Question about Sony Ericsson K800i Cellular Phone
Master reset without using soft keys?
Hi i need to preform a master reset for a k850i but i cannot use the 3 touchscreen softkeys across the top.
I know theres a shortcut to view your IMEI number which you type into the number pad but is there any such shortcut that will reset the handset?
thanks in advance
  • 282 Answers
There is no code to make a fact reset on SE fones. But if you have the usb cable you can do it with some free softs.
Posted on May 20, 2008
How to remove align screen
Problem can com from your touchscreen panel.
you need to replace it manually. only then this will be solved.
or you can try with soft reset or hard reset.
please find explanation at below :
i-Mate JAQ3 soft reset
Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
running slower than normal, or a program is not performing properly.
A soft reset is also necessary after the installation of some programs.
If a soft reset is performed when programs are running, unsaved work
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its default
settings - the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
programs will remain.
To perform a soft reset
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard resetHard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
hope this kind information will be help you to solved
Dec 24, 2010 | i-mate JAQ3 Smartphone
After using the ear phone jack, my 9502 refuses to turn the speakers back on unless I jiggle the ear phone in the jack. A toothpick works as well so it is a mechanical problem, not an electronic problem....
back up all data and then master reset.
Take out the battery for a minute and then put it back, then press the Left and Right soft keys (the ones that look like a dash above the call and hang up buttons) at the same time, hold, and softly push the Reset button on the left? side of the device. Keep holding the SoftKeys until a confirmation message appears or the device boots up differently.
Mar 24, 2010 | i-mate Ultimate 9502 Cell Phone
How to reset soni ercsson w850i
To perform a master/hard reset on your Sony Ericsson K850i you will need to:Menu > Settings > scroll down to master reset > reset all
hope this helps.
Dec 22, 2009 | Cell Phones
How do i master reset on sony ericsson k850i with a code?
the master reset code for sony is 0000 or 00000, try this code. hope it will help...
Feb 03, 2009 | Sony Ericsson K850i Mobile Phone
HTC TY II Product - messaging not working
You will have to do a master or "hard" reset which will reset your phone to factory state. This can be done via Tapping Start > Settings > System tab, then tap Clear Storage and input "1234". Conversely you can also hard reset your phone by holding both your softkeys (the physical keys that map to left and right menu options) and using your stylus to hit the reset button while holding those two softkeys.
Apr 29, 2008 | HTC TyTN Smartphone
Master Reset...
Try this:
Use the jogdial and * key:
up, * down, down, *, down,*
In the on-screen menu, goto service fuctions. Then, do a master reset.
Jan 13, 2008 | Sony Ericsson P910i Cellular Phone
Won't start up past the green 'windows mobile' screen
I just tried it too. It wouldn't work at first, but this is what i did. At first i kept pushing the softkeys first and then the power button, but you have to do them the opposite way.
Push and hold the on button and as soon as you do that, hold down the (-) two softkey menu select buttons (above the home and <- buttons)
it will take you to the black screen that says its going to reconfigure
then you push the green talk button
it'll look like it freezes again, but its really booting up. so leave it alone. mine took 5 minutes to finish. i really didnt think it was going to work again. but YAY! it did..
Nov 08, 2007 | T-Mobile Dash Smartphone
Touch Screen Frozen
Note: A master reset will erase all favorites1 and will restore your device to the default factory settings. If you would like to back up your favorites to your computer, you can find instructions to do so on the Garmin site
To perform a master reset on a nuvi 300 series device:
1.Start with the device OFF and unplugged from the power source
2.Touch and hold the top right corner of the touchscreen2
3.Power the device ON while continuing to hold the touchscreen
4.The message "Do you really want to erase all user data?" will appear
5.Remove your finger from the touchscreen when this message displays
6.Touch Yes
After the nuvi resets, follow the on-screen prompts, and then place your device in an area with a clear view of the sky until it acquires satellites.
Although the master reset will erase all saved favorites, any loaded custom points of interest will remain intact on the device.
If the message in step 3 does not appear when using the top right corner of the touchscreen, please repeat these steps using the bottom right corner of the touchscreen instead.
Jan 19, 2018 | Garmin n vi 360 GPS Receiver
Sony Ericsson K800i Cellular Phone Logo
459 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
