when i switch ON my camera the message appear on the Screen "Acess" and after few seconds diplays another message " Switch Off and Switch On again" but this doesnt seem to solve the problem. plus at the same time when i switch on the lens zooms in and out auto and does that till i swtch off. please can you help me as to why its behaving so??
The first time this happened I smacked the camera into the palm of my hand and it started right up and worked fine for a year. Yesterday it happened again and no amount of smacking helped. Today, as soon as I turned it on I took a sharp stylus, stuck it into the side of the lens and force levered it out. Now it works! Unfortunately I already bought a new camera.
What you are seeing is a generic stuck lens error message:
Your
lens needs to be cleaned, repaired or replaced. There are online places that will do it for a
decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the
repair! (Google 'darntoothysam')
Just let us know if we can help!
You can also buy a defective camera online and use the parts to fix one from the two yourself.
If your Sony DSC HX1 camera appears to be working, but you can't see anything through the viewfinder or LCD screen, there are a few possible causes for this issue:
1. Display Settings: Check the display settings on your camera. There may be an option to switch between the viewfinder and the LCD screen. Make sure the correct display mode is selected.
2. Viewfinder/LCD Switch: Some cameras have a switch or button that allows you to toggle between the viewfinder and the LCD screen. Ensure that this switch is in the correct position for the display you want to use.
3. Display Brightness: It's possible that the brightness of the viewfinder or LCD screen is set too low, making it difficult to see the image. Check the camera's settings menu for options to adjust the brightness or contrast of the display.
4. Faulty Display: If the above steps don't resolve the issue, it's possible that there is a problem with the camera's viewfinder or LCD screen. This could be due to a loose connection, a damaged cable, or a malfunctioning component. In such cases, it's recommended to have the camera inspected and repaired by a professional technician or the manufacturer's service center.
5. Power Saving Mode: Some cameras have a power-saving feature that turns off the display after a certain period of inactivity. Check the camera's power-saving settings and make sure the display timeout is set to a reasonable duration.
If none of these solutions work, it's best to consult the camera's user manual for specific troubleshooting steps or contact Sony customer support for further assistance. They will be able to provide you with more detailed guidance based on the specific model and issue you're facing.
Appears the backlight for the LCD display has stopped working. This usually needs to be replaced by a professional unless you are electronically and mechanically savy.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!! rate me!!
does this model have the eye viewer also? if so check and make sure the switch is toggled to displayed and not for the eye viewer. look into the eye viewer and you should see your display. it is simple switch to toggle it to the display mode.
Sounds like your camera was dropped and the LCD was damaged. The white screen you see is typical for a defective LCD screen. The only way to repair the camera is to replace the bad part with a known good one.
One solution would be to buy a defective camera online that has a good LCD screen and swap them out.
the problem of your camera is the flexwire cable of the lcd monitor that why you don't see nothing in the panel,Also the message 'cover is not open' appears,while the cover is already opened the switch on cover have poor contact..it is not covered by sony service...it have to replace or repair that switch and flexwire cable....
I have exactly the same problem as described.
When I turn it on it says "access", "please turn camera off and then on again", and when I do that it happens again, over and over.
