Question about Insignia NS-DV2G MP3 Player
Can't open downloaded files off Media Player 11 off new pc with Vista installed.
I recently bought a new pc with the Vista operating system. I installed my software for my Insignia onto it. Media Player 11 will download my music choices but when I try to play them back, I get a message that my Insignia can't open the file. I have no problems downloading and playback when I install off my old pc with XP installed on it. But all my music is now on my new pc. Is it the operating system or could Media Player 11 not be compatable with my Insignia? I have Media Player 9 on my old pc.
  • van77 May 21, 2008
    Well. I solved my problem by experimentation with my pc (Vista operating system) and my Insignia. I had ALL the problems that I saw posted on here; froze after downloading from my Media Player, won't turn off, reverting back to start up screen and the main issue with mine, ERROR player can't open this file. Folks, I've got to tell you. I transferred my music files from my old PC (XP system) using a flash drive and this was a BAD choice. The online music provider won't let me use the files on my Insignia (not sure about other manufacturers), and FROZE up the player itself. I've had to delete EVERYTHING off both and start over from scratch, reinstalling CD by CD into my pc. Don't change the settings on the Media Player 11 that comes with Vista, as anything other then Windows Media Audio for your format and nothing other then 64 kbs (default setting) for your bit rate, or you will receive ERROR: Can't open this file. We are all 3 very happily coexisting now. And I hope my solution will help you with your's.
    Thanks anyway. I solved the problem.
Try administrator rights by right-clicking on Windows media player or try to turn off UAC(User acc control)
Posted on Apr 15, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Olympus ws-110 no playback when connected to pc
ahh...that sounds like a player issue..open your settings on WMP and look to see that it's not on sample mode
Mar 25, 2008 | Audio Players & Recorders
I cannot get songs to download onto this new mp3 player and i cannot figure out how to erase the pre-programmed songs.
Hi liz enriquez...
Here is a little help on downloading some songs to your mp3 player and then how to delete from your mp3 player
Downloading songs:
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod below:
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me
Aug 07, 2011 | Mach Speed Audio Players & Recorders
My windows media player11 was now but it was not installed and showing microsoft genuine product plz solve this my problem and validate my win media player 11
Media player 11 is part of Vista,It is installed with vista and cannot be installed without reinstalling vista,You don't need to validate media player,you only need to validate vista,That can only be done through Microsoft.
May 08, 2009 | Microsoft Windows Vista Ultimate Edition
I tried to download window media player 11
Try going into the control panel
Start>control panel>add/remove programs
Uninstall media player 11
If you really want to you can try to download and install again but it sounds like the file is messed up on the server you downloaded from.
Jan 26, 2009 | E-Machines T2615 PC Desktop
Error when I try to use Windows Media Player 10 or 11
This error is generally the result of a corrupt or missing Custsat.dll file, usually located in the C:Program FilesWindows Media Player folder.To workaround this problem:
1. Remove the current Windows Media Player 10 install.
2. Download and install
Windows Media Player 11 for Windows Vista
or
wm_tn_wmp11xp.jpgDownload Player 11 for Windows XP
I tend to use VLC Player, as it plays everything I throw at it..
Hope this helps
Chris (ziraffa)
Jan 05, 2009 | Microsoft Windows Media Player
Windows media player disappears
Hi shen,
can you download and try another player? like winamp...just to check or isolate the problem.
Jun 24, 2008 | Microsoft Windows XP Media Center Edition...
Green screen on windows media player and trouble installing drivers?
Hi, does this occur when you open all files or just movie files, eg. avi files? there is a free application called gspot, this will tell you what the file is encoded with. Are all your codecs installed? failing this you could possibly go back to WMplayer 10. hope this helps...
Feb 18, 2008 | Computers & Internet
My sansa 250 mp3 player
http://www.rhapsody.com/-software
there i just downloaded the software from the site... enjoy :D
Jun 10, 2007 | SanDisk Sansa e250 MP3 Player
Insignia NS-DV2G MP3 Player Logo
166 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
