Question about Hitachi 61SBX59B 61" Rear Projection Television
Jittery picture, jittery picture not, jittery picture, jittery picture not
Hey and good day.. I can't think of a better way to describe the problem than the title. If you close the front door of the house the picture will jitter then settle...........maybe, then sometimes it will jitter up and down, the top corners will jiggle in.. But never does it go black. It is as though the picture looses configuration and then snaps back. Tap on the side of the TV and most the time the jittery picture will react to the tap. If left alone usually the picture will settle in to hours of operation without any jitter. Sometimes jitter every now and then. When it is jittering if you lightly tap on the bottom it is affected generally double as much as tapping the upper side. So sometimes it jitters a couple times and stops, other times it jitters for minutes and minutes and eventually stops.
When a friend plugged in his PS2-3 to the front input, the sound from guitar hero the picture was affected so much by the game noise that we had to patch the sound directly to the receiver and not use the TV speakers. Anyway it acts mainly as though it is a loose connection. When the TV is cold and turned on fresh it takes a while before it stops jittering and becomes stable.
Is this a connection and/or a component on a specific board that is known for doing this? I figure I can pull it out and solder it or replace the component fairly easily with some good instruction. I know nothing about that part, how it works etc. But if I can find the thing I can get it cut out and get a new one soldered in if it needs to be done. But I need some good and helpful direction.
So is there a place on a board that is known to cause this problem generally. Sure would be nice to find it before it goes completely and/or destroys something else while doing so, not to mention to watch a movie without the jitters would be nice too.... Sure appreciate your time and help. Thank you.. Stringpickin@comcast.net
  • Stringpickin Nov 28, 2013
    This has been a long time ago.. But you know what fixed it.. unplugged the tv from the 110.. I carefully vacuumed the entire board everywhere I could reach and viola', never did it again.. Someone, somewhere told me it could be a build up of dust causing connections to be affected by current passing through the dust and affecting some of the electrical components.. Unreal it worked.. In some of the hard to get places I used canned air to blow it out of the cracks.
  • 10 Answers
SOURCE: Picture flickers when T.V. is tapped on or struck.
sounds very much like a loose connection, i.e. a wire or solder joint, you could have a look around make sure everything is plugged in right, as for the solder joints id advise getting it proffessionally looked at as these rear projection tvs can be a lot of hassle if you slighty knock any of the 3 tubes,
Posted on Feb 26, 2007
ttech
  • 139 Answers
SOURCE: Hitachi 53SWX12B: Sound goes out for a while, then comes back on
Its sound like the Audio ouput Ic has Cicle Breaks around its connections,What will happen while cold it will play Great as Soon as its get up to Operational temp (WARM) The connection expand and you lose sound,You need someone that has Soldering skill to solder the Conns and all will be fine..Good luck my friend Let me Know how it Goes ttech
Posted on Jul 24, 2007
  • 927 Answers
SOURCE: Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Posted on Sep 06, 2008
  • 14 Answers
SOURCE: hitachi 53udx10b no picture have sound
sounds like to be you have a bad solder joints, check solder and make sure the they are still attached.
Posted on Jan 11, 2009
  • 5 Answers
SOURCE: Hitachi 61SDX01B
R43 resister drives the lamps 2.5 ohm 2 watt $.70 cent
located in the center of the center board . same tv i have did same thing
Posted on Jan 19, 2009
How do I buy a compact refridgertor to go on an outside covered deck in Raleigh, NC?
Most compacts will work but I don't think the glass door is a good choice. Think of your house windows. Cold in winter--hot in summer. I would stick with a solid door and on extremely hot days, a fan blowing against it may help. I have a GE on my outdoor patio in PA near the border of WV and it works fine but we don't get as hot as you will. We get a few days close to100 but not a lot.
Mar 12, 2015 | GE Refrigerators
Hey , I have a 1997 t-bird and I need help getting a name for a part , I don't know how to fully describe it , but a part to my door latch broke , and it's keep the door from closing all the way , the only...
It's called the door latch. You can't buy parts for it. You can buy the whole mechanism though. Or get one at a junkyard. A spring or small pin has broken inside of it. I tried to many times to find parts for the inside of these things. No luck.
Nov 03, 2014 | Cars & Trucks
Screen rolls and is jittery
If you have room to install extra memeory, do so and see what happens. If you still have the same problem, it could be that your video card is defective.
Dec 17, 2013 | HP Pavilion dv9820US PC Notebook
Instructions for Global TC2204, not for what I have
no offense but this 'house door' issue might get a better solution in that category unless we are talking about a computer back door
my solution is to repost this to another category
Jun 01, 2012 | Computers & Internet
Hey, I keep getting a front door paper jam, and I take out the paper, and everything clears up a goes. It works fine for some prints, but then later it says paper jam check front door. And it is the same...
hi,
make sure the door completly closed
and the relative sensor " actually the botton which control on or off by closing the door"
good luck
gorbesia
Jun 14, 2011 | HP LaserJet 9050 Printer
LN46C630K1F Jittery
THIS LOOKS LIKE A LOGIC BOARD PROBLEM ABOUT 225 DOLLARS
May 31, 2010 | Samsung 460PN 46 in TV
Toshiba 57h82 "jittery" Screen
I had the same issue and i hooked my time warner cable box up and turned it to an hd channel and it comes in perfect so i set the output to only 1080i and now i can view every channel perfect
Feb 24, 2010 | Toshiba 57H82 57" Rear Projection...
No water goes into dishwasher. Dishwasher has only been used 2times. Came new with house 3.6 years ago. Pulled front panel off...everything appears to be connected motor fan runs.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
Jan 04, 2010 | GE Nautilus 24" Built-in Dishwasher
My top freezer door pops open when you close the bottom door
Good day,
If leveled properly, with ideal being a slight tilt to the rear,
The problem is usually weak magnets in the door gasket.
If you are going to replace the gasket, when purchasing it at an appliance parts house, they should advise you on the proper procedure for installing it.
Follow the procedure exactly as described. IMPORTANT !!
Nov 28, 2009 | GE Refrigerators
Hitachi 61SBX59B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
