Question about SanDisk Sansa m240 MP3 Player
Problem with the settings
I formatted my sansa mp3 player but now when i power it on after powering it off the settings do not get restored..and the factory settings appear.this happens everytime i power it on.please tell me how can i save the settings.
  • 8,596 Answers
Firmware upgrade needed - go to Sandisk website
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
It got hanged..it can be turned and the buttons are not functioning
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
Instructions
Complete Reset
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
Player is froze
Release it, then turn it on again. Go to the Sansa website (http://www.sansa.com) and download the "SansaFirmware Updater." Select "Run" when the updater installs.(Installation will take less than two minutes.) Wait for the Sansa Firmware Updater to run through its system test. It willask you to connect the Sansa Clip to the computer to update your Sansa'ssoftware. Connect the Sansa Clip. Remove it from the computer when instructed. If thisprocess does not unfreeze your Sansa Clip, contact Sansa support at the SansaFirmware Updater website.
Complete Reset
Turn player on. Press the "Menu" (home) button.
Pressthe bottom of the scroll wheel until you reach the "Settings" screen.Push the center button to choose "Settings." Scrolldown to "Reset All" and select. You'll be asked to confirm the reset.Select "Yes." This option will simply allow you to reset the languageand location settings on your Sansa Clip. Thiswill not erase data from the clip.
To doa complete factory restore, whichwill erase all files from the clip, follow these steps: Inthe "Settings" menu, scroll down until you reach "Format"and then select. You will be asked to confirm that you wish to format. Select"Yes." Wait for the screen to say "Formatting Complete."You have now cleared all the files from your Sansa Clip and reset it to factorysettings.
Oct 24, 2010 | SanDisk Sansa Clip MP3 Player
When dowloading music, my sansa fuze (Refurb)
Save your music and format the sansa and reset
1: RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
2: Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
3: Recovery Mode also resets system settings when unplugged... lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode connect to comp when finished unplug
Apr 03, 2010 | SanDisk Sansa e260 MP3 Player
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
The sansa froze
press the power button for 15 seconds and it will shutdown itself. then try reformating your sansa using the sansa updater..
Aug 12, 2009 | SanDisk Sansa e250 MP3 Player
How do i reformat my Sansa e260 mp3 player? I want to erase everything off the player and have it like new again.
Reset All
will be gone.....
Go to my computer click on folder scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders Right click on your sansa then format a couple of times hope this works
Aug 05, 2009 | SanDisk Sansa e260 MP3 Player
When i turn on my sansa its said sandisk , then raspody sansa then it shut down by itsself , the turn on by its self and its repeats over and over again.
Reset All
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Jun 01, 2009 | SanDisk Sansa e250 MP3 Player
How do i reset my sansa e260 without using a program and if i have to use one where can i get it online for free
1. Press the "Power/Menu" button and select "Settings" and then select "USB".
2. On this screen, select "MSC".
To format your Sansa, please follow these steps:
1. Plug your Sansa into your computer then open "My Computer", right-click the drive associated with the player and choose "Format."
2. Set "File System" to "FAT" if your Sansa's capacity is less than 2GB. Otherwise, select FAT32.
3. Click on "Start" to proceed in formatting your Sansa.
I hope that helps..
Computerrep
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
SANSA c240 fails booting
i want softwere of sansa c240
Jul 08, 2008 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
