Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS-55809 Color
The color red no longer works
  • Mitsubishi Master
  • 8,617 Answers
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
Posted on May 20, 2008
My Mitsubishi ws-55809 works fine although the screen turn pink but the picture is still visible. After a while it goes back to perfect color. Then it repeats this back and forth. Sometimes it will fl
Problem is likely on the small circuit board that plugs onto the bottom of the red picture tube---be careful as dangerous voltages in and around that board---each of the three picture tubes has a small board that plugs on the end of the tube.
Oct 21, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Ws 55809 color
So you are still haveing the convergence issue with your tv, the convergence ic chips need to be replaced to correct this problem you can't adjust it as the components are failing.
Aug 19, 2008 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi ws-55809 works fine but the screen turns pink and after a while it goes back to perfect color. Does this back and forth
Someone with moderate experience would have to examine the red crt printed circuit board--I have seen some of these that develop a cracked ground path on that board but usually it is pink except on the sides depending which ground path is bad.
Tv is 10 years old, the red drifts to the right and some times reverts back to normal its a Mitsubishi 1080 55" Rear Projection WS-55809, I found this...
The Tvrepairkits.com to buy a convergence kit,will fix ur red color line or color shadow pictures drifts problems.But u must have tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders,also can u do basic soldering skills work,than u can fix this problems.Yes,the new tv design have Energy Star incorporated in it design and will save u energy and some money,but the power consuption of a big screen tv any century era,still will cost u alot of money to operate it.
Dec 04, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Color changing while viewing
Sounds like your TV needs new convergence chips.
Go to this web site.
http://www.tvrepairkits.com/xcart/home.php?cat=2653
If you can handle a soldering iron and solder fairly well, then you can do the repair.
Hope this helps.
Apr 03, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Distorted picture and multi-color words
ive got the same problem on mine ita a 2001 model and also mine when you turn it on it goes off by itself and wont stay on.also mine has multiple pictures one green and one red almost as if 3d im not sure what it cost to fix it but tvs have come down so much i might just buy a new one. good luck with yours
Aug 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
TV shuts off with high color images . Example: explosions,bright lights etc
Normally, the screen control being up a little to high, would cause this problem. If no one has worked on this unit when it started may be a sign of something else, for example, the 200 volt line may be running a little low. Check the brightness and contrast for starters and if that doesn't help, then, the screen control would be my next step. Hope this helps.
Jun 03, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
