Insignia LCD TV won't recognize computer input...
I recently bought an Insignia 19" LCD TV [NS-LCD19 720p] (with 1440X900 display resolution and NTSC tuner) and am trying to connect it to my Apple MacBook 15". I purchased a DVI to VGA cable, and a mini-DVI to DVI adapter which works fine. When plugged in, my MacBook recognizes the MacBook monitor and also IDENTIFIES the Insignia TV/monitor, but the Insignia TV continues to read NO SIGNAL! I tried changing the resolution of the MacBook display to 1440X852 (the closest to 1440x900) and it did not work. I tried shutting all off and starting the MacBook first, and then starting the Insignia LCD-TV and it still read NO SIGNAL! What do I need to do to get the Insignia to recognize the computer since it is supposed to act as a monitor for a computer?
  • 13 more comments
  • cwadrun Jun 15, 2008
    I have the same problem.
  • beagle2369 Jul 07, 2008
    Hooked up my 15 in. MBP to a 22 in. Insignia, similar problem.  It recognized that there was something there, but gave me a different error message.
  • darin_dick Jul 09, 2008
    same issue - any help is appreciated.
    Please email me at becuase I'm having the same issue.
  • illustrator Aug 02, 2008
    Same problem. The tv was hooked up to a computer at the store but when I got it home the screen remains black. I'd appreciate any help.
  • Anonymous Sep 08, 2008
    i have the same problem where my tv does not detect my MacBook, so i also tried using DVI to HDMI instead of VGA and this time the tv detects the computer but reads "mode not supported" please help-
  • Anonymous Sep 24, 2008
    I have a toshiba laptop running windows xp. vga hookup to vga on tv it does not recognize the display at all it either goes to video not supported or no connection made. I bought this tv 5 days ago i spoke with tech support they ar nt sure I brought my laptop into best buy hooked it up to the display model on the floor and it didn't work either. The geek squad tried ever thing that i had tried already on my tv with the answer well i guess its not compatible. And that's it. I did try hooking it up with the s video and it did work but was very fuzzy and looked like crap no matter what rez i put it in. Well I wonder if using a vga to dvi adapter and the a dvi to hdmi would work but that's expensive. Dunno im stumped
  • Anonymous Oct 04, 2008
    I have a new toshiba HDTV and I get the wallpaper on the tv and nothing else, i am using the connectors purchased at apple and cant get it to work, i thought I would be able to use the larger screen and get the web on it and watch dvds
    anyone else have this challange?
  • kulawrence Oct 05, 2008
    Same problem. Please help.
  • Miroslaw Stanczyk
    Miroslaw Stanczyk Oct 21, 2008
    Have the same problem with trying to connect my PC to Insignia 20"LCD with D-Sub PC input.
    LCD keeps complaining that refresh rate is out of range and needs to to se to 60Hz, then I run PC in safe mode, set refresh rate to 60Hz and then autodetect indicate it is starting at 60HX but after ew second it switches to 70Hz, and goes black.
    Any ideas what the real problem is?
  • Anonymous Dec 05, 2008
    I have the same problem. I'm trying to hook my computer to my 42" insignia lcd hdtv. The screen shows on the tv for about a minute when I hook it up then it goes to no signal. I have tried changing the resolution and this has done no good. Please help.
  • jusjerry216 Dec 19, 2008
    I have an RCA W26WD26D and I have the same problen the "No Signal" is all I get when trying to hook my TV to my computer. I've tried all the settings changes, disconnecting the VGA and reconnecting it in hopes that the computer would recognize it but nothing seems to work. Is there something that I can do to make this work?
  • Anonymous Dec 29, 2008
    Mac detects the display fine, it just will not show up on the TV.
  • billyo29 Apr 14, 2009
    Idid almost Identical things same result. I have a hp laptop with a sony 46" lcd Z series. went to Sear with my lap. same result on all Soney models. never tried any other brands
  • Taalor Nakol McDade
    Taalor Nakol McDade Dec 19, 2013
    I am having a similar problem except mine keeps going in and out. It will flash a blue screen and come up with the little hdmi box at the top then flash blue 3 seconds later and disconnect from hdmi. I've got a macbook air and I've got an insignia tv
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
Posted on Oct 27, 2008
  • inoelprogram
    inoelprogram Jun 01, 2012
    adding in: On Mac, the menu for display settings pops up individually on each monitor, so the menu that you "can see" is for your laptop not for your attached monitor. Use the SPACES view feature to pull the display menu over to your viewable screen. You have to use the SPACES feature!
  • inoelprogram
Here is my mac friendly solution:
Open your display settings (found in system preferences). Plug your computer into the TVs VGA port. Then, without shutting off the computer, unplug the VGA cable from the TV and put it back into your monitor.. A new list of resolutions should now be seen in the display settings. From the list, select a resolution that you know is supported by your TV (for me the max is 1680 x 1050). Unplug the VGA cable and hook it back up to your TV. You may have to turn the TV off and back on again or reselect the VGA setting to get it to try again, although I think it should work after a 5 or 7 second delay.
Posted on Nov 06, 2008
I lowered my resolution and now it works perfect
Posted on Aug 11, 2008
Setup insignia NS-LCD19. I get a "signal not
Your computer video output resolution is not compatible with the TV. Try adjusting your video card output settings to 800x600 at 60 hz to begin. Once the desktop displays on your TV, you may continue to adjust the settings to meet your needs.
Oct 12, 2011 | Insignia NS-LCD19 19 in. LCD TV
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
I have an insignia NS-LCD19. I get a "signal not support" error when connecting to my P.C. Is there a fix?
Usually this is because the video card settings and the TV settings do not agree. Here is a resolution that has worked for others.
Mar 12, 2010 | Insignia NS-LCD19 19 in. LCD TV
Dvd player is playing in black and white on new tv. tv is a Insignia NS-P502Q-10
could it be the DVD player is european or simply set to output PAL or SECAM and not NTSC?
About the time plasma and LCD TVs started to replace classic CRTs pretty much all CRT TVs used to be able to handle both PAL/SECAM and NTSC.
Then, whether because of the difference in handling them due to switching to fixed display resolution or because of other considerations, less and less LCD and plasma TVs are handling all encodings.
So an older TV could have actually handled the encoding while a newer one lacks it, thus resulting in B/W image.
Feb 14, 2010 | Insignia NS-P501Q-10A 50 in. HD-Ready...
I just bought a 19 inch flat tv with the dvd player and pc input. I hooked it up to my computer with the vga cable and it says it doesn't recognize the format. what am I doing wrong?
Set the screen resolution, on the PC, to a low initial setting say 800x600 32bit, and also ensure your Video Out is set right either PAL or NTSC depending on what your TV receives. Make sure you have activated dual display "Extend windows desktop to here" under Video Properties, (Right Click Desktop)...and finally plug in to TV, turn on, and THEN boot up.
Feb 03, 2010 | Emerson LD195EM8 19 in. LCD TV
Input not supported is floating round my monitor screen how do i get rid of it
You probably need to change the resolution setting in your computer display settings to a setting that is supported by the monitor.
Your resolution setting right now is probably too high to be recognized by the monitor.
1440x900 should be the resolution setting for an AL1916w if your video card will allow that setting
Jul 19, 2009 | Acer AL1916W 19" LCD Monitor
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Apr 15, 2009 | LG L194WT 19" LCD Monitor
VG4 mode on Insignia 19" widescreen LCD wont accept computer
go to your control panel of your computer (using a different monitor obviously) and change your screen resolution to 640x480, 800x600, 1024x768, or 1440x900. any of those resolutions should work. also go to advanced and make sure it is set at 60 herz.
Feb 25, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Jul 30, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
Televison & Video Logo
29,202 people viewed this question
Top Televison & Video Experts
