Question about Lexmark X5150 All-In-One InkJet Printer
Not printing I hit "print" in doen't print, the paper comes out with nothing on it. I did a test page and it printed. Help,
  • 3 more comments
  • Anonymous Jun 10, 2008
    i tried to resolve that but i cant get it....
  • kesrose18 Jun 24, 2008
    Print command is given; the printer starts up, scrolls the paper down; paper stops as if print is about to begin but doesn't, then blank paper scrolls out.
  • eshchory Jul 03, 2008
    I'm using Windows X. All is fine with Word and Excel but when I try print from an accounting program the printer spits out the page before the the on screen printer gauge even starts to run through the percentages.
    The technician claims the program is perfect and the my driver is the problem.
  • westenn Aug 05, 2008
    not printing the ink on page acts as though it is-paper goes through and sounds like it's printing but no ink. installed new cartridge and printed alignment page blue ink only. help
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are these connected to Vista computers?
  • 39 Answers
Westenn, if there is no black ink on the alignment page, then your black cart is empty or the nozzles need cleaning. Your printouts will be blank if you're printing text since that would be black and you're out of black ink. Try cleaning it by carefully wiping the nozzles with a cotton ball swabbed in rubbing alcohol, and try cleaning the nozzles through the Solution Center. If that fails, try a new black cart - install it, print alignment and then everything should work.
eshchory - the tech may be wrong. If the accounting prog doesn't send print data to the spooler in a way in which the driver expects, then it's not the driver's fault, but worse it's not likely you can resolve the issue. You can try updating both the app and driver to the latest versions to see if it fixes it, but it isn't likely. Sometimes apps like this just won't work with certain brands of printer. If you were to get another brand of printer and see if it prints from the accounting prog, that might tell you once and for all who's to blame.
Posted on Aug 06, 2008
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Does not print.
print a test page from Windows...if nothing prints, you need new ink
Jul 21, 2012 | HP Office Equipment & Supplies
The printer will print out the test page but it will not actually print anything on a paper whenever i hit print, it just runs a piece of paper through the printer blank
If test pages are working but print jobs aren't, it's almost always a driver issue.
Uninstall and reinstall the printer driver.
If it's still not working, and you're running windows 7, turn off the bidirectional communication mode.
post a reply here if you need further help or if that doesn't work.
Feb 27, 2011 | Office Equipment & Supplies
No print at brother mfc-24c
"Machine Error 50" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
However, if that doesn't work, the error is mechanical, and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
4100 stops printing mid streem and engins continue to run
Try printing out an error log and seeing if that leads you anywhere.
Nov 25, 2008 | HP LaserJet 4100tn Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Jul 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Printer is not printing
i got a paper jam and now my printer won't print at all what should i do?
May 03, 2008 | Office Equipment & Supplies
Printer
run a test print page, please..and report.
Feb 19, 2008 | Office Equipment & Supplies
Lexmark X5150 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
