Question about Samsung YP-Z5 MP3 Player
Touchpad My touchpad also just stopped scrolling up & down, though everything else works fine. It's 3 years old, so over warranty, but I was trying to figure out how to buy a replacement touch-pad. I'm studying abroad now, so don't want to spend a ton on 1800 numbers, so I was looking for a good place to buy a new touch-pad, or how to order one straight from Samsung.
This touchpad works with the same principle of a PC keyboard or a TV remote control: pushing the touchpad makes a shortcircuit between two electrical paths.
To fix the problem you need to clean the two contact surfaces that are in the bottom of the metallic film (the label where you can see de up and down arrow) and the upper surface of the electical paths (the touchpad chip) because they are dirty and their electrical properties (conductivity in this case)are missed.
Steps to fix this problems:
1. Take off the four tiny screws (two at both sides of your mp3)
2. With a very small screwdriver take apart the back cover of your mp3. Make it gently but firmly the first time it seems hard to separate it, but the back cover do not has anything more to be retained on its position. Before totally separte the back, take notice that: A) The battery is scticked to the back cover and you need to disconnect the cable that connects it to the circuit board. Separate them carlessly will break the connector or the thin cables, it will be very difficult to repair this failure; B) there are two plastic chromed pieces at the upper side of the mp3 (the ring for the strap and a large one rectangular piece that seems to reforce the audio out plug connector. Take notice how this chromed pieces are in place in order to reinstal it again latter. They will pull down because pressure only mantanis them in position.
3. With the back cover pulled apart you can see two more identical screws to the four you retired on step 1, These screws are almos at the midle of the body of the mp3. Take off this two screws.
4. Now you can take off the front cover.
5. Once the front cover is pulled out, you can see the touchpad in it's positon, take off the plastic outher square (the one that has the marks Tun On, Forward, Backward and Return) it's easy to do so.
6. Now you can see clearly the piece that don't works: the touchpad. You need to separate it from the mp3´s body. There is a flex cable that connects the touchpad to the back of the printed circuit, on the circuit board there is a connector that secures this flex cable to the board, don't pull out ,at this moment, the cable...
7. You need to take notice that the connector has two tiny brown and rectangular plastic pieces at the left and the right of the conector. This pieces, when pulled in, secures the flex cable to the connector, and when pulled out release the pressure that secures it and you can take in or take out the flex cable. Don't try to move the secures before read ...
8. With a tiny screwdriver move out (in the same direction of the flex cable) the tiny brown and rectangular pieces no more that one or two milimeters or you can broke them and can't ever make a good electrical contact, you need to be very careful to avoid damage this plastic fragile pieces.
9. Once you move this plastic secures, you can retire the flex cable from the connector, pull out to do this.
10. Now you can retire the touch pad and put it appart of the mp3.
11. With the touchpad on your hand you can see (use a magnifier to see details) that the "metal" area where you push with your fingers to control the options of the mp3 is only a tiny label, and I can tell you that this label is sticked with adhesive to the plastic "chasis" of the touchpad.
12. On one side of the touchpad label you can pull in the tip of a tiny screwdriver in order to separate the metal label of the plastic chasis. Find it and begin to separate this label, the adhesive is not too firm, once you start to see that you can separate it without damage (believe me, is too difficult to damage the metal label by separating it) you can separate totally the label from its site.
13. Once separted the label, you can see that its bottom side has a black square, this square is electrical conductive, its surface has to be clean showing an uniform black color, if you see that has dust or anything else you need to clean it up. To do that, use a pencil´s eraser to rub up the surface. The pencil's eraser has tritured crystals that works like a light sandpaper and cleans all substances that prevents the electrical properties of this black material. Finally use ethyl alcohol or electrical contact cleaner, spray it over the black square and use a tissue to make a trully clean surface (it must have the same black color and looks glossy while you see it against a light source)
14.Now you need to clean the other electrical conductive black surface that reamains in the body of the touchpad. If you pay attention, you can see electrical paths, this paths works the same way like a keyboard or remote control to sense when you touch a key or a button. This black surface needs to be cleanead the same way you did in step 13.
15. If you make a good cleaning process that restores the electical conductivity of both surfaces, the fix is maked, you now have a Samsung´s YP-Z5 mp3 working again. You need to return all unmounted pieces to its position.
16. To mount (stick) the label over the plastic chasis of the touchpad, you don't need another glue, the same that remains in the label, incredibly is reusable. I recommend that before stick up the label mount on its position the plastic square that has the marks of Power On, Back, etc and then stick over the metal label (doing so, makes easy to align the edges).
17. Reconect the flex cable to the circuit board, secure it pull in the brown rectangular plastics of the connector to its original position.
18. Put the front cover of the mp3 on its original position.
19. Restore the two screws in the back of the circuit board, this screws needs that front cover will be on its position in orfer to tighten up.
20. Return the back cover to its position, don't forget the top plastic rectalngular and chromed protector and the ring for the strap.
21. Restore the outher four tiny screws and...
22. Ready, check your mp3. It must works now!
Posted on May 19, 2009
Just had mine in bits, it look like you can not replace the touch-pad , it's Joined to the circuitbord. Looks like you would have to replace the whole thing. NOT GOOD SORRY
Posted on Dec 10, 2008
Search on e-bay for your make and model number. There is usually a steady supply of faulty ones. Make sure it is not the same fault though!
Posted on May 25, 2008
Scroll bar
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
Feb 03, 2013 | Acer Aspire Computers & Internet
Hi, I need help with my acer aspire 5750, the Multi-Touch Touchpad has stopped working. It works as in its moves the cursor on screen but the secondary touch control that controls; Circular-motion...
Hi
can you please check that the touchpad has not been locked i dont think it has but worth a try
by pressing FN+F7 or FN+F9
also check that the nulock has not been ingaged by mistake
also the scroll lock
or go to
start
all programs
acer
acer management
contents
scroll down to find the touchpad/pointing device
go over to the right by the green icon and hit the install tab
and let windows re install the touchpad
may be this will help
many thanks
Jul 07, 2011 | Acer Aspire One PC Notebook
Toshiba Laptop Scroll problems
Scrolling is not obvious because there is no area actually marked on the touchpad that shows where it is. Also if you tap the area before doing it, it won't work. Even for me it is hit and miss, since I don't practice with it enough. You could adjust the area that it uses and make it bigger, but then that gets in the way of regular mouse usage.
I would suggest that you try it at a store, and have a sales person show you how to use it.
As for the curser jumping even with that checkmark, well it can. All that checkmark does is turn off the touchpad for a brief moment while oyu are typing. Pause for a second and the touchpad is active again, then slightly bump the touchpad and your mouse will jump. Prove this to yourself by turning off the touchpad entirely with Fn+F9.
In the touchpad settings you can adjust various things to suit you. For example increase the slider for the diable while typing chekmark oyu mentioned, decrease sensitivity, turn off tapping support, etc. Each have thier pros and cons, and that is why they are adjustable.
Also, since you repaired it, I assume they tested it to make sure it was working. And if the touchpad is working, then the jumping adn the scrolling have nothing to do with a hardware problem, it is all software. You can replace hardware till the cows come home and it won't change things. So look at the software settings for scrolling and for "jumping".
This signature left intentionally blank.
Please let me know if you have any further questions or concerns.
Thanks.
May 07, 2010 | Toshiba Satellite A3 A355D-S6922 Notebook
My touchpad scrolling doesn't work, what to do?
“Hi let’s see if we can fix this problem”
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver”, click (OK), this will ensure that the application take effect.
Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
Hope this Fix it.
Dec 06, 2009 | Toshiba Satellite A10-S177 Notebook
Laptop touchpad won't stop scrolling.
1. hook up a usb mouse to get you by.
2. try to download the synaptics touchpad driver.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432985
see if that helps.
Sep 14, 2009 | HP Compaq Presario V2000 Notebook
My touchpad stopped working on my Aspire 5720z sinced last week and I my laptop just a year old this month. Can you please help me
If it is still in warranty, as Acer has a one year warranty, you can take it to your local Best Buy for repairs, you will need your receipt though.
You can go and check to see if your laptop is still in warranty by going to Acre's website and select support, www.acer.com.
Good Luck.
Mar 15, 2009 | Acer Aspire 5720 Notebook
Synaptics Touchpad Enhancements stops working
Hi!
I resently had the same problem on my HP laptop and search Google for possible solutions. No solution works until I tried Windovs Update and then got 5 alternatives - Synaptics PS/2 port TouchPad was one of them. I update and restart and finally solve this problem.
Terje
Jan 09, 2009 | Acer Aspire 3610 Notebook
Touchpad scroll not working
Check to see that the program is still installed that manages that feature:
"C:\Program Files\Apoint2K\Appoint.exe"
If it still exists, you need to run that EXE to get scrolling back. To make sure this happens automatically at start-up, add a shortcut to the "StartUp" menu of Programs\All Users, or run msconfig and ensure it is enabled in the Startup section.
If it does not exist, you need to reinstall dual-pointing device (or whatever touchpad you have) from the Toshiba website, for your specific PC.
Jan 13, 2008 | BenQ Joybook 5100U Notebook
Samsung yp-z5 scroll panel stopped working.
This is a common hardware fault with this player. I guess it is why the model has been replaced.
The cheapest solution is to buy a faulty player from ebay - around £10 including postage and replace your faulty one. Make sure to check the faulty one does not have the touchpad fault.
It is straightforward to replace the touchpad.
Oct 23, 2007 | Samsung YP-Z5 MP3 Player
Zen Touch 40GB Scroll Problem.
There is a circuit board under the touchpad that has probably gone bad. You should purchase a Zen Touch with some other problem like bad hard drive or broken screen, but that has a working touchpad, and swap the outer body for the working one.
Sep 11, 2007 | Creative Labs Zen Touch MP3 Player
Samsung YP-Z5 MP3 Player Logo
600 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
