Kenmore 110.92380200 washer lid switch replacement
The lid switch of my Kenmore washer model# 110.92380200 broke and needs to be replaced. I can get the part no problem but how can I replace it? How can I take the broken one out and put the new on in? Thanks in advance.
  • Anonymous Apr 12, 2009
    I do not know how to get the lid switch out I can not get to where it plugs in
  • Anonymous Apr 24, 2009
    is this a generic solution? I have a different model from the mid 90's.
  • 868 Answers
You first have to remove the 2 phillip head screws on your face panel.There is one on each side located about 1 inch from the front corner.tThese 2 screws are holding down the entire front timer panel.Ok,now lift up & forward at the same time so you can swing back this timer panel and get it to balance back out of the way.Now, it becomes a little harder,locate the harness that your lid/spin switch is on by unscrewing the 2 screws on the spin switch.Pulling the bad switch away from your cabinet will expose the harness ,that way you will see where it is plugged in.After unplugging it your now ready to plug the new one in and just tuck in the harness in the cabinet.Flip the timer panel back down and screw it back down.Your done !!!
Posted on May 20, 2008
I have a Kenmore 11020722991 washer. My lid switch broke and i need to remove the top of the washer what is the best way of doing that?
You will need to remove the exterior washer case in order to access it. The entire washer case comes off the frame on this model and is removed for access to the internal cabinet components. This is a lot easier than it sounds. The following link explains step-by-step how to access and replace a lid switch:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 31, 2010 | Kenmore 20722
Replace lid switch on a Kenmore washer
Sometimes on these you need to open the lid, remove the screws there first, then take the screws off the back. Try that.
Aug 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
Yes I fixed my washer problem.
The washer was stopping before it would drain and spin. I would raise the lid and then close it back and it would start back up. So we figured the lid switch was broke.
Before you do anything you "unplug" the washer!
You have to pop the ends off the back panel with the buttons on it. Then you unscrew the 2 screws at the bottom of the panel and raise it up. Then you remove the brass clips that are holding the lid on. Then you move the whole washing machine cabinet out. My husband replaced the lid switch. Then we had to figure out how to get the cabinet back on right. That took some time but we did it. Then you repeat everything you did to take it off to put it back together.
The washer is working fine now.
May 18, 2009 | Kenmore Washing Machines
Kenmore 80 series lid switch
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
May 11, 2009 | Kenmore Washing Machines
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore lid switch broke inside washer?
Bought a new lid switch and replaced it.
Apr 08, 2009 | Tecnik TKL9260 Front Load Washer
The part that gets pushed down by the lever when the washing machine lid is closed broke off my older Kenmore Washing Machine. Can it be replaced or do I need a new washer?
Its the lid switch i think, of course you can get a replacement and fit it yourself. You need your model number, etc to look below.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Mar 13, 2009 | Kenmore 15864/15862 Top Load Washer
Washer won't spin,rinse,or drain
BAD LID SWITCH,YOU CAN REPLACE IT OR BY PASS IT,REMOVE THE 2 CONSOLE HEAD SCREWS ONE ON EACH SIDE,FLIP THE TOP UP,YOU WILL SEE THE LID SWITCH JACK,YOU CAN CUT THE 2 OUTSIDE WIRES AND PUT THEM TOGETHER WITH A WIRE NUT AND PLUG BACK IN,YOU HAVE NOW BY PASSED THE LID SWITCH AND YOUR GOOD TO GO-MIKE
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
564 people viewed this question
Top Washing Machines Experts
