Question about Hitachi 53UDX10B 53" Rear Projection Television
Magic Focus does not fix the blue 57UWX20B Hitachi
The magic focus stops when going thru the blue color. What I do I need to do to fix this?
  • 2 more comments
  • jimsell May 22, 2008
    I ordered the parts and are awaiting their arrival. Will let you know after I install them.
  • jimsell May 24, 2008
    I bought the IC's from B&D Enterprises. Their KIT-10 came with 2 STK392-150's and 6 resistors. The hardest part about getting the board out was 3 heavy duty wires that had to be pushed down and turned to get them from their connector. Also there were a couple of jumpers between boards that I had not seen before but the friend that did most of the work just lifted them up from the lright side. We found out that we SHOULD replace the 6 resistors and managed to match them up from the websight wa6ati.com-HIT-DP23. We had the right values from B&D and replaced RK50 2.7 ohms, RK54 1.5 ohms, RK58 3.9 ohms, RK62 2.2 ohms, RK 46 1.8 ohms and RK42 3.3 ohms. After cleaning up any residue from removing the old IC's, he put the heat sink compound on the back of the IC and screwed it into the heatsink after lining up all the leads thru the connector. Then he soldered in the IC's.
    We put the board back into the TV, put all the connectors where they belonged and turned on the TV, hit the magic focus button and everything came into place. The TV is now working like it was brand new.
    Now that I have done it once it seemed so easy, but it took us a couple of hours. Also I was quoted $395 + parts to come fix a convergence problem from a Hitachi recommended repair shop. The parts were $ 47.95 + shipping.
    Thank you all for your suggestion to replace the IC's and the web site for pointing out the resistors.
    Jim
  • RFranky Jan 16, 2009
    I have the same problem, my question is how do you get inside, I have no manual or anything. I have a 57uwx20b
  • eddie villarejo Feb 02, 2009
    i have a hitachi 51uwx20b chassis dp23 i thought the stk393-150 upgrade kit. i replace the two stk and all 6 resistor. still have the same problem the red is out i hit the magic focus botton but nothing anyone have any idea what could be wrong.. thanks eddie
  • Hitachi Master
  • 8,617 Answers
You need to replace the convergence ICs they are STK392-110 you can get replacements at the following link and they send instalation instructions with pictures so you can do the repair yourself. You need to replace both IC they are both STK392-110 they are located on the large heat sink on the far right side of your Tvs' chassis Heres the link for replacement ICs
http://servicemanuals.vstore.ca/
Posted on May 20, 2008
Blue colors no magic focus stop at blue colors
Check the resistor in front and back of Convergence ICs. STK392-110s. the ICs might need to be replaced also. Look for poor solder connections also.
Oct 01, 2012 | Hitachi 46F500 46" Rear Projection...
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
HITACHI 57UWX20B has blue ghost shadows how do I
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 05, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
I have a hitachi ultravision and the blue is off center.
your convergances amps ics have failed and need to be replaced alone with the 2 burnt resistors you will find then run magic focus
Nov 30, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Color Alignment
get a shop manual,it tells how to do the whole convergence process and how to store it to the rom memory to save it.
Mar 15, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
481 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
