Question about Tascam DP01FX All-In-One Recording Package Microphone
Bit Rate After recording and mastering a track I wanted to transfer it to my computer. I followed the instructions to get it on my computer but when I came to look at it the bit rate was 1411 kbps. I did the same with another song and the bit rate was the same. How do I reduce the bit rate as a 3 minute song takes up just over 30 MB of space.
  • 1,031 Answers
CD media We speak about AudioCD, not about MP3 collections: these are two absolutely different things. Audio CDs offer reference sound quality, because they capture everything without any clipping or compression. What concerns MP3 collections, they are just compressed CD tracks recorded on a CD. Music in AudioCD format has strict technical parameters, which cannot be changed. That's why it's possible to calculate the total length of a disc - 74 or 80 minutes (an album may be shorter, of course). You can copy music from a CD to your computer, but it's not very easy. In order to save your music to a hard drive, CD tracks should be encoded into any audio format. You can do it with various programs - for example, Windows Media Player, which can be found in most computers. The audio quality will depend on encoding options. The higher audio quality, the larger your audio files will be. However, this is already the next point :) Uncompressed media Digital data from a CD can be read 1:1 and recorded as a WAV PCM file. As no details are lost, this operation is fully reversible - you can record a CD from your files. It will be almost the same or absolutely identical (if you didn't break tracks into files) as the original CD. The advantage of this format is that it's lossless. However, from the point of view of portable devices, such files are too big: one minute of music in this format requires over 10 MB of disc space. Besides, WAV support is not available in all players: HDD players tend to support this format, while flash players usually don't. Lossy compression There exist methods to compress music, when some audio data are lost. For example, MP3, WMA, OGG, AAC, etc. It's these formats that are supported by all modern players. But this support is limited. For example, any player supports MP3. WMA is supported by 3/4 of the modern devices. However, only 30-40% of modern players support OGG and AAC. Lossless compression An encoding program can compress original audio from a CD several times. However, the file size is relatively big - a usual CD can be compressed twofold. However, original audio is not clipped. While lossy formats just sound like the original audio CD, lossless formats provide original sound, which is compressed to take less storage space. There are several lossless codecs and formats. The most popular is the format used by Apple - it's supported in all iPods but shuffle. You may also come across such formats as FLAC and APE. These formats are especially promising from the point of view of their top audio quality - they are no worse than WAV PCM, but they take up 50% less storage space and they support tags (we'll touch upon them below). Regardless of a format, music files differ by compression quality. The main parameters here are bit rate and sampling rate. Bit rates vary much in music files. The higher the bit rate (all other things being equal), the higher the audio quality. The highest audio quality is provided by bit rates starting from 128 Kbps and higher. Lower bit rates are used only when audio quality is not critical, for example for voice recording. Besides, it's agreed that 320 Kbps hardly differs from the original audio track. However, it's a subjective factor, which depends on a given person, ear for music, and sensitivity. By the way, the bit rate of audio CDs is 1411 Kbps. As we can see, there is a great difference between compressed and uncompressed audio. Audio file size grows proportionally to its bit rate. The lower the bit rate, the smaller the audio file, the lower audio quality, and vice versa. Let's describe the notions of bit rate and sampling rate.
Bit rate shows how much data is required to encode one second of an audio file. So, when the bit rate of a file equals 256 Kbps, it means that each second of this audio file takes 256 Kbit of memory. So you can calculate the size of a music file, if you know its length and bit rate. Another definition of this term is a bitstream. It's often used to describe audio microcontrollers. It's easier to understand this term from the point of view of interface throughput: how much bits are processed (go through a given interface) per second. It's impossible to say which bit rate to use to encode audio - it's a subjective matter. One user will be always satisfied with 128 Kbps, the other will grumble about 320 Kbps.
Sampling rate—it resembles video resolution: the higher it is, the more details you will see. What concerns sampling rate, the higher it is, the more distinctly a file sounds. So the higher the better. The optimal quality is usually provided by the sampling rate of 44100 Hz (it's often called 44 kHz). This value is not chosen at random - according to the sampling theorem, a sampling rate of a signal must be at least twice as high as the rate of the source signal (if you know physics well, don't write angry emails to us, we simplified it deliberately ;)). As a human ear distinguishes sounds from 20-30 Hz to 20-22 kHz, we should use 40-44 kHz for digital audio processing. The standard of professional equipment is 48 kHz - with a little safety margin. But when the AudioCD standard was created, its authors did not want to compete with professional equipment, so the sampling rate was cut down to 44 kHz. Computer formats support even higher values. But as most music tracks are copied from AudioCDs, there is nothing surprising about this value being the widest spread sampling rate.
This theorem gives only a necessity criterion, not a sufficiency criterion. That is, we know for sure that if we don't provide the twice as high sampling rate, the audio quality will definitely be bad... But we don't know whether it will be good, if we do. And we don't know the exact sampling rate to ensure good audio quality :) That's why the 48 kHz sampling rate is used in DVDs and professional audio equipment, and HD audio (for example, SACD or DVD Audio) supports sampling rates of 96 kHz or even 192 kHz, because even 48 kHz may be insufficient. However, there is no need to support these excesses in portable players :)
What does it all mean in practice? Here is a ballpark statistics for a 4.5 minute audio file. We'll show you how many files your player can store depending on the quality of these files and capacity of the player:
Quality and size of an audio file/ player capacity 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 128 Kbps - 4.3 MB 120 240 475 950 1900 3800 192 Kbps - 6.48 MB 80 160 315 630 1260 2520 256 Kbps - 8.64 MB 60 120 235 470 940 1880 320 Kbps - 10.8 MB 45 95 190 380 760 1520 The speed at which a player can save data into its memory is not a key factor, but it's still important. The higher the speed, the faster you can copy files to memory. The usual speed is 2-5.5 MB/s for flash players and up to 15-20 MB/s for HDD players.
Prices for flash memory are constantly decreasing now. When you choose between identical players with different memory capacities, you should keep in mind that twice as much flash memory does not mean twice as expensive player, because the player itself also costs some money. So you should make up your mind whether to pay a little more for double memory capacity or save it.
8 bits = 1 byte
1,024 bytes = 1 Kilobyte (Kb).
1,024 Kb = 1 Megabyte (Mb).
1000 Mb = 1 Gigabyte (Gb).
Modern computers can store anywhere from 5 to 100 Gbs on their hard drives. Why would you need to worry about the file size of your digital audio with so much space available? Well, your computer needs a good chunk of its hard drive to store the operating system (Windows, Linux, etc.) and instructions for running things like your modem, your internet browser, and your email program. So space is often at a premium. You’ll see.
Posted on May 20, 2008
  • Starnley Johnwells
    Starnley Johnwells May 20, 2008
    The time it takes to accomplish this is dependent on how fast your CD-ROM drive can rip the tracks but it rarely takes more than 90 seconds.
    Guru:
  • 1,342 Answers
  • 111 Answers
Obviously the lower the bitrate the lower the quality, so be careful downsampling too far. Most DAT and sampler hardware can sample at 88.2khz and the audio CD sampling rate of 44.1khz. There are many many sofware packages for downsampling...
Steinberg Wavelab = super gui app for windows = $550
Sox = basic command line tool = free
  • 2 more comments
  • Mark Day
    Mark Day May 20, 2008
    Note that downsampling as above only applies if the file is already in some lossless format like .raw/.wav/.riff etc. If the file is in a compressed format already (like mp3/mp4 etc) then converting it to lossless in order to downsample is pointless because the quality will degrade severely.
  • Mark Day
    Since you do mention bitrate and not sample rate then Im assuming its encoded in some compressed format already... MUSICAM(mp2)/mp3/mp4, so why not just master it at a lower bitrate in the first place?
  • Mark Day
    LOL I think he just wanted to know how to downsample his file, not the complete history of digital audio. Great job cutting and pasting btw!
  • Mark Day
    BTW jonniewalker's solution was to simply steal the information presented on:
    http://www.digit-life.com/articles3/mult...
    That mustve taken quite a bit of thought there, jonnie. :P
FTP Connection using Windows 7 64 bit
Individual applications that transfer files using FTP may have their own methods for monitoring transfer speed. But for a single method that works across all applications, consider an external bandwidth monitor. Windows no longer tracks bandwidth usage, but several free third-party tools display your upload and download speed. Close other Internet programs besides your FTP transfer tool, and check the bandwidth monitor to determine your transfer rate.
Net Speed Monitor
If your computer uses the 32-bit version of Windows 7, download Net Speed Monitor 2.5.4.0 for Windows. If your computer instead uses the 64-bit Windows 7 version, download Net Speed Monitor 2.5.4.0 for Windows (msi, x64). (See Link Below.) http://www.floriangilles.com/software/netspeedmonitor/download/ Run the installation program. The license agreement will open. Accept the agreement. Click "Next." Further options will open. Click "Next." Click "Install." A dialog box will ask whether you want your task bar to display the "NetSpeedMonitor toolbar." Click "Yes." Another dialog box will open. Click "Save." Run your FTP transfer. Check the transfer rate from the task bar. Bandwidth Meter b> Download the Bandwidth Meter installation program. (See Link Below.) http://www.bandwidth-meter.net/freedown.htm Run the program. Click "Next" through the options. Choose "Install" when the final step prompts you to. Run your FTP transfer. Check the transfer rate from the task bar. Hope this helps.
b>
Dec 17, 2012 | Esker TUN Plus 11.5 Upgrade Version for PC
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
When i transfer songs from my tascam to my computer or burn to a cd. The audio volume is extremely low. How do I fix this.
There are simple free solutions for editing audio
Try using audacity
When you have it installed simply open your imported tracks, hit ctrl+A to select all the entire track, then pick Effect> Amplify. It will automatically choose a comfortable listening volume, if you still can't hear you may want to tinker with the audio a bit more.
Jul 27, 2011 | Tascam Dp-02cf Digital 8-track Recorder
I made and saved a master of a song, now i want to tweak it a bit but i'm not sure how to get rid of the current master. because it's saved i cannot do another. Help??
play the original song back. not the master, but the original song. tweak all you want and then master it again, the new master will replace the old one automatically.
Mar 11, 2011 | Tascam Dp-02cf Digital 8-track Recorder
If I want to record let's say someone speaking for 90 min and burn 2 cd's , one 60min and the other 30 min from the one 90min recording , each one divided into tracks , how would I do this ?
If you want to burn a CD you have to make a master. For 2 cd's you have to make 2 masters, one for each recording.
The best way to handle this is to "create a song" for each speech giver and give each a name.This is because you can make only one master copy of a song before burning a Cd.
But another way is to :
1. Make a master of the first speech giver (who is on one track) and record to the Cd.
2. Make a new master of the second speech giver (on the other track) and record to Cd.
As long as you don't mind, the second mastering will overwrite the first one that you did, but then you already have burned a copy of that Cd!
Nov 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
How do you delete recorded music from the vp-02? I have searched for a manual with no results.
hi,
please follow the instructions to delete any song or music track from your player.
  • Switch on your PC or laptop and connect the MP3 player via USB port!
  • After your player is recognized, go to My Computer!
  • Double click on the Player's logo (sometimes you notice it as removable disk).
  • Now you can see all the music track available in your player.
  • Click on the track you want to delete. Now right click on the track!
  • In the drop down menu, Click on delete.
  • For deleting multiple songs, while clicking on music tracks that you want to delete, Click on Control (ctrl) button.
This is the easiest way to delete music tracks from your Mp3 player.Have a nice day. If you find some thing difficult to understand, Please write back to me! Please rate my solution as helpful!
Mar 12, 2010 | Virgin Pulse VP-02 MP3 Player
I finished one our ago my first recording i don't understand how to do to for pre mastering, because i want to do ace and evry time i read track too short, set out point... ?? give me how to do.a
Congratulations on your first recording! Mastering and pre-mastering is covered in much more detail in the manual (page 59 in the original 2488 manual) but I'll provide a brief explanation here for you.
First you need to enter pre-mastering mode. Do this by navigating through the menus to the 'audio CD' menu and then choose 'pre-master'. You'll see the word 'Mastering' appear in the LCD screen to indicate you are in mastering mode.
Basically you need to then set the 'out point'. The 'in point' is always 00:00:00.00. So just play your recorded song to the end (or where you want the master to end) and press 'shift' and 'set out' to set the out point there. A master has to be at least 4 seconds long which is whay you are getting that error message.
Next press record and play and the master will be recorded on two internal stereo mastering tracks (left and right). Master recording will automatically stop at the 'out point'. You can redo the master, undo a master, or copy the master tracks to any other two available tracks to preserve a copy and then go ahead and record another master. All effects, mixer settings, and fader movements are recorded as part of your master.
Best of luck.
Hope this helps.
Jun 15, 2009 | Tascam 2488 Portastudio Multitrack...
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
Usb file transfer
In reading and working with the unit, I have learned that the file transfer is for backup only. If you want to manipulate the file they have to be transferred individually via your sound card or an interface.
Jun 21, 2007 | Tascam 2488 Portastudio Multitrack...
421 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
