Question about Kenmore 24 in. 15953 Built-in Dishwasher
Heating element broken, water leaking
The heating element in our Kenmore Elite 15953 dishwasher broke tonight.  We noticed b/c water started leaking from the kitchen thru the basement ceiling.  The heating element looks like it's snapped through in an area not attached to anything.  It had been looking rusty.  Is the heating element easy to repair ourselves?  Is there more to the problem than just the heating element?
  • kadekole Jan 06, 2009
    cannot find heating element for this dishwasher, please help!
  • 868 Answers
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
Posted on May 20, 2008
Why does the heating element in my Kenmore elite look like it has a white film on it?
hard water. test water hardness, clean out with 8oz of CLR. and run affresh once a month for maint. ALWAYS RUN A FLUSH CYCLE AFTER ANY CHEMICAL
Oct 02, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Our Kenmore elite dryer has no heat, what do I do?
The First thing I would do is look at the heating element, you must unplug the dryer and remove the screwsfrom the back of the dryer and then locate the element and inspect it for being broke, if any of the coil of the element is broken you must order a new element.
Jul 18, 2011 | Kenmore Elite HE4 Electric Dryer
How do i stop the light from blinking ove the clean botton on my kenmore elite
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run yourdishwasher as normal. If this same light appears again then you have a bad element or thermostat.
Please take a second to rate your experience. Feel free to repost again if you have more questions.
Have a great day!
Dec 10, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean cycle light is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 22, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
It doesn't start and clean light flashes Kenmore Elite dishwasher water supply is turned on overfill protection float is able to move up and down freely there are no sudes in dishwasher soap dispenser...
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Jun 07, 2010 | Dishwashers
We have a Kenmore Elite 665.15953; the display shows 2 dashes, most of the time the "Quick Rense" button blinks.
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 17, 2009 | Kenmore 24 in. 15953 Built-in Dishwasher
Kenmore Elite Dishwasher not cleaning well
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
45jdgyhj
Jun 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
May 24, 2009 | Kenmore Dishwashers
Kenmore 24 in. 15953 Built-in Dishwasher Logo
352 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
