Question about Kenmore 24032\24036 Top Load Washer
Kenmore elite washer24952
The back clips that are wiggle that hold the back panel together fell off how do i put them, back
    Genius:
  • 1,073 Answers
Hold the clip in your hand with the small 90 degree facing up
latch it into the rear panel into the slot that coresponds to the case
pull the rear panel to the case and firmly press down on the clip until it seats in the case hole
repaeat for the other side
Posted on May 20, 2008
I have a Kenmore Elite top washer and was wondering how to lift the top to clean
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have Kenmore Elite top-loading washer that will not agitate or spin. told it is probably the coupling between motor and transmission. can't get control panel off.
5
6
7
Apr 24, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Side vent
5
6
7
Aug 09, 2009 | Kenmore Elite Oasis ST 7806 Dryer
Need to disassemble a kenmore elite oasis dryer
5
6
7
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Removing the top of a Kenmore Elite Oasis Washer to replace hose
5
6
7
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Double cube fell and separated
Use a Flat blade screw driver to take off both grills. Take both speakers out use a phillips screw driver. Put your fingers in the cube with the protruding grommet, turn the object until you see it protruding its maximum. Next align it with the opening in the other cube and press until you here it click back together. re-attach speakers and put grills back on ..Whala!!!
Mar 16, 2009 | Bose Acoustimass 3 IV System
I need to remove the back panel on my top load kenmore washer
5
6
7
Jan 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore gas dryer. 70 series
sound slike something fell down there and is jamming the blower from turning. if the filter is ontop of the unit, remove the 2 phillips located under where the filter pulls out from. and the n remove all the screws on back panel youll see ( down the left side of unit ) the filter houosing, its secured by 3 5/16 screws toward the bottom portion of the housing, simply unscrerw and wiggle out, then remove the debris, and reassemble.
if the lint screen is located inside behind door, eitehr remove the bottom accesss panel or pop the top(with a screw driver approx 3 inches in from ither side of main top relaes the clips) the lid tips back revealing 2 screws holding front panel to the unit, after removing you will see the filter housing, still mounted by probalby 3-4 screws, remove the housing and retrieve the debris that has fallen down there
Apr 05, 2008 | Kenmore 74602 Gas Dryer
SHU 43 Built in-removed door, clips fell out
Those clips will fit into slots on each side of the door frame just above the hinges, Put them back into the frame, then install your new stainless panel. If they fall out b/4 you can get the panel back on, try taping them to the door frame with some masking tape to hold them in place while you secure the stainless panel.
good luck.
Feb 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore 24032\24036 Top Load Washer Logo
59 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
