Question about Refrigerators
Rubber door gaskets get very warm to touch - Refrigerators
  • Anonymous Mar 21, 2009
    where can I get the rubber magnetic band of a kitcenaid old refrigerator
  • 868 Answers
There supposed to.Dont worry ,its a normal thing and will cycle on & off.You may have a switch inside that will say on it "to reduce moisture ".
Posted on May 20, 2008
Door not creating suction when door closes
the door may need adjusting
cut an place a strip of paper between the seal and the fridge and close the door
if the paper pulls out easily then the seal is not touching fridge
The suction is created when the warm air from the room that gets into the fridge when the door is opened is cooled down and occupies less space hence the lower pressure and the vacuum forms
May 12, 2016 | Refrigerators
I changed the gasket but it does not have a tight door close. it closes but it very light to the touch close
You have to form the door gasket. That means you have to use a heat gun (please don't use the heat gun if you are not familiar) to form the gasket to the seating surface. You can use a hair dryer which is less heat intensive. You got to be very careful, since too much heat is going to burn out your gasket and has to buy another one.
This is what you do.... Where the gasket is not seating properly to surface..... Those areas in the gasket you slightly heat up and let the rubber heat up and close the door. So the heated rubber will form into the shape of the seating surface.
Please check some YOU TUBE video's on this before doing. Otherwise you might burn out the gasket and will have to buy a new one again.
Oct 13, 2014 | Sub-Zero Refrigerators
A bad smell (like a chemical) was coming from the frig but it was still working fine. Repairman couldn't find anything - other than saying it smelled like burnt wiring. Then a few days later, the...
There is a stile heater around the door opening and sounds like it shorted out. This would be the smell you noticed. The plastic door trim should have felt exceptionally warm to the touch
Aug 01, 2011 | Turbo Air MSR-49NM Refrigerator Commercial
Hot on middle bar between doors. Both rubber gaskets are hot too. seems to be working but running hard and making noise. Its making ice and water.
Hello, Thank You for using FixYa. I will be helping you today.If it is hot to the touch it is either because the condenser fan failed or the condenser is dirty.Check the fan in back of the unit make sure it runs when the compressor is on. If it doesn't run with the compressor replace it. If it does then you need to clean the back vents in the cardboard and under the front of the unit. One of these will correct your issue. This area should be warm at times just not hot. It prevents moisture.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | KitchenAid KSCS25FKSS Side by Side...
Water leaks from door during last cycle
Sometimes residue builds up between the gasket ( rubber on the back of the door ) and the unit itself. With the door open clean the inside of the washer where the door touches it when closed, clean the gasket too.
When dishwashers aren't run frequently the gaskets can dryout and shrink, this creates a gap in the gasket and allows it to leak. New gaskets are available from your dishwasher manufacturer.
Dec 30, 2010 | Estate 24 in. TUD6700KQ / TUD6700KT /...
We have mildew in the rubber gasket behind the front door
use a good mildew cleaner on gasket the gasket gets wet from when clothes are taken out and drip on gasket mildew grows on damp/warm surfaces
Sep 26, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Replace seal
Take the door off. You will find a 1/4" screw every 3" to 5" all the way around the door. Remove every one of them. It amy take a couple trips around to get all of them. Before you attempt to install the gasket, soak it in hot water for about an hour (while you are removing the old gasket). This will soften the rubber so that you can work with it. After you have replaced the gasket and re-installed the door. Take a rag soaked in hot water and wipe it slowly around the gasket. This will warm it again. Now take Vaseline and smear a small amount all around the gasket. Close the door and let sit for 15 to 20 mins. Now take a dollar bill, open the door and close it on the bill so that a end of the bill is sticking out. Now pull the bill out slowly. The gasket should have a snug grip on the dollar. If not re-heat it then close the door so that the magnet will pull and stretch the gasket until it touches the box. Do this all around the door to insure that the rubber of the gasket has expanded and allowed the magnet to reach the fridge case. If you take your time, you should have no problem. Good luck
Please rate solution
Sep 07, 2009 | Candy CPCA270FFK Bottom Freezer...
Door gasket icing
Icing is caused by warm, moist air hitting cold air. Either your gasket is not properly sealing to the frame or the door frame heater is either off or not working. Some units have an off/on switch for that. The heater is usually referred to as an "Anti Sweat" heater. Make sure the door is closing and sealing. The door frame should be slightly warm to the touch. If not, look for no power to the heater or the heater could be damaged/ burned out.
Good luck and hope this helps,.
Mar 21, 2009 | Freezers
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Rubber door gaskets very warm to touch, ice cream soft, ice ok
the icemaker will work until the frezer gets to 17 then it will quit sound like a defrost issue defrost heater defrost thermastat or defrost timer need to get it fixed sooooooon you dont want to loose food at the price we have to pay
May 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
