Question about HP Compaq nx5000 Notebook
Screen goes black
Hi there my screen goes black sometimes and if i move it up and down it fixes itself . but sometime not, i have a spare laptop for parts i just need to know witch part to change . if anyone can help me that would be rawsome
cheers buddy
  • 3 Answers
This problem is fixable with no parts.
the ribbon cable inside the back of the monitor most likely is loose. if when the screen goes black you can tell that the back light is still on inside the screen then this fix is definitely for you.if the back light is what is going off then you may try swapping the inverter from the other screen, this requires disassembling the screen to do, follow the instructions below to get it apart, then find the inverter at the bottom of the screen, but from what you said about moving the screen makes it come back on id pat its just the ribon cable as discribed below. the nx5000 has a notorious problem for the monitor going out, sometimes it flickers and sometimes it just doesn't show anything at all. the problem is often easily fixable in less then 20 minutes.
the cable that connects the computer to the monitor comes unplugged on the back of the monitor.
you will need to disassemble the monitor to do this fix, don't worry it is easy.
get a Phillips screw driver and a small flat screwdriver and use the flat to pry off the 5 round rubber plugs on the front of the monitor.
next use the Phillips to remove the 5 screws.
next use the Phillips to remove the 4 screws on the edge of the screen.
next using caution pry pull or rip the inside bezel off from around the screen, there is double sided tape holding it to the screen. careful not to break or disfigure the bezel durring removal.
once you get this off there is 4 screws into each hinge at the bottom of the screen. remove those.
now the outside cover will be completely lose and dangling by the wi-fi antenna cable.
now the connector on the back of the monitor is exposed and in many cases it looks like its is only half plugged in, plug it in all the way until it is even and turn the computer on, see if this fixes your problem.
you may put a piece of tape to help hold it in but i doubt it would really help.
reassemble in reverse order, be careful to route the wi-fi cables through the little opening or they will be pinched and your wi-fi will no longer work.
it may not happen again for years or ever, it is possible that some joker working at hp was lazy and left hundreds of these only half plugged in, or did it intentionally.
Good Luck
Lanshark
Posted on Jul 19, 2009
  • 1,031 Answers
. if The screen flickers then turns dark,when you move it or tap it lightly on the sides, it may be due to Failed cable at the back of the screen or LCD
In some cases you might hear a buzzing noise coming from the area where the inverter board is located, it’s on the bottom part of the screen Troubleshooting: If the screen is black, look for the “lid closed” switch and try pushing it a few times. It’s usually a small switch near the hinges that is pressed when the lid(the screen) is closed. Sometimes these switches get stuck in the “lid closed” position that results in black screen(no backlight) or non-starting laptop. Also some laptops have a magnetic switch (newer Dells, most Macs, etc.) that doesn’t get stuck.
The most common failures are (in this order): inverter, “lid closed” switch, cable, LCD, backlight.
the display assembly.so open the display assembly check the cable fix it tightly and again if no improvement change the inverter PCB
Posted on May 20, 2008
Hi Chris my toshiba satellite L875D-S7332 randomly goes to black screen, then i click it type in password and can get it back, sometimes, other times the blackouts become to frequent and i am unable t
I think the problem might be in your laptop screen,did you try to turn it on in different positions,I mean the part between keyboard and screen might be broken.I suggest you first reinstall windows/mac or whatever,then try in different positions(move you'r screen up down),and if nothing work,take it on service :/
Mar 26, 2014 | Computers & Internet
When laptop turned on the screen is bright white with black lines
Hook a spare monitor to the video output usually on the back, if picture okay! you may have a loose video cable, or intermittent LCD display. If spare is the same, it means the video graphic card is defective and is part of the motherboard.
Mar 05, 2012 | HP Computers & Internet
Acer Aspire 7720-6569. The screen on the laptop periodically washes out to bluish-gray, then goes black with occasional horizontal streaks. Sometimes comes back to life. The external monitor works fine. Is...
Hi friend, In this case i would recommend you to please try and install the latest video drivers for the laptop and also try to move the screen of the laptop up and down to check if it makes any difference because it might be possible that the LCD cable is loose.
Dec 09, 2010 | Acer Aspire 7720-6569 Notebook
GATEWAY LAPTOP COMPUTER IS FULLY FUNCTIONAL WITH BLACK SCREEN
umm i would not if you really never opened a laptop before there is deffently a wire loose in there no doubt about that. if you know anyone that could just open the scren part and fix the wire you should be in buissness
Jun 05, 2009 | Gateway MT3705 Notebook
Green red blue stripes down the middle 32in lcd I have a similar problem. When I first turn the tv on, the screen is mostly black, with small vertical colored lines shown scattered across it. Then,...
Hi
Base in your complaint, you have defective Ribbon Wire thats connected to the LCD to Mother board..
Or you have loosed contact to Pin Ribbon Wire that needs to re solder..
Thanks!
Jan 28, 2009 | Televison & Video
Inspiron 1521 green screen problem
Either the lcd cable is loose on the inverter board, the lcd cable is going bad, or the inverter is going bad. Usually this can be fixed by removing the power button bezel and making sure all the cables are seated properly on their connection. Removing the power button bezel varies from laptop to laptop, sometimes there are screws on the bottom of the laptop that you need to remove and sometimes there are not, it just snaps into place.
Thanks and please take a moment to rate as fixya.
Nov 25, 2008 | Toshiba Tecra 8000 Notebook
Screen goes black
here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Sep 08, 2017 | Televison & Video
Optical mouse moves by itself
yes reinstall the software
Aug 31, 2008 | Computers & Internet
A whole crapload of problems.
Not a hard drive issue I'm afraid. Sounds like they switched the whole system out. So you disassembled the laptop and put it back together? That's more than most of these guys can do. You've got a loose lcd cable, or memory is going bad, or there's a short in the case-palm rest area. All these are common with this model. Good luck
Oct 08, 2007 | Toshiba Satellite A105 Notebook
HP Compaq nx5000 Notebook Logo
464 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
