How to get a new Microphone I purchased to work
I do not know what plugs at the rear of stereo I have to have in or if there is something else I am not doing
  • Hopelessone May 20, 2008
    This problem is for a Pye Stereo Model No.CST4000
  • Hopelessone May 22, 2008
    Thankyou so much Kiyro for fixing my problem!
    Problem Solver:
  • 4 Answers
Your stereo most likely has an audio input in the back. 1 red and 1 white. It's usually labeled "AUX". Go to your local electronics shop, (radio sh**k) and get an rca audio cable where on one side it's 2 cables (red & white), and on the other side it looks like a headphone jack input or female Your microphone should plug into that side, unless your mic has the big jack. In that case just get the adapter to go from big to small. The red and white part of the cable will go into the AUX input on the back of your radio. And that's it!
just press the AUX mode of your stereo and your mic should work.
Posted on May 22, 2008
Hi I've purchased a new double din stereo for my vw sharan 02 reg plugged it in and it's permenantly live any ideas
Check colour coding off old unit plug too new unit plug sounds like acc wire is in wrong position for your model. Put stereos together an check loom from actual deck should have a plug on end make sure both same, if stereo has no plug from it an you plug loom into rear of unit then wrong stereo given an you will need service manual to correct wiring positions.
May 05, 2015 | Cars & Trucks
Microphone dosen't work
Just go and buy a microphone on its own, they are cheap maybe 10, it will plug in and work perfectly, you have over complicated yourself
Apr 19, 2014 | Dell Dimension 8300 PC Desktop
Why do I only hear static
Hi Cathy.. it sounds like you might be connected to the wrong jacks instead of the output that the headphones need.
Most high quality stereo headphones have a single 1/4" stereo plug that would readily plug into a 1/4" jack on the front of the stereo labeled "PHONES" or HEADPHONES".
Many lower quality "computer headphones" or headsets have two 1/8" plugs. One is often black or red and is for an included microphone that may be a boom type (shown below) connected to one of the speakers or an "in-line" type built into the cord itself. The headphone speakers in the headset get their signal from the other plug - which is usually green; but could be any color really. There should be 3 metal parts on the stereo headphone plug. The tip, the middle ring and the bottom ring. Many times the mic is mono (not stereo) and only has only a tip and a bottom ring on the plug. You can see stereo headphone and microphone plugs he picture below:
Computer Headphones or "Headset" with mic and phone plugs.
Your Yamaha stereo will probably NOT have 1/8" jacks to directly plug the headphone into. You can buy an adapter that you would plug your headphones into and then plug the adapter into the 1/4" jack on the stereo. One is pictured below:
Front and rear views of a "1/4" to 1/8" Stereo Adapter Plug" The front plugs into the stereo and the the smaller 1/8" headphones plug into the rear.
I hope this helps & good luck!
Jan 21, 2012 | Sennheiser Audio Players & Recorders
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 22, 2010 | Kenwood KDC-422 CD Player
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Jun 02, 2009 | Yamaha HTR-5440 Receiver
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Stereo Illumination Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
Microphone doesn't work with small plug
I'm just taking a stab in the dark here but bare with me on this, I got a lot of info stored in this old head so it takes a while.
If you look at the jack for the microphone, Does it have 2 sleaves and a pin or just 1 sleave and a pin. If it has 2 then you will need an adaptor (Normaly Stereo jack to XLR). If it has 1 sleave then your going to need a preamp.
Apr 20, 2009 | Computers & Internet
Logitech Clear Chat Stereo microphones
You should go to logitecs website and search for the microphone drivers and install them. Thhis should solve your problem.
Kenneth Triest
Oct 23, 2008 | Shure Head Set Microphone Microphone
164 people viewed this question
