Question about Sony KP-46V35 TV
Blinking standby light and nothing else...
I just got this thing from a friend and I'm usually good at fixing used tv's but when i hit the power button the standby light just blinks untill i turn it back off.....nothing else happens...at all..but it must work or that wouldn't happen..it's like it has a lock on it or something...
If you know what to do hit me back at ISmackPimps@GMail.com
  • xj1514 Nov 03, 2008
    kp46v15 model. Turn power on and I get a blinking standby light, once every second. What does this mean?
  • Anonymous Feb 11, 2009
    the light just blinkes non stop, wat could this mean?
    JH_scottsbluff_NE
    also i was told that it may have bean the overload. upon hearing this i opened up the tv and found a part with what seemed to b a button, and i pushed it in. after doing so the tv turned back on, the tv then stoped working 4 days later. i have sum #'s off the part and im hoping to find a place i can order it from. the numbers are(8-598-965-51)(6k21)(10-62)plz hep
  • 4,234 Answers
When Sony TVs detect a problem, they shutdown and present a blink code. The blinking should be a repeated count. Please report that count here as that indicates the circuit in which the problem was detected.
Thanks,
Dan
Posted on May 20, 2008
Jmatejicka@When plugget in red light show but nothing else.Tried the power button,nothing,same whit using remote.
Modern tv's have power supplys that shut down on standby when faults appear , often its capacitors in power supply that fail, they usually go like batteries and leak. You can sometimes spot them ( with a trained eye) they swell up .... but not a repair for the novice.
capacitors are cheap, so i would not expect a large bill for parts
but time for engineer , uplift , bench repair , delivery . vat etc wow £ 100 or more
pete
ps (had same fault with friends tv) I fixed it for £ 20.
Pete
Nov 11, 2010 | Philips Televison & Video
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture, just a red blinking light
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Feb 07, 2010 | RCA Televison & Video
My tv will not turn on
The blinking standby light is an indicator that an internal safety circuit has kicked in. The light shouldbe blinking a repeated pattern of count/pause/count etc. Can you please post the count here? That will indicate the problem circuit and allow us to provide you with the solution.
Thanks,
Dan
Nov 01, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light keeps blinking. tv wont turn on
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
May 07, 2009 | Televison & Video
Blinking power light
This set has a power supply and signal PCB. Since the indicator light is blinking, I would consider the problem to be a missing voltage from the power supply. Unplugging the set for a couple minutes may solve the problem. If not the set may still be under warranty. Contact LG (800) 243-0000 for a servicer in your area. Hope this helps.
Apr 28, 2007 | LG DU-37LZ30 37 in. LCD HDTV
Televison & Video Logo
204 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
