Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel (mw511)
My Fisher & Paykel MW511 will not drain once it finishes its wash cycle. is there a solution?
  • 2 more comments
  • judeletele Jun 05, 2008
    Cheers mate, sorry for the late comment. You saved me many dollars. My partners necklace was caught in the pump. Thank you
  • jakes mom Jun 08, 2008
    My washer beeped in the draind cycle and noe won't empty.
    I kep trying to restart it but it won't do anything in the spin cycle. RIght now its full of water we took the clothes out. I am trying to get my children ready for camp and need the washer..help
  • Anonymous Mar 12, 2014
    FISHER AND PAYKEL STUCK ON DRAIN CYCLE
  • Anonymous Mar 20, 2014
    loud whirring in wash cycle
    New Friend:
  • 3 Answers
I just did this with a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. You could find a coin, cloth, rubber band etc. Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle.
Posted on Sep 08, 2015
  • 975 Answers
Check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
  • Chrissy Watkins
    Chrissy Watkins Sep 08, 2015
    I just did this with a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump, clean it out. You could find a coin, cloth, rubber band etc.
    Put it back together & test if it's pumping out water at the rice cycle by doing a low water wash cycle.
Fisher paykel mw511
take it apart-something has let go in the tub suspension department-springs or bearing-tear it down and it will become apparent-cheers Denny
Oct 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
Need replacement motherboard for Model MW511 fisher & Paykel washing machine
Hi just read your posting.Have you try ed Fisher and Paykel local distributor ?What country are you in?If you are in Australia I can help you with phone numbers.Please reply with additional information and I am sure I can help you out.Looking forward to your reply.
May 20, 2011 | Washing Machines
Need to replace the memory board on: f&p mw511 pride 5.5 washer, where can i purchase this from and how much
Hi just read your posting.What country are you in?Is your control module faulty?Have you checked why the control module became faulty?Please reply for further assistance.Looking forward to your reply.
Sep 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
My MW511 model is not spinning , slow motion wash cycles, noisy
Hi blow down the hose that the waste water comes out of, it may be blocked
Nov 29, 2009 | Fisher and Paykel (IWL12)
Mw511 wont empty water to allow the spin cycle
Could be a belt problem, check the belt first.
Or could be your control switch problem check your belt first as it is the easiest way to go and the cheapest.
Sep 25, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel mw511
temp sensor is bad or dirty with hard water deposits
Feb 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
2,056 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
