Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
1333 FSB processor only runs with fsb set to 1066 in bios
If i try to boot it with the fbs set top auto the computer locks up before it gets to booting windows, i have to reset the bios via the jumper on the board when this happens, everything is compatible for 1333 bus speed i dont understand it
would upgrading ran from 533mhz 2 gig to 667mhz duel channel do the trick?
or is this motherboard simply borked :(
it is running the newest bios revision and all drivers are up to date
  • 3 more comments
  • RIArchangel May 20, 2008
    ive been back and forth with ECS customer support. i think they pay a monkey to work that for them.... i will never buy another board from them again >.<, nothing they send back even comes close to answering the question at all hopefully you guys can help :D
    i have read the manual 1000 time it says through bios setting this board can support 1333mhz processor does that imply that i have to overclock to do it?. when i bought the board the tech said it would work yup no more ECS boards for me :(
    the only reason it is bugging me is my 3ghz dual core is running a 2.2 ghz becuase of this incompataibity
    page one under introducing the motherboard
    right underneath the 2nd paragraph
    "* Through BIOS setting, this board can support FSB 1333 MHz processors"
    but in no way explains how to go about doing it, and it seems there techs don't know the 1st thing about the products they release :(
    they are going to take back the motherboard, luckily im still within the 30 day grace period. Im just glad i got a straight answer before i hit the point of no return. thank you very much for your support.
    President:
  • 2,351 Answers
RIArchangel, you're board is not able to run 1333fsb; it can only run at 1066fsb. Though setting the bios to auto should not cause the system to lock up, unless you are over-clocking other settings in the system bios.
Changing you're memory to the faster dual channel 667 will increase the systems over all performance but it will not change the fact that the board can only run at 1066fsb.
If you have the time, take a read over this link. 1333fsb over 1066fsb. http://www.tomshardware.com/forum/230788-30-1333-1066
Feeling spunky? You can test you're CPU with this free software. Scroll down a bit until you see, CPU Stability Test
http://www.pcworld.com/downloads/file/fid,7146-order,1-page,1-c,alldownloads/description.html
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 20, 2008
  • 2 more comments
  • Mike Peluso
    Mike Peluso May 20, 2008
    Please tell me where in the manual you see this. (Page number)? I have the manual too & maybe I missed it, so do tell?
  • Mike Peluso
    Well I also have the manual, so please do tell where in the manual you read this?
  • Mike Peluso
    Chapter 1
    Introducing the Motherboard
    Introduction
    Thank you for choosing the 945GCT-M motherboard. This motherboard is a high
    performance, enhanced function motherboard designed to support the LGA775 socket
    Intel CoreTM 2 Duo/Pentium D/Pentium 4/Celeron D processors for high-end business
    or personal desktop markets.
    The motherboard incorporates the 945GC Northbridge (NB) and ICH7 Southbridge
    (SB) chipsets. The Northbridge supports a Front Side Bus (FSB) frequency of 1066/
    800/533 MHz using a scalable FSB Vcc_CPU. The memory controller supports
    DDR2 memory DIMM frequencies of 667/533/400. It supports two DDR2 Sockets
    with up to maximum memory of 2 GB. DDR2 Maximum memory bandwidth of 10.7
    Gb/s in dual-channel interleaved mode using DDR2 667 MHz. High resolution graphics
    via two PCI Express slots, intended for Graphics Interface, is fully compliant to
    the PCI Express Base Specification revision 1.0a.
    The ICH7 Southbridge supports two PCI slots which are PCI 2.3 compliant. It
    implements an EHCI compliant interface that provides 480 Mb/s bandwidth for
    eight USB 2.0 ports. One onboard IDE connector supports 2 IDE devices in Ultra
    ATA 100/66/33 mode. The Southbridge integrates a Serial ATA host controller that
    is SATA 1.0a compliant, supporting four SATA ports with maximum transfer rate up
    to 3.0 Gb/s each.
    The motherboard is equipped with advanced full set of I/O ports in the rear panel,
    including PS/2 mouse and keyboard connectors, COM1, LPT1(optional), one VGA
    port, four USB ports, one optional LAN port and audio jacks for microphone, linein
    and line-out.
  • Mike Peluso
    1066/800/533 MHz using a scalable FSB Vcc_CPU. I do believe you after reading some forms. Here is one but I'll post the link so you can see all the posts. ( The "just" of this is you can get the fsb up to 1333 but you would need to run memory to run at 800MHz. So, is it worth upgrading you're memory to the 667 & hope the bios allows you to get at the settings to set it to 1333fsb? That's the question. You'd need to run 800MHz (as mentioned in the forms). I get the feeling that the board is not doing what it's supposed too.
    Read this.
    Pros: The price can not be beat. Runs stable. Integrated graphics is a useful feature to me since there is not much room for expansion on this matx board.
    Cons: If you are wondering what ""Supports FSB1333 processors with specific configuration"" means. It basically means that this board will overclock itself to support the 1333fsb. This is not problem. However, 1333 processor needs memory that runs at 800mhz to run up to speed and this board only goes up to 667. My E6650 @2.33ghz runs at 1.86ghz instead. It is not that big of a problem but i wouldn't find getting what I paid for out of my processor.
    Other Thoughts: Since you overclock the board to run at 1333, your pci bus also gets overclocked from 100mhz to 133mhz if I'm correct. This rendered my pci ide controller useless. Needless to say, I'm returning the board. This is a good board, but not if you're buying it for your new 1333fsb processor.
    Read the form.
    http://www.newegg.com/Product/ProductRev...
    Again, let me know you're thought's.
    (Can you return the board for not running as stated)? (Just a thought!
    Mike
My core 2 duo E6550 does not work on my foxconn g41mxe motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186187
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
http://ark.intel.com/products/30783/Intel-Core2-Duo-Processor-E6550-%284M-Cache-2_33-GHz-1333-MHz-FSB%29
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
http://www.manualowl.com/m/Foxconn/G41MXE/Manual/297328
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=G41MXE&cputype=Intel
Note the version of the BIOS program also.
Regards,
joecoolvette
Sep 25, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
Bios update for t5226... intel update will not work.. some people say it is locked by emachines. i am trying to put an e8400 in it, but i don't think that the processor is supported by the older bios...
It isn't the fact of the BIOS, it's the motherboard chipset.
The eMachines T5226 uses an Intel 945G.
This chipset only supports processors with up to a 1066MHz FSB.
Supporting Data:
1) eMachines T5226 specifications;
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5226
2) List of Intel Chipsets, and more specifically the Pentium 4/Pentium D/Pentium EE chipsets,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_Chipsets
The Intel 945G is the 12th one down, or last in the list.
Looking across to the right, you can see the Intel processors supported, and the maximum FSB support.
(533/800/1066)
The motherboard's BIOS also won't let you overclock the FSB.
The Intel Core 2 8400 has a 1330MHz FSB,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Wolfdale.22_.2845_nm.29
The Intel 945G also won't support Intel processors with the Wolfdale Core.
Feb 18, 2010 | E-Machines T5226 PC Desktop
How to overclock Intel Pentium Dual Core E2140 1.6 GHz processor
The following link will tell you the very simple way to overclock this processor. Half way down the page you will find the header "OVERCLOCKING"
http://www.value-reviews.com/index.php?page=pentium-dual-core-e2140
"Since the architecture was designed for the 1066 MHz FSB, overclocking is as trivial as setting the FSB to 1066 MHz (266 MHz quad pumped).
...you instantly get a 2132 MHz CPU with little increase in temperature."
Dec 06, 2009 | Intel Computers & Internet
I have a gateway MSII have a gateway MSI Ms-7399 mother board. I have an E6300 pentium dual core processor at 2.8 with a FSB at 1066,in it and it works fine. I want to know what the specs on the board are...
The board is maxed out at 1066 and it does not appear that gateway has a BIOS update to allow for the higher FSB reuired with the faster Intel chips. If you installed one of these newer LGA 775 chips into your computer it may work but would be a lot slower than what it is rated due to the chips multiplier would be set for 1333. I could not see any BIOS updates from gateway for this board. Also these chips are designed to run with the faster memory and the 800mhz memory speed would also be a bottle neck for your system.
Oct 10, 2009 | Computers & Internet
Compatible processors???
This MB will support: Intel® Wolfdale/ Core?2 Duo /Pentium Dual Core/* Pentium D / Celeron 4 xx series/ Celeron D Processors FSB 1333/1066/800/533 MHz. Here is the support page with more info: http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Specification&MenuID=44&LanID=9 Thanks for using Fixya.
Aug 29, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I am tryin to upgrade my processor on my 4000783 gateway motherboard need to change my fsb speed and dont know how
You cannot change your fsb. You need to upgrade to a cpu with a fsb speed that your board can support. Once you install the new cpu your bios will set the fsb to the higher setting of your new cpu if your board supports it. If you have your board specs it will tell you something like supports fsb 1066/800. That would mean you could upgrade to a supported 1066 fsb cpu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Nov 08, 2008 | Gigabyte GA-8ID533 Motherboard
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Wont post with 1333 fsb
This board wont take a 1333 cpu. The fastest it will run is 1066
This motherboard supports the latest Intel® Pentium / Celeron CPU in LGA775 package with 1066/ 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond.
Make sure your RAM is DDR2 800mhz
The Pentium D830 runs at 800fsb which is in line with the board capabilities.
Feb 24, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
820 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
