Question about Aurora Electronics AS1018CD Shredder
Performance lagging - is lubrication possiable?
My shredder is only a little over a month old. Although I was not there at the time, I suspect my GF over extended the machine's duty cycle. The tool now functions at about half its original speed and does not seem as "hungry" as it once, so impressively, was. Furthermore, after completing a page the shredder used to give brief 'fast-spin' before shutting off. The 'fast-spin' no longer happens.
I have opened the case (warranty be damned) and see nothing obviously wrong. I notice a lot of darkened(?) lubrication on the drive wheels/gears and wonder if I should try, somehow, to refresh the grease.
  • whnixon Nov 22, 2008
    Yes, The Bushing on the gear end of the Motor shaft is Worn Out.
How to lubricate a paper shredder
To lubricate a shredder, use some shredder lubricating oil which can be purchased at stationary shops or online. Get a piece of paper and run a line of the oil across the width of the paper at different heights then run the paper through the shredder, do this a couple of times as this should lubricate the mechanisms and the gear assembly.
Aug 15, 2014 | Office Equipment & Supplies
Tip
Oiling a Shredder
Oiling your shredder maintains optimal performance. You should oil your shredder every time you empty the waste bin.
on Feb 04, 2015 | Fellowes Powershred Shredder Oil &...
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
THE BLADES ARE FULL OF PAPER. SHOULD I TAKE IT APART AND ATTEMPT TO CLEAN IT?
In order to maintain a functional paper shredder, you should clean it out and oil it at least once a month(depending on usage) if not every time you fill it.
I would advise against trying to disassemble the actual blades to clean them out if that's what you mean by "take it apart."
What you can do is unplug the machine, lay the blades up and get a pair of tweezers and remove any large pieces of paper/shredding that might be caught in there.
After doing that you should oil the blades with any lubricant that your owner's manual recommends.
Most shredders suggest a non-aerosol/biodegradable oil such as vegetable oil.
Do not use WD-40 or other canned spray lubricants.
I've found that dripping the oil straight into the blades can be very messy so a good alternative is to lay out a piece or two of scrap paper and soak it in the oil. Then run the paper through the blades as normal.
They also sell varieties of this here: http://www.staples.com/Staples-Shredder-Lubricant-Sheets-12-pk-Shredder-Sheets/product_602400
It doesn't have to be a headache to maintain but proper care can make your shredder last a long time.
Jan 18, 2013 | Royal Sc120 Shredder
I have a novitech shedder. The motor works but it will not shred?
It is probably a gear that is not longer connecting or is worn so will not turn the teeth. It is a little known fact that shredders need to be lubricated at least annually as the fine paper begins to clog the teeth over time and can over-work the motor.
Solution if this is the case - purchase a new shredder and some lubrication.
Oct 27, 2012 | Fellowes Office Equipment & Supplies
I have the CX6 shredder, the paper get jammed in the feed,can i oil the feed?
How to Oil a Paper Shredder shredder_oil.jpg Paper Shredder OilProper shredder maintenance is required by all paper shredder manufacturers to maintain warranty coverage. Perhaps the most effective way to care for your shredder is to oil the cutting heads regularly. Why should I Oil my Paper Shredder?
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Oct 03, 2011 | Office Equipment & Supplies
It makes a loud screeching sound, i think it needs to be lubricated. how do i lubricate it?
Sqirt shredder oil on a piece of paper that you want to shred & feed it through your shredder. Do not soak the paper a little is all you need.
Jan 12, 2011 | Fellowes Powershred C-320C Shredder
Should the shredder ever be oiled? if so...where
Directions
Dec 16, 2010 | Office Equipment & Supplies
Worked well for a long time. Now it makes a very bad noise when I try to feed it a paper, and it doesn't grip the paper. I lubricated the shredding mechanism, and cleaned it thoroughly of scraps of paper....
This sounds a little odd... however, what I would try is to take the top cover off and check that all gears/teeth are ok..( I suspect they are ok but check anyway )..then I would try some lubricant/oil in the "bearings" of the cutting shafts at both ends to see if that helps...with the cover off sometimes it helps in locating exactly where the noise is coming from.
On the off-chance that you have to order a part you can contact Royal at 1-800-524-0799.
Dec 14, 2010 | Royal VF1012mx Shredder
How do I lubricate a Aurora AS702MX shredder?
two ways, first take a light oil (3 in 1) and scribble a pattern on a piece of paper and pass it through the cutting heads do this a couple of times, this can be done as you shred just put a little oil on papers you are about to shred from time to time.
second, if it is a light duty machine, with plastic parts, then pass some waxed paper through the shredder to clean and lube the heads, this also works for your 3 hole punches.
Apr 12, 2009 | Aurora Global AS702MX Shredder
Aurora Electronics AS1018CD Shredder Logo
175 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
