Question about Kenmore 44072 Front Load Washer
Kenmore front load washer
My kenmore washer suddenly starts making a loud noise.i tried to run it with less of a load but still making that loud noise.i checked the belt,motor & it looks ok.i am thinking of it maybe out of balance.any help on how to fix this problem.
thanks,
rommel
  • 2 more comments
  • laloandjacki May 25, 2008
    My washer only make it during the spin cylcle its really loud I could here it from my bedroom and my waher is in the garage. it sheakes so much it moves the washer all the way until it hits the wall.
  • Tappanzee May 27, 2008
    I have a loud noise during the spin cycle as if the drum is loose or off line.
    Please advise?
  • jozzz Jul 24, 2008
    Mine has the model# 417.41142000
    Noise description: loud, grinding, continuous when spinning. Upon hand rotating,
    it's smooth if little force is used sideway, but starts to make noise
    when the cylinder is slightly off the axis.
    I read about a "flash recall" on the bearing but when I called the recall #(800-659-7026), I was told there's no recall. Well, I think there should be after reading so many reports online on this problem.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Describe the noise you are hearing. Does the washer make the noise continuously? Does it only do it during the spin cycle? If you are talking about a loud rumble noise during the spin cycle, you may have a rear tub bearing that has gone bad. Please post back and describe the problem a little more in depth, so I can diagnose it correctly.
I had the same problem and it went on few months. Then the final spin didn't work and I could smell something buring. Called AHS and they sent a tech, who said it was the bearing. Cost about $350. to fix. Will be replacing the washer soon, I don't think we paid too much more than this at the scratch and dent place.
Posted on Sep 06, 2008
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
Posted on Aug 30, 2008
My washer started making a loud noise and won't drain or spin.
What brand of washer? Does it have a drive belt? If it doesn't have a drive belt. If it sounds like the motor is running, it has a coupler between the motor and the transmission. Very inexpensive and easy to change.
/uploads/images/8_19_2014_4_37_02_pm.jpg
/uploads/images/8_19_2014_4_40_36_pm.jpg
Aug 12, 2014 | Maytag Centennial Top Load Washer
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
Jun 12, 2014 | LG WM-1832C Front Load Washer
Started making loud noise during spin cycle and then stopped running
May be loose brushes in motor, belt come off or bearing collapsed
May 09, 2012 | Kenmore 24032\24036 Top Load Washer
When washer spins it makes a loud banging noise, washer is a front load kenmore
Thanks for choosing FixYa and welcome. Anytime loud noises are heard, it can almost always be traced back to the drive motor. That is what controls the spinning. Check that and the spin bearing. One of these two are probably your problem. Make sure the washer is level though. Check the suspension.
Apr 30, 2011 | Kenmore Washing Machines
Washer makes loud noise during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 31, 2010 | Kenmore 4292x Front Load Washer
Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Feb 22, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore model-c45072 will not start ant cycle and make a loud buzing noise (like electric noise)
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 43142 Front Load Washer
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Kenmore 44072 Front Load Washer Logo
761 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
