Question about Panasonic PT-AE900U Multimedia Projector
Projector restarts after 30 minutes or so
I have been putting up with a grinding fan noise in my projector for some time. Recently the projector has started to restart in a 30 minute cycle. The time is not exact, but it seems to be within 20 to 30. After that the bulb shuts of and restarts, then after 20 to 30, here we go again.
The lamp has only 1300 hours on it and I run it in econo mode at all times.
  • M diwan Sep 06, 2008
    I have a PT LB50 ea as soon as I start the projector the panasonic logo comes clean for 3 seconds and then it shuts off and does not start again for atleast 5 minutes. Please help me with this thanks.
    Problem Solver:
  • 11 Answers
Try avalontc.com for repair. they are reasonable.
Posted on Aug 06, 2008
  • 563 Answers
Hi jamble77
This sounds like a faulty Ballast ( lamp's powersupply ) if it made a grinding noise and now the Projector shuts on and off intermittently.
I would advise you to rather have the part replaced than repaired , as in most cases the Ballast almost always returns with the same problem if repaired a couple of months down the line.
Posted on May 20, 2008
Dell 5100mp projector fan is quiet when doing presentations on table top, but makes noise when ceiling mounted for home theatre. Noise get better after 20-30 minutes, but is just as noisy next time i...
turn it on when sitting on a table right side up. If possible, take the cover off and support carefully nearby the unit. Then slowly rotate the unit upside down and notice when the noise starts to get worse. Have a look at the fan area and see if there is anything that's causing the fan to make a worse noise. perhaps the bearings are getting worn out or something's not as titgh and vibration is being amplified by the fan unit.
Jun 07, 2011 | Dell 5100MP Multimedia Projector
I have an Infocus IN2102EP projector. It was shutting down after several minutes of use. I contacted InFocus support and they advised to change the bulb. I've changed the bulb and reset the bulb hours. ...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 04, 2011 | InFocus In2102 Projector
Nec VT 670 It overheats after 30 minutes of use. This is when the fan is on auto. Appears to be OK on man full fan speed. The room temperature is OK and the bulb life has 96% left. Any solutions. The...
hi,
Check the lamp cooling fan of your projector one more time. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 27, 2011 | NEC VT670 LCD Projector
In Focus Ask Proxima M2+ has a squeaking noise and the image flickers. After about 30 minutes the unit goes to standby.
Bearing on the fan is probably shot, causing the unit to heat up and shut down. Repair would more than likely exceed the replacement value of the projector.
Mar 14, 2011 | InFocus ASK Proxima M2+ Multimedia...
My projector will run for a time between 20 minutes and 2 hours and then it shuts down. It will start right back up (takes 3-5 minutes for it to cool and then restart) after that. What could be wrong?
It could be overheating. Can you hear a fan running? Does the projector feel hot to the touch?
Try putting a small house fan on it to cool it and see if that helps.
Jul 13, 2009 | Casio XJ-360 Multimedia Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
I have a Hitachi PJTX100.....been using it for a year and a half and it has been flawless.....until recently....After about 30 minutes of use it shuts off....meaning the screen goes black and the actual...
i believe your problem is heat the bulb is getting hot and the air or fan is not working properly so when it hits temp it automatically shuts off check your fan air flow filters etc
Jan 10, 2009 | Hitachi PJTX100 Multimedia Projector
Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
Dec 15, 2008 | Sanyo PLC-SW30 Multimedia Projector
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
371 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
