Epson RX500 waste pad replacement instructions
I have an EPSON Stylus Photo RX500 printer and the ink waste pads need to be replaced. I already reset the counter that tripped past its limit, but now I have to replace the pads. I ordered and have new waste pads, but don't have any intructions on how to install them. Do you know if this is a difficult process that I can perform myself or should I take it in to a service dealer? Are there any intructions available anywhere?
Thanks,
Gary
  • mserafinwozn Dec 18, 2008
    What were the part numbers on those pads?
  • Gary Beeg Dec 30, 2008
    I bought my replacement pads through compassmicro.com. If you go to their website, select "new parts" on the right side menu, select "all-in-ones" for the RX500 printer, then select the "Stylus Photo RX500" printer. Since they didn't list the pads, I e-mailed them and explained that I needed replacement pads and they said that I needed the following part numbers:
    The pads that need to be replaced are reference numbers 553-556. Below are the Epson part numbers, descriptions, and the Epson list prices:
    1267934 porous pad, ink eject, lower right $2.46
    1267935 porous pad, ink eject, upper right $3.00
    1267936 porous pad, ink eject, lower left $1.72
    1267937 porous pad, ink eject, upper left $1.72
    It cost and additional $10 for shipping & handling. I got the pads, but I haven't taken the time to replace them yet since it looked rather complicated. It has been 7 months since I had to reset my counter and it is still printing fine, but I imagine that the pad will get over saturated at some point.
It's quite complex, but the instructions can be found (for a price) here:
http://www.2manuals.com/product_info.php?products_id=638
I bought the instructions, but can't find a source of the pads. I am trying to clean my old ones, but they are pretty filthy. Please let me know where you got yours. Thanks. Rob.
rob.bigsby@sbcglobal.net
Posted on Dec 28, 2008
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
http://www.ssclg.com/epsone.shtml
http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
Jan 09, 2013 | Epson Stylus C67 Photo Printer
Replacing waste ink pads on epson rx685
Actually it will very hard for you to access the ink pads for it was designed to be only touched by their service center. I would pressume your printer is giving you errors on waste ink pads full? Try this to reset the counter and be able to use your printer again..
http://fix-your-printer.blogspot.com/2010/04/how-to-reset-epson-stylus-photo-rx690.html
Sep 25, 2012 | Epson Stylus Multifunction Inkjet Printer/...
My epson 700w has a message that ink pads are needing replaced and to contact epson. The printer has not been used a lot and I don't know who to contact to sort out the issue
you need to reset yung printer but first you need to replace the waste ink pad inside the printer. or put a wastebin outside the printer.
here's the instruction and the resetter to reset your printer
http://pcmediks.blogspot.com/2010/09/epson-photo-tx700w-resetter.html
Dec 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus photo rx685 the problem is, waste ink pad in the printer is saturated, I have removed all the wested ink in the priter, but is the same problem that am experiencing. Please help me solve this...
go to www.octoinkjet.co.uk/wib/ to download one of their inkjet ink pad reset utilities. It may just solve your problem. I couldn't clean or replace the ink pads on my epson RX700, so I bought their special adaptor kit. It solved the problem for me. If you already have cleaned the ink pads, maybe you can just download the reset utility. I hope it works for you.
Jul 07, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Printer sending message
Waste ink tank/pads getting full.
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need to actually get a SERVICE MANUAL, to refer to that removal procedure.
You may want to try doing a general search on the "Fixyourownprinter.com" printer repair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.
Jun 22, 2009 | Epson Office Equipment & Supplies
Stylus Photo 1400 Ink Pad Replacement
Hi, if you change wast ink pads it will cost too much.
The best way to resolve this matter is Do it by your self.
You can purcahse wast ink bottle from us then use EPSON reset software to reset wastink pads.
After this done your printer will back to normal.
If you require more information related this issue you can email us free of charge
service@rextras.com
Kind Regards
May 15, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
May 12, 2009 | Epson Stylus Photo 1400 Printer
Epson Rx500 waste ink collection pads cleaning/renewal......can this be done DIY If so can you advise with detailed method etc Regards Tibbs
The same instructions available all over the internet for the R300 should suffice for the RX500...
In terms of resetting the waste ink counter, the SSC utility will provide the necessary compatibility as well...
Apr 13, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
2,857 people viewed this question
jasbo
jasbo
