The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again."
  • 3 more comments
  • Anonymous Jan 26, 2009
    Vista with Microsoft document scannig complains of a non-existent hardware error.
  • rjbetty Mar 12, 2009
    Sorry I accidentally said I had a solution. No I don't. Just the problem.
    Richard Betambeau,
    Reading, UK
  • falesq Mar 24, 2009
    Can't scan using MS document scanning. This problem just started happening and I get the error message: ''The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again.'' I am using an HP Scanjet 5550c. Anybody know the fix?
  • Vandtekor May 07, 2009
    Yes, I'm getting the same problem. Running Vista 32, using an old Lexmark 5500 with MS Office 2003 Document Scanning. Worked a treat for a period of time, then without warning nor reason, I get:
    "The scan failed because of a scanner hardward error. Feeder may be jammed. Please correct the error and scan again"
    Strange thing is, it'll scan the preview and then just as the scanning light is about to return to it's original position as the preview scan is complete, this error will flag up and the scan is aborted.
    I've tried uninstalling and reinstalling the driver(s), but to no avail. All very frustrating...
    Any help anybody has, or hints in the right direction would be much appreciated. Thanks
  • aammo May 13, 2009
    My scanner says hardware error and feeder may jammed.please help?
    Problem Solver:
  • 5 Answers
I had the same problem on Vista Home x64 with a Lexmark 5150. I solved it by scanning from Windows Photo Gallery.
Posted on Oct 26, 2009
  • dgower2 Oct 26, 2009
  • abdillahijib
    abdillahijib Oct 20, 2012
    you're the BEST. This works for me
Yep. I also can't scan using the Samsung SCX-4200, which results in that error
Richard Betambeau,
Reading, UK
Posted on Mar 12, 2009
This is a step in the right direction, but by no means a solution. I tried scanning with VueScan, and it worked fine, which indicates that the problem lies with MS Document Scanning which I was using before.
I shall investigate further and post any useful info.
Posted on May 07, 2009
  • Vandtekor Jun 18, 2009
    Btw, you can always use Ifranview to scan documents. I used this as a
    replacement for MS Doc Img, as that failed. It's available at http://irfanview.com/. The only downside to it though, is that is scans
    at lower quality than MS Doc Img, though there may (must) be away
    around this.
    Problem Solver:
  • 9 Answers
If you choose the twain driver under the scanner link it will work. According to MS's Office site, WIA may not work with their application.
Posted on May 27, 2010
Paper load error
Try this approach:
1. Remove all the paper from the scanner feeder.2. Re-brick the printer by by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.3. When the printer turns on, try to scan again to verify that the problem is fixed.
Should the error continue, please contact Lexmark Technical Support Center for additional assistance.
Feb 07, 2012 | Lexmark Platinum Pro905 multifunction...
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
THE UPPER UNIT FLASHES ON THE SCREEN WITH ERROR CODE 39,003,40;75554
On the Xerox 8560MFP multifunction, this error code 39,003 signifies a Scanner problem, specifically that the Optical Test has failed. the 75554 is your current page count on the printer.
The Scanner Assembly 062K22590 must be replaced. It is fairly expensive, but moderately easy to replace.
You should also order the Scanner Calibration Sheet 109K01910 to make sure that margins and contrast are correct.
The scan/ document section is broken into 2 main parts, the Scanner, and the Automatic Document feeder. The feeder section is probably working fine.
Good luck with that.
Dec 27, 2010 | Xerox Phaser 8560MFP Printer
Am unable to use the feeder tray - it keeps saying paper jam. There is no jam -- something seems to be blocking the mobility of the paper. I have it on "office" use and the regular scan works one...
Click on the link below and download the User guide which will help you solve the paper jam problem.
User Manual
The above link has complete information for your Epson Scanner.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 13, 2010 | Epson Perfection 4490 Office Flatbed...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
Document Feeder, a warning dialog box opens after a few
moments.
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
The scanner output problem
replace scanner ccd or replace scanner cable
Mar 17, 2008 | HP ScanJet 2400 Flatbed Scanner
HP LaserJet 2840 Scanner problem
Have you looked to see if there is any paper at all in the trays. That are getting hung up.?? I can help
Feb 10, 2008 | HP LaserJet 2840 Printer
Scanner 3770 hardware problem
Hi, it is possible that your scanner has a transport locking lever or knob underneath which might have been keeping the carriage locked in place. Try checking and release if there is one. Hope this works for you. Pls post again how things turn up. Good luck and kind regards.
Jul 30, 2007 | HP Scanjet 3770 Flatbed Scanner
3,877 people viewed this question
jasbo
jasbo
