Question about Panasonic Microwave Ovens
1200w Genius microwave, about 4 years old. Has been working no problem until today. When I press start, its starts ok but cuts out after 23 seconds. It does this on every setting.
  • Panasonic Master
  • 9,098 Answers
The 22 seconds is the giveaway. In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
Panasonic Microwave Genius 1200W stop working. I move a little bit electric cord and it went on again. Then I pressed one min quick reheating. It blinks and stop working. Any solution ?
Assuming that you mean the whole unit goes off as if you unplugged it then the problem sound like the incoming power//you say that if you moce the cable then it comes on untill you try to use it //replace the whole cable from plug into the machine
Dec 29, 2009 | Microwave Ovens
My microwave is a 32ltr 1200w NNT583SF Inverter. it is 4 yrs old. No matter how long i set the timer for it will only work for 23 seconds, then it just switches off??
Aug 05, 2008 | Panasonic Microwave Ovens
Microwave not heating and countdown lasts 20 seconds before stopping. put food in and start as normally do then it stops. Microwave is the genius 1200w.
It sounds like it is the "magnetron" has given up. In any Microwave there is a device called magnetron. This is the device which radiates microwave to heat up anything inside for set time.
Before the device gives up most of the time usually the microwave makes little bit of loud noise. Usually it happens when there is abnormal power.
Remedy: Any qualified technician should be able to replace it. The spare is available from the service centre of the manufacturer. In most cases spare is expensive and it is better off to buy another one.
Jul 16, 2008 | Microwave Ovens
Model # NN-T793/T993
My first guess would be to checvk the venealation fan
Mar 31, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
225 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
