Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Communication error when i plugged my camera to the usb "communication error" appeared. help.
  • Anonymous Feb 18, 2009
    Have this prob with one mamory card only (I use many for work) Was able to download to PC using a different camera, but still cant identify why problem arises as it seems to be with one card only.
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
Posted on Jun 11, 2008
  • Cindy Oct 02, 2013
    You can also manually delete some photos so there are less than 1,000 pic and it will connect to your pc. and you can save the photos to your pc/and then format your memory card if desired.
I BELIEVE THE REASON IS THE TYPE OF SD CARD.
THERE ARE SD AND SDHC. IF YOU ARE USING SDHC IT GIVES CAMERAS ERRORS WHEN MOUNTING TO A COMPUTER.
THIS IS ALSO TRUE WITH OLDER CARD READERS. I HAVE AN OLDER AND NEWER CARD READER, SOME CARDS WORK AND OTHERS DONT - SDHC DOES NOT MOUNT WITH OLDER CARD READER.
HOW I FIGURED THIS OUT WAS, I JUST HAPPENED TO PUT AN OLDER CARD SD CARD IN MY NEW SD1300 AND IT READS FINE, BUT ALL NEW CARDS-SDHC WONT READ.
I BELIEVE SD IS UP TO 2GIGS AND SDHC IS 4GIGS AND HIGHER.
I HOPE THIS HELPS
Posted on Sep 01, 2010
Just returned from the Himalaya after 2 months with 1000's of images which would not download from the camera (a new Canon G10) - "communication error"!
Spent $20 on a card reader and problem was solved.
Thanks to Undeadmonkey!
Posted on Nov 02, 2009
  • snowball147 Feb 22, 2011
    I had the same problem.. :/ My camera contained over 3,000 images, and as i tried to download them to my computer, on the display of the camera stod something like "communication error". I tried to delete some of the pics so that my camera contained under 3,000 images, and then it worked. ;)
You can also manually delete some photos so the memory card has less than 1,000 pictures. Then your camera will connect to pc and you can save your photos and then format/delete all photos from the memory card if desired. This worked for me!
Posted on Oct 02, 2013
Tried a reader and nothing happened. Is this a MAC Problem, because I am using a MAC?
Posted on Jul 14, 2008
SOURCE: COMMUNICATION ERROR WHEN UPLOADING?
my camera did this after lending my camera and cord to somone else to upload pictures onto their computer, and then when i tried on my own it wouldnt let me.
all i had to do though was take the memory card out and put it back in.
Posted on Oct 19, 2008
  • 11967 Answers
SOURCE: "Communication Error" message
Use a card reader to download your pictures to a folder you create on your desktop.
Posted on Sep 29, 2009
diddydaveh
  • 154 Answers
SOURCE: I have plugged my camera into my computer on its
Hi, firstly check that the camera software is properly installed. It's sometimes worth re-installing it in case of a corruption. Next check the battery life in the camera is good, next unplug the camera cable and try it in a different usb port. if this still hasn't cured the problem, if you can try a replacement lead and if not, find a friend who will ;let you install your camera on their computer to rest it. If there is STILL no communication, I'm afraid you'll have to take then camera to a repair shop. hope this helps
Posted on Feb 22, 2010
Tri3mast
  • 747 Answers
SOURCE: when i conect the USB
The work flow should be first make sure the camera has enough power to do the transfer from the memory card to the computer turn off the camera. Connect the USB cable to the computer with the computer on. connect the USB cable to the camera mini USB port and turn on the camera. The computer will see this possibly as a new device and then accept it as an external drive or "Mass Storage Device"
Posted on Dec 21, 2010
  • 102366 Answers
SOURCE: when i plug the camera into the usb it comes up
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 12, 2011
Communication error
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jan 14, 2014 | Canon IXUS 80 IS Digital Camera
Communication error canon a4000 install
Mar 24, 2013 | Canon PowerShot A4000 IS Silver 16MP...
Communication error
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
Jul 03, 2010 | Canon PowerShot SD600 Digital Camera
USB COMMUNICATION ERROR!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto.
Oct 20, 2009 | Fuji FinePix S5700 Digital Camera
Communication error
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 27, 2009 | Fuji Finepix Z20fd Digital Camera
Connecting camera to the PC
Apr 06, 2009 | Fuji FinePix A345 Digital Camera
Communications error
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Jan 30, 2009 | Nikon COOLPIX L18 Digital Camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer or Picasa.
Jan 28, 2009 | Nikon COOLPIX L18 Digital Camera
"Communication Error" when trying to upload photos
Dec 06, 2008 | Fuji FinePix S1000FD Digital Camera
Jul 14, 2008 | Fuji FinePix S700 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
11,734 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
