Possible that there is no heat exchange with the cooling fan being unefficient. Normally all car ac's have a better cooling when it moves as the air flows into the condenser to have a better effect to cool. So when the ac does not respond so much you must
1. check the fan, check the fan speed.
2.Check for blocks in the condenser specially if there is any obstruction inthe fins. Use a good water jet air jett to clean the fins to have a better flow so that the fan blows out the heat.
3. reduced pressure of gas and poor conpressor performance can also reduce the cooling
Either clutch coil is heating up and letting go Or one of the sensors is defective. Or there is a restriction somewhere in the line (open up hood and look for frost on a/c lines.)
If this isn't the problem the AC compressor relay may also cause this, flip a coin.
