ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Prepare the Phone Driver for Flashing. 1. Turn OFF Phone. 2. Connect MicroUSB to Champ. 3. Press Volume Down + Lock key then connect USB Cable to PC 4. Install driver (Driver can be found on C3300K_Flash_loader_7.4.4_SSG_v0.5 folder, 52xdfu)(Manual install it using device manager)
When installed, get ready.
Re flashing 1. Run Flash loader 7.4.4_SSG_v0.5.exe
2. Click SET MODEL -> Select C3300_LIBRE_Setting_v02.mdl 3. Click Start
4. Turn OFF Phone.
5. Connect MicroUSB to Champ.
6. Press Volume Down + Lock key then connect USB Cable to PC
7. Wait the flashing finished. (During the Flashing, your phone is off, then when the flashing is finish, you can see the your phone is charging.
8. Remove from USB. Turn on the Phone, Check if success, -if failed, try nyu ulit ang mga steps.
Good Luck. Do at your own risk. Not my responsibility for the Possible Damage can be made to your Phone
Just place a jar files(games or apps) on a memory card. Then just click on the apps or games it will install. Samsung champ will only install below 500 kb/apps or game, if you want to install higher than that just used this code by dialing *#52828378# you will go to Java Test Menu, then go to OTA test, change 500 to 4000 then save. You can now install as much higher than 500 kb but less than 4 mb.
