Question about Lands Phones
GE 900mhz model 26936GE2-C
I get no link to base when I try to use the handset.When I first remove from base,I get readythen when I push talk button,I get no link to base-Also no dial tone on handset---Base works good. I also have GE phone model GE 26936GE1-C and cannot get the base to link with the handset. I have changed the battery, re-booted the phone. Tried every button on the darn thing and UGH not a thing. Can you help please.
Thanks!!
  • 1 more comment
  • KENTEXXX Jul 08, 2008
    THE BASE AN HANSET WORKS. BUT WHEN I TRY TO DIAL GIVEME THE MESSAGE OF NO LINK TO BASE.
    I TEST THE POWER SUPPLY AND THIS GIVE ME 18 V INSTEAD OF 12 V-. SO I HOPE THE SOLUCION IS RIGHT THERE, REPLACE THE POWER SUPPLY AND HOPE THAT NOTHIG IS BROKEN INSIDE THERE.
  • robbie_tang Sep 02, 2008
    Thanks!!
  • Anonymous Apr 20, 2009
    I have the same problem with a GE 900mhz 26936GE2-B phone.
    No dial tone when removed from base. If I try to dial I get "No Link to Base". On the base, there is a small number 3 in the bottom right corner of the display. Any thoughts?
HI NEED HELP MY PHONE IS SAY NO LINK TO BASE
Posted on Jul 03, 2008
GE Cordless Phone No Link to base model 26936GE2-C
remove power in both phone and base and retry connecting. place phone in base for registering.
Regards
Mar 23, 2010 | GE Lands Phones
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
I have a GE cord and cordless speaker model: 26955-GE 900mhz phone which i have had for eight year and I would like to add another cordless phone which GE phone is compatible to what I'm currently using....
If you mean you'd like to add another handset to the base unit on this phone, I'm afraid you can't. This isn't a multi-handset phone and isn't expandable. If you want the kind of system that has the main base unit and several separate handsets, you'll have to start fresh with a new system. They aren't expensive.
Mar 09, 2010 | GEH5450 Cordless Phone
Unable to talk on two handsets at same time when receiving a call
Unfortunately that is the untold story about cordless phones they only have the capability of 1 open line be it the handset or or the base. There are some very pricey multi line systems, I have the same system bought two extra handsets and found out too late that I can only use them one at a time! Sorry probably not the answer you were looking for but thats the reality...
May 22, 2009 | GE 25942GE2 Cordless Phone System
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Sounds like a defective battery or low battery.
1. Have you replaced the battery?
2. Have you changed the channel?
3. Have you dropped it?
Answer these few questions and we'll see if we can figure it out.
Let me know.
Feb 18, 2008 | Xact Communication XG2200 Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Base set fine - additional handsets dont work
The additional handset and the base need to "pair" first. Put the handset in the base cradle till you see the red light blinking. That's when they are paired.
Nov 07, 2007 | GE 25951EE2 Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
1,435 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
