Question about Microsoft Windows Vista Ultimate Edition
Internet Not Working
Dear ALL,
Internet is not working in Windows Vista OS, which is in LAPTOP.
Given a LAN IP with DNS.
IP address is not getting ping. But Default Gateway and DNS pings.
If we ping to yahoo or google in cmd prompt. It pings
Needs Assistance.
With Regards,
System Admin.
Amadeus BLR.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Hi - Did anyone Helped you? Did you get your problem solved ?
  • Jason Disbrow May 11, 2010
    I'm assuming your behind a router...if so can you access the web interface of the router? Do this by typing to the gateway IP into your web browser. Let us know.
  • 108 Answers
I know i'm speaking the obvious, but you are defininatly being on a corporate LAN.
If you are able to ping google, than there is no problem with outside communication.
I'd check the configuration settings of first of all the software on the PC, then connect to the router/network server and see if your ports are being forwarded correctly through your firewall. If my memory serves me right, TCP ports 8000-8099 are used for web browsing, 21-25 are used for FTP access, etc.
It would also help to know if any other PCs on the network are experiencing the same problem or not. If they aren't, you could compare configuration settings in them to determine what to look for and change on the mulfunctioning computer.
if they aren't, your SOL on using that as a method, but still RDP or VNC to the server (or just factory reset the router, if it's a small soho router), and reconfigure/check settings.
Posted on May 27, 2008
Used to run wired desktop and wireless laptop off a Netgear DGN2000. No problems. Just changed the desktop for a new one. The laptop continues to work fine but can't get internet on new wired-in...
Check to see if the LAN card is enabled and working. If not install the LAN card driver.
If the LAN driver is working then go to Control Panel - Network Connections - right click on the LAN card then click on Properties, then check the TCP/IP settings of the LAN card, Tick Obtain an IP address automatically and tick Obtain an DNS server address automatically.
Then you will be able to connect to the Internet.
Jun 11, 2011 | NetGear DGN2000-100NAS Router
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . :
Subnet Mask . . . . . . . . . . . :
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
My server has 2 NIC one of them connected to the router (ISP) and one of them is connected to the LAN.But DHCP and DNS working but there is no internet to the Host and also the server itself.when i...
This is more a configuration error. Depending on how you have your DHCP setup, you may need to adjust it's setting. No mention of what os you are using but if you set your DHCP to give IP addresses only to the LAN, set the ISP NIC address to receive its ip from the ISP provider, you should be able to get Internet access to your server and the LAN.
If you have done so, use the server os to setup your Internet connection. Answer a few questions about how you connect to the Net and the os will do most of the configuration for you.
Good Luck
Jan 24, 2011 | Dell PowerEdge 1800 Server
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. into the box marked "IP Address, press tab "Subnet Mask" would appear automatically ( and in "Default gateway." type
To specify DNS server address settings, do one of the following:
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
Nov 25, 2010 | Linksys Wireless-G Broadband Router
I have a windows 2003 SBS Standard Edition and IP Address: also a Linksys WRV210 and the IP address I have setup a preferred DNS on all clients to The internet is not...
For that connect your router to directly to lan ports of your server.and install another ethernet lan card on server so that ports connect with switch.
Then configure your router as bridge connection then set dns as your server ip in all computers.Then you can get 100% fast internet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 15, 2009 | Computers & Internet
I have a Dell laptop connected via Wifi to Livebox and Internet works OK. I have bought another Dell laptop with Wifi for my son, but while his computer recognises the livebox, he can't access the...
In command prompt (with admin privleges)
Try to ping a domain name. For example:
Does it list an IP address? Do you get reply's? If you get replys then the internet on your son's laptop should be working. Try and make sure there are no proxies setup. Its a brand new laptop so there shouldn't be but check anyways.
In Internet Explorer goto tools, internet options, connections tab, lan settings button. Make sure the box use a proxy server for your LAN is unchecked.
If you don't get an ip address or reply's it would most likely signify that your DNS settings are incorrect. Verify the correct DNS settings by typing in 'ipconfig /all' in command prompt. It will show what your DNS ip address is set to. Make sure the settings are the same on the other laptop.
If they mismatch then you may have some settings incorrect in your wireless router, or the laptop itself, or both.
The ideal solution in that case is to resolve the dns issue on the wireless router, but for a quick solution, you can set the router to be the DNS host on the laptop. The process for doing so is OS specific. A quick google search should lead in the right direction.
If further problems persist, it may be a problem with the OS itself, or the hosts file.
Good Luck
Jun 20, 2009 | Computers & Internet
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: and Subnet Mask:
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
Problems with home networking between desktop running XP (wired) and laptop running Vista (wireless), using DSL broadband (PPPoE) internet connection, Westell 6100 modem/router & Linksys Wireless-G WR
Hi MissGarbs,
Based on your post and description, it would seem that your problem is caused by:
1. having 2 routers on the same system;
2. Both routers performs DHCP server function; and
3. Both routers use as default IP Add.
Your problems are:
a. laptop has no internet access only local network; and
b. you cannot access the router to make changes.
A possible solution. Pls back up your configurations first before attempting changes (or log them down somewhere so if needed you can revert back).
A. Power off and remove all connections to the LinkSys WRT54GS, set it aside for the moment. The objective is to verify/establish Internet connection.
Connect your desktop PC via LAN cable to the Westell 6100. Boot your desktop PC, right click on the networking icon bottom right side in your system tray, click on Status, click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right):
tick "Use the following IP address"
Enter values as shown below -
IP address:
Subnet mask:
Default Gateway:
DNS servers: &
click on OK, OK, Close.
Power on the Westell 6100, give it time to sync and connect to your Verison. .In the desktop PC, open a browser. Verify that your desktop have access to the Internet, do it on a few sites. Should you have no internet access, pls seek assistance from Verizon tech support. You need not mention the LinkSys nor the laptop since you have as of the moment a single PC attached directly to the Westell 6100.
If it is all green & go, power up your laptop and boot to Windows. Remove the LAN cable at the back of your desktop and connect it to the laptop's networking port. Do the same configuration ("Use the following IP address") to the networking/LAN card of your laptop.
IP address:
Subnet mask:
Default Gateway:
DNS servers: &
In the laptop open a browser. Verify that your laptop have access to the Internet, do it on a few sites. Should you have no internet access, pls seek assistance from Verizon tech support again. You need not mention the LinkSys nor the desktop since you have as of the moment a single laptop attached directly to the Westell 6100. (This is of course assuming that your laptop has a networking port)
If both the desktop PC and the laptop can now connect albeit individually to the Internet, the LinkSys may now be inserted into the system.
B. Disconnect the LAN connection of the laptop to the Westel 6100 and connect it to one of the 4 LAN ports at the rear of the WRT54GS; do the same with the desktop (use another LAN cable). The LinkSys for the moment need not be connected to the Westell. So in effect you have 2 units connected to the WRT54GS. Do a hard reset on the WRT54GS, with the power on, press on the small reset button at the rear of the unit. Allow it to reinitialize. Open browsers to both laptop and desktop. Type "", password is "admin" and the username is blank, verify that you can open the LinkSys Web Configuration Utility. On either the laptop or the PC desktop (assuming both can access the same page), on the setup page of the LinkSys Config, change your Internet Connection Type to "Static IP",
Internet IP Address
Subnet mask:
Default Gateway:
DNS servers: &
Scroll down to Network Setup,
Change IP Address to
Subnet mask:
Disable the DHCP Server (You can have at any given time only 1 instance of a DHCP server, either from the LinkSys or the Westell, but you can also have NO DHCP server if you are using static addresses.)
Click on Save Settings at the bottom, exit, and close. Verify that the LinkSys can be accessed from any of your browsers by typing "", if no; go through the procedure again very carefully. If yes, proceed to change the Default Gateway of both the laptop and desktop PC from to, all other configurations stand.
In your laptop, right click on the WiFi networking icon (bottom right of System Tray). Click on Status, click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right):
IP address:
Subnet mask:
Default Gateway:
DNS servers: &
Verify that you can access/connect/ping 192.168.3; 192.168.4;; and/or from either the laptop or desktop.
If yes, we can now connect the LinkSys WRT54GS to the Westell 6100. Remove the LAN cable attached to your laptop. Verify that you can still access/connect/ping 192.168.3; 192.168.4;; and/or from the laptop even without the LAN cable since you are now connected via WiFi.
If yes, connect that LAN cable to the Westell 6100 LAN port, move the other end from 1 of the WRT54GS ‘ 4 LAN ports to the WAN likewise at the rear of the LinkSys.
Verify that you can access the Internet from either computer. At this moment, you have not assigned a security method (WEP, WPA, MAC Filter). Your choice as to what security you want implemented but offhand I would suggest the simplest, MAC Filter since any other would affect speed of your connection.
Additionally, you may want to enhance you browser connection. In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Normally (and perhaps easier for some) would be using the DHCP and not using static. Experience has shown me that static proves to be more stable especially if WiFi is concerned and in your case, only 2 PCs.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 05, 2007 | Linksys Wireless-G WRT54GS Router...
Microsoft Windows Vista Ultimate Edition Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
