Monitor has gone completely black
My monitor one day grew dim and black. The next day it was completely black by best guess is that the backlight has gone out because the display is fine on an external monitor. So am I right? and if so, about how much will it cost me to repair?? Because I really don't want to get another notebook because this one is super fast(3.00 GHz!!!!) but it could use more RAM.
  • 55 Answers
Hi
Normally notebooks last abt 3 years (3.0 GHz is abt 3 years, sorry) and then you will have to upgrade or change. In this case I suggest you get the "monitor" changed to a used one (I think u can find it in ebay) or buy a new one. The approx cost is USD 300.00 depending on the make of your notebook. U could also get it repaired if u can find a technician.
Posted on May 20, 2008
Black display
You say black display. Not sure what you mean. Either the monitor is working or it is not. If you see nothing on the monitor and the power light is yellow, then it is not getting a signal.
If the power light is green and you see nothing, look really closely. You might even shine a flashlight at the monitor to see if there is actually a dim display. If so, the backlight has gone out and needs to be replaced.
I'm assuming that you have tried to brighten the display with the monitor controls.
Jan 09, 2012 | ViewSonic VA720 17" LCD Flat Panel Monitor
Dim backlight
you need to contact the manufacturer and ask to replace the backlight...
May 20, 2010 | Toshiba Satellite 15" Flat Panel LCD...
My philips lcd monitor in side dim please healps model philips 170s
It sounds like the backlight has gone out. Replace the monitor.
Feb 06, 2010 | Philips 170S4FB 17" LCD Monitor
Dell inspiron 1318 lcd screen completely dim
The backlight in your LCD has gone out. You will need to replace the entire LCD. You can look on ebay or here, you will be paying around $300 for it.
Good Luck!
Jesse
Jan 05, 2010 | Dell Inspiron 1318 Laptop Computer PC...
My monitor on my Dell laptop went completely black while I was on it. I have tried turning it off and back on, and the monitor is not working at all
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 26, 2009 | Dell Computers & Internet
My monitor shut off and wont come back on
Do you have a yellow light on it?
Is this a monitor that has a power adapter to run it? If so, check the voltage coming to the monitor. If the voltage is low or there is no power, then you have found the problem.
If the voltage is correct and if you can get video by attaching a different monitor, then your monitor is bad.
Oct 10, 2009 | Gateway FPD1760 17" LCD Monitor
Monitor went dark
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 25, 2009 | Toshiba Satellite A135-S2386 Notebook
Black screen battery charged new ac cord turns on fan is on nothing on screen wont go on to hard disk i guess
Your LCD screen is probably bad.. Can you see anything? It may be very very very dim. If it is very dim(use a flashlite to see if anything comes up), if you can see something but is very very dim then it is the backlight to your LCD screen and you need a new screen
Try connecting your PC to an external monitor.. then try getting it to work..
If it works on an external monitor then it is your LCD screen.
If it fails, then it is your video card or motherboard.
Sep 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Compaq V2000 Display blacks out
sounds like the backlight has gone....test with an external monitor....if the external monitor works without any problems...the backlight has gone...better to get a professional to do this as its kind of fiddly and involves taking the screen apart
Dec 22, 2008 | HP Compaq Presario V2000 Notebook
Half a monitor
This could be a backlight problem- Dont know about a fix though
I guess some one may repair them[new tube[s]]
I guess what ever the labour plus parts will be well on the way to a new one.
How old is it by the way - any warranty left?
Jan 26, 2008 | Hyundai L91A 19" LCD Monitor
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
