are usually problematic - recommend avoiding them when possible.
Apr 22, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Doesn't pump out. Pump is very noisy.
these units have a either rubber or brass water pump impeller. empty machine and turn upside down. follow hose until you discover where the pump is and take it apart. you can then get pump part at any small appliance store.
Oct 30, 2009 | Viking 24 in. Professional Series VUD141...
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
Bosch dishwasher growling and not draining
Bosh dishwashers work off a gravity pump system. They sometimes require a stronger pump. Make sure if it has a air gap either at the top of the sink or johnston T or in the wall that, that is not plugged. They are very sensitive to how the drainelines are set as well. If it was installed prfessionally, call the installer back out as they should warranty there install for 1 year. Also all products have a 1 year MF warranty as well. You should be able to get a BOSH tech out at NO charge to see if it is a deffective pump.
May 04, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dishwasher Class1xx
I think if u take the left side pannel off u will find the meatering tank clogged up which can not fill up the machine at diffrent levels.
Jan 02, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
333 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
