Question about Technics SL-1200M3D Turntable
Low volume on both sides
I hooked up my turntable to a vestax mixer and than the mixer into a speaker system but it still has low volume. What`s wrong? Is it expensive to fix. Please help got a gig comin up.
  • 515 Answers
Make sure you connected the turntable to the PHONO INPUT of your Vestax Mixer. If so, then the problem might be with your mixer output, or your sound system. You will need to test each unit individually to determine what the issue might be.
- OPTiC
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
Posted on Jul 12, 2008
I have my PL-5 hooked up to an amp and speakers. The only way I can hear it is by turning the volume all the way up on the amp. Even doing that the volume is very low. The weird thing is with the amp...
You need to buy a turntable pre-amp, as the signal output is much too low to drive an amplifier. Or buy a DJ mixer, which has a turntable preamp built in, as does any "integrated receiver" which is basically a tuner/phono preamp/amplifier combo in one box.
Nov 17, 2017 | Pioneer Audio Players & Recorders
Hello! We have some problem whith 1 chanel, when 2
BOTH turntables and the same channel on each? If it's really really low and tinny that would probably be a failure to have/use a PHONO preamp (built-in and selectable on the Mixer).
Swap the channels coming in from the mk1200 and see if it stays with the mk1200 or with the left channel of the mixer.
There IS an outside chance you have flaky connections at the cartridge.
May 06, 2011 | Vestax Pmc07pro DJ Mixer System
I get a signal on a channel but there is no output, just a loud hum.
It's a connector's problem, at this type of noise the ground wire is disconnected. Check the cables, reverse left - right to clarify the problem and, if needed, replace the faulty one. Take care to make these checks at low volume level because this kind of hum can burn out the speakers very easily.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Dec 05, 2010 | Vestax Pmc05pro-Sl 2-Channel DJ Mixer...
Volume Level on Memorex 9299M 4-in-1 Turntable System Way Too Low
It's the nature of the all-in-one turntable beast to be low fi and low performance. Too much volume and vibration would feed back through the turntable.
It does have a Line Out that you could slave over to REAL electronics and speakers.
May 23, 2010 | Memorex Nostalgia Turntable and Stereo...
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Apr 18, 2010 | Technics SL-1200 Turntable
1 X 1200Mk2deck higher volume / causing spkr not to work..
Problem If you swapped the two TT's would the problem stay with the connection on your mixer? At least then you/we would know wherein lies the problem. I'm betting thge low volume is because you have the phono jacked into a line level input like AUX instead of PHONO.
Typically, what you're describing is a phone source plugged into a NON-phono connection. (Tinny, low volume - classic lack of a phono preamplifier with RIAA equaliztion). A standard old-school tuntable requires a phono preamp that is labeled "PHONO". Nothing else will give it the boost and freq response correction LP's and phono cartridges produce.
Your problem #2 alludes to a channel problem with a turntable running through your mixer. This isn't rocket science. Swapping the two turntable channels around would probably change the apparent failing channel, right? Yes - Problem out at the turntable. No - problem in the mixer. You've already hinted at the source by monkeying with the tonearm wiring. You're on the right track. The tiny multi-colored wires in the cartridge shell are very thin and delicate. Their brass fittings sometimes oxidize and reseating them as you have done usually gives some relief. Kinks in the wires could cause your intermittent symptom. At the RCA end of the tonearm cables, make sure they're seated on with a twist to wipe off oxide.
Problem #3. Is it just bothering you or is there a functional problem, too?
Apr 21, 2009 | Technics SL-1210 Turntable
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Sound is way too low
Make sure you are connecting the unit to the PHONO input on your receiver or mixer. If you do not have a PHONO input, then you need to purchase a PHONO PRE-AMP and then you'll be able to connect to any LINE or AUX level input.
- DJ PRO LAB
www.djprolab.com
May 01, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200M3D Turntable Logo
290 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
