Question about Canon Cameras
I have a new Canon PowerShot A570 IS and can't figure out how to get the Time and Date to show. When I go to menu and come to the time & date (That says Off) it skips past It wont light up so I can put it on.
  • 2,039 Answers
In order to embed the date in the photo, the camera has to be in the "Postcard" mode. That's on the same menu as the picture size -- L, M1, M2, M3, S, Postcard. Once set for Postcard mode, the date/time can be turned on.
Posted on May 20, 2008
Set date time
Press the MENU button, select Setup (hammer-and-wrench icon), then select "Date/Time."
Oct 03, 2013 | Canon PowerShot A570 IS Digital Camera
Any solution to the battery problem? Low indicator comes on WAY too soon! Canon A570
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Aug 14, 2010 | Canon PowerShot A570 IS Digital Camera
Can not seem to set date to appear on my Canon PowerShot A610 - is it possible? in menu Date Stamp is grayed out
If the current date & time is not set in the root menu, the T&D stamp feature isn't available.
Check your quality settings as well.
My Canon won't allow stamping on portrait-quality prints, or hi-speed settings.
Jul 07, 2010 | Canon PowerShot A75 Digital Camera
Canon Powershot A570 keeps showing change the batteries
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
Date stamp on photos option is not getting enable in my camera, how to make it enable.
In the <REC> menu, its an option called <Date Stamp>. You need to toggle it to <ON>.
Note that when its on, it permanently etches the date into the picture, so you need to make sure your time and date are set correctly.
Page 33 of the manual explains it (with pictures)
You can download the manual free from here:
http://safemanuals.com/annexe_POWERSHOT%2020A570%2020IS%2020CAMERA%2020USER%2020GUIDE%2020ADVANCED_CANON_POWERSHOT%20A570%20IS-_E.htm
Hope this helps
Mar 01, 2010 | Canon PowerShot A570 IS Digital Camera
How do i turn on the date stamp on my Canon Powershot SD750 so that the date prints on all my pictures?
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Jan 31, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The date will be printed on your images even if it has not been set at the computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
Jul 27, 2009 | Canon PowerShot A640 Digital Camera
Date/TIme Screen ALWAYS appears when camera turned on.
You need to replace the lithium date/time battery. It is a CR1220 coin cell and it's replacement can be done using the instructions on page 109 of the advanced guide. If you don't have a copy you can get one here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=221&modelid=14905#DownloadDetailAct
Hope this helps, if it does please rate my solution.
Nov 16, 2008 | Canon PowerShot A520 Digital Camera
Need help
go to function and change pic size to wide or it shows a w -then you will see in main menu highlight of time and date stamp-canon can only do date and/or time in a certain size pic-rember it's a lower quality resolution than normal-change pic size first at bottom of function menu then go to main menu
Jun 09, 2008 | Canon PowerShot A560 Digital Camera
My PowerShot A570 stop adding the date/time stamp on each shot. Followed the directions and the selected menu won't let me enable it. It used to work. Does the internal battery (not the AA batteries)...
According to page 33 of the manual, the date/time stamp can only be embedded in the image in the Postcard mode. Set the image size (L, M1, M2, M3, S, Postcard) to Postcard.
May 14, 2008 | Canon Cameras
Cameras Logo
253 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
