Question about HP Computers & Internet
My laptop computer wont turn on. I plug everything in press the power buttin but nothing happens. what can i do to fix it?
    Problem Solver:
  • 8 Answers
Check the power cable
Posted on May 20, 2008
Will not turn on
I would remove the power adapter, battery, RAM and hard drive. Press the power button for a few seconds to discharge everything. Plug the adapter back in and press power. If the laptop throws a wobbly and messages appear on the screen, power it off and add the RAM, do it again and the add the hard drive. If it does nothing when all is removed, the motherboard has a fault, otherwise the issue will be apparent as items are added.
Sometimes removing and replacing the RAM and hard drive will fix this problem.
Dec 24, 2013 | HP Compaq nc6230 Notebook
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
Wont power up
The DC jack in the laptop is the most likely trouble, first! remove main battery and power supply from the computer, now press and hold power for 2 minutes to drain off residual voltage, next plug everything back in and attempt startup, if no change! computer must be dismantled down to the motherboard to address.
May 05, 2012 | Acer Aspire One PC Notebook
My Lenovo Y430 having problem after the power was cut off, I can not turn on the laptop, when I press the power button, not thing happen and when I plug the power cord in to my laptop, the power LED is not...
Welcome to Fixya
This could be a problem with the motherboard. Try to do troubleshooting first. If you will be getting the same thing then you need to have the motherboard replaced. Take out the battery then unplugged the power adapter from your computer. Press and hold the pwer button for 30secs without the battery and the adapter unplugged to the computer. Put everything back in then restart the computer. Call our techsupport at 18774536686 then press option 2 if same thing happen.
Thank you for using Fixya!
Nov 24, 2010 | Lenovo 3000 N100 Notebook
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Vaio sat survey has stop working
Do the following:
-unplug adapter from the wall
-unplug from the computer side
-remove the battery
-With everything unplugged and battery removed, press the power button.  Keep holding it down for 15 seconds
Yes, nothing happened, that is ok. :)
-re-insert the battery first
-plug the adapter to laptop side first
-plug adapter to wall socket
Now, turn on the laptop and see if it powers on.
Jun 28, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
It won't Power On at all, all wires hooked up to it.
try to hold down the power buttin for about 45 seconds, if nothing happens, after ensuring all the cables are properly connected and everything is plugged in, I would suggest taking it back to the store you bought it at so you can exchange it for a new one.
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Wont stay on
I suggest removing the battery when plugging it to the wall outlet or are you trying to charge it? I think the one that is spinning is the hard drive reseat it then lets see what happens try to purchase a new hard drive if problem persists. please indicate also the status of the lights on your laptop ill reply with more steps when you've indicated everything
Mar 22, 2007 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
