How to replace the belt on a Samsung J845 front loader washing machine
I need to find out how to replace the belt on a Samsung J845 front loader washing machine.it would be great If anyone has any instructions or even a simple diagram.
Thanks
  • Anonymous Mar 18, 2014
    On any cycle the machine simple flashes red alert button and consequently won't wash. It is a front loader
  • 868 Answers
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
Posted on May 20, 2008
  • joanddave216 Apr 19, 2011
    Our J845 does not have a rear cover plate. The sides and rear are all one sheet. How do I get access to replace a worn belt? It appears I will have to remove the entire outer cover to gain access.
I have Samsung J845 front loader washing machine. The error code bE or 6E is showing up. It won't spin at all and barely drains
Possibly a short circuit to motor or PCB
Requires a competent repair engineer to fix.
Check mains supply
Check main control module
Check main drive motor
Mar 22, 2016 | Samsung Washing Machines
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
Front loader wont spin
Hello there:
It doesn't spin If your washer won't spin, check these: If the motor is running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
May 15, 2010 | Samsung Washing Machines
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
I need a manual for a Samsung 7kg Front loader washing washine model number J845
I googled the make and model of the washing machine and it bought up a site that had manuals that were in PDF form and I printed it from that.
In fact I got the manual for the washing machine, oven and microwave.
Nov 12, 2009 | Samsung Washing Machines
Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Sep 30, 2009 | Samsung Washing Machines
Help remove and replace the diaphragm on my samsung J845
The front loader machine should be done by a appliance dealer because this is a diffuclt job and need a lot of patience if you do it. Hope this might help.
Jun 02, 2009 | Samsung WF337AA Front Load Washer
How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
May 20, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
1,258 people viewed this question
Top Washing Machines Experts
