Question about Krups Burr Coffee Grinder
Burr grinder GVX212
My grinder stopped working entirely when I was out of town. Housesitter pleads innocent. I do not get any blue light, motor sound or grinding action when I press the button. I have tried it in several different outlets, on several different settings. Took out the grinder mechanism and cleaned all the grounds off of it and reseated it, all to no avail. Please help! I am using a blade grinder now, and it is driving me crazy!
  • soy-dog Oct 31, 2008
    I have the same problem.. LIke there is no power to the unit?
I had the same problem, took it all apart, separated the two halves, and looked into the guts of the machine, not an easy task. Fiddled with this and that, and looked at the back of the switch mechanism, and heard it making a 'click' when depressed, so put it all back together, to no avail...It turns out the grinder needs to have two limit switches engaged, one between the lid of the ground coffee hopper and the underside of the grinder hopper housing, and the other between the grinder lid and the base of the unit. This last limit switch was my problem, it seems the lid wasn't making contact with the limit switch, so the unit didn't run. I cleaned out the narrow gap that the grinder lid sits within, pressed the lid down until I heard a small 'click' , pressed the on switch, and presto! it works. You can see this very tiny switch if you take off the grinder lid, and look in the narrow gap it sits in at a position of about three o'clock ( the back of the machine when viewed from the top being 12 o'clock. Hope this helps anyone else who can't find their receipt within the one year warranty period. This is the best burr grinder I've found for the money, and I'm glad mine's still o.k.
Posted on Feb 06, 2009
There are two safety switchs that need to be seated before the grinder will activate: one for the top bean cover and one for the top of the receiving bin. The first is on the right side in the slot where the cover slides down. Sometimes a bean fragment will fall in the slot preventing the plastic lid from pushing the button down. The second is on the roof of the space where the receiving bin slides in. There are two pimples: the left hods the bin in and the right must be pushed up by the lid to allow the grinder switch to activate.
Posted on Dec 10, 2008
After reading the first two solutions, and confirming that the two switches referred to weren't the cause of the grinder no longer operating, the following brought our grinder back to working order; 'unlocking' the grinder part (and removing it), pouring water through, and poking a paper-clip into the opening which feeds the container for the grounds.
Posted on Feb 01, 2010
Krups Grill FDE3
If NO LIGHTS come on and not a single thing operates, I too would say that it's most probably the THERMAL SWITCH, activated when the motor gets too hot and is in danger of damage. A very cheap electronic device, quick and easy to remove and replace.
Mar 10, 2014 | Krups GVX2-12 Electric Burr Grinder
Motor shorting out?
check ur switch better replace the switch
Jun 17, 2008 | Krups Burr Coffee Grinder
GVX2-12 Electric Burr Grinder: blue power light not coming on...
Check all connections and plug then after that it is a short behind the switch and will need to be sent back to the manufacturer.
May 17, 2010 | Krups GVX2-12 Electric Burr Grinder
Non-working Starbuck's Barista burr grinder.
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
The thermal fuse is to protect the motor its a 104C
May 12, 2009 | Starbucks Barista Burr Grinder
Maestro Burr coffee grinder stopped grinding
Hi
Remove bean hopper
Insert a screw driver into the grove and pry gently outward with a
Apr 04, 2009 | Solis Maestro G385 Electric Burr Grinder
Motor revs but grinder does not engage.
I am what you would call an expert when it comes to Baratza repairs.
The problem you are describing is not an unusual one. It sounds like the main drive gear has been stripped due to something foreign (likely a stone) sneaking into your grinder with the beans. It would have jammed the burrs, and because of the powerful torque from the motor, the drive gear has been stripped so it will no longer (or rarely) engage the burrs.
To solve this problem you will need to contact COAG Ltd (if you live in Canada) or Baratza if you are from the US. If you machine is still under warranty (less than a year old) this repair will be free of charge and you shouldn't be parted from your grinder for long.
I hope this helps anyone who stumbles upon this and finds themselves with the same problem.
Kind Regards
Emily
COAG Ltd.
877 477 3849
Aug 25, 2008 | Baratza Virtuoso Electric Grinder
Nemox Lux Burr Grinder
There are a series of gears between the motor and the shaft. Replacement parts are avaialble ad cafeparts.com under ascaso ibertal grinders. You will need to take the grinder apart to find the problem.
Dec 16, 2007 | Nemox X79751250 Electric Burr Grinder
Krups Burr Coffee Grinder Logo
647 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
