Question about Dopod 818 Pro Smartphone
Screen freezing My Dopod 818pro screen was freezing. I can't do anything about the screen. I had tried press the reset button, tried to pull out the battery and switch on the switch button but still not function. Please somebody help. Thank you for your corperation. Regards, Hafizi
I have similar problem also after trying to install CE Start software. Hope someone can help us out.
Regards,
CK
Posted on Jun 01, 2008
I also got the same problem, the lcd always goes to blank, white screen, anyone can help me how to solve it, thanks
Posted on Aug 01, 2008
My dopod 818 pro gets hanged on start up at htc innovation logo....please help
do a hard reset, beware all data will be lost and you need to calibrate screen again.
press two soft keys above call and end button press power button and insert stylus in reset hole,
phone will display some thing press green send button to restore or format.
you are done
Dec 22, 2010 | Dopod 818 Pro Smartphone
Dear sirs, I have a Dopod T3238. After a software installation concerning Greek Language when I restarted my cellphone I got a white screen (initial screen) says "Dopod T3238" but it never entered the...
I pressed the green button (left) then the ENTER button (center) and finally the POWER button. That is what I did before but the change I made and succed was that I formated an SD card to FAT 32 system file (not in FAT 16 because in FAT 16 did not work).
After these I got a colored (steady) screen with options. I chose the option No 5 "Clear User Space" and after a while the cell-phoned made a "Hard Reset".
Best regards
Jan 15, 2010 | Cell Phones
Dopod 818pro mobile is having problem
That is a seriously old phone(but still awsome) and you may not be able to get the help from the manufacturer by now.
You can search google for instructions about updating/upgrading your phone OS. That will fix your phone
Jun 11, 2017 | Cell Phones
Freezing at the "HP iPAQ Pocket PC start-up" and won't advance any further. (think that it pushed up against something in my bag, and perhaps maxed the memory?). Not at a point where ActiveSync can...
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
Jul 25, 2009 | HP iPAQ RX5915 Travel Companion GPS...
My Dopod 900 (aka O2 Xda Exec) White Screen Problem
if you have a lot of data on your phone, do a sync. if it synched properly, if it does, probably the flex is damaged or the screen alone. try to press all the buttons on ur pda phone. if they all make a sound (if your sounds for keys are enabled, i hope) your flex is alright. have your LCD changed. try to tap your screen also if it makes a a sound... Hoping to be of help to you.
Apr 13, 2009 | O2 Xda Atom Exec Smartphone
Mogul Screen black
Press the soft reset button located right under the SD mini memory card its a small hole just press there with your stylus (pen)
Oct 26, 2008 | HTC PPC-6800 Smartphone
Lock code
HTC X7500/7501-(ATHENA/ADVANTAGE/Dopod U1000/T.Mobile AMEO)
Slide the Volume slider down and at the same time, use the stylus to press the RESET button at the back of your
device. After a brief period of time, two choices will appear on-screen. Press the CENTER OK button to perform the
hard reset. (Otherwise, if any, press the CAMERA button to exit.)
or try with this link...
http://www.efsoft.it/resetdev.htm
Jun 09, 2008 | HTC Advantage X7500 Smartphone
Dopod 838 pro touchscreen not working
Have you tried a hard reset?
(Hold in the power button why pressing the stylus in the reset button on the bottom of the phone)
Jan 29, 2008 | HTC TyTN Smartphone
White screen
the same thing happend to me but if ixed it
what you do is go to the shops and buy and small screw driver and on the back of the slidyout bit there is two screws tighten them up a bit and that fixes the prob
Jan 28, 2008 | Dopod 838 Smartphone
Dopod 818 Pro Smartphone Logo
134 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
