Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
TNP2AH046 board I'm in need of one ... do you have one inclusive of the convergence chips?
Excellent. may i buy one as well. how much do you charge. Do you accept a core in exchange?
Posted on Oct 15, 2008
Im looking for a tnp2ah046 board i have a model pt-47wxc43g please let me know where i can get one. thank you for any help you can provide.
Posted on Jun 09, 2008
    Scholar:
  • 137 Answers
Yes. let me know to contact you
Posted on May 25, 2008
  • Mervin Guy
    Mervin Guy May 28, 2008
    techadvisor@interactive.com
  • Mervin Guy
    Mervin Guy Jun 01, 2008
    sorry wrong email. Its techadvisor@interactiverepair.com
Convergence
I'm assume you are referring to a non adjustable convergence option. this will occur when you have a damaged convergence chip set that is located on either the PC board or the convergence board. The location of the affected chip will vary from model to model but, in most units, this can be fixed by replacing the convergence board or chip.
May 31, 2009 | RCA HD61W66 61" Projection HDTV
Tnp2ah046
yes..get another board..and be careful about that soldering iron and it's rating..
is that the model number? who's the maker? We can find you a replacement board online.
May 11, 2008 | Televison & Video
Hitachi ultrasound hd
voltages to IC's There's a shielded module near convergence IC's It could be bad too. Check voltages to It.. I had simular problem /replaced IC's did not fix..Replaced module & did convergence.. TV was fine so try this 1st k
Jan 29, 2008 | Hitachi 43FDX01B TV
Colour problem with rearview projection tvred
you will need to change out the convergence board if the blue and green wont align its time for a new board
Aug 21, 2008 | Sony KP-51HW40 51" Rear Projection...
D Board tnp2ah046
Hello WoodenBadger,
I do have the board in stock. Please contact me by email: boards@interactiverepair.com for full details on receiving the board.
Best regards
Jun 10, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergance chip
Thats the regulator chip for the convergence circuits thats the one youre most likely needing, as your chassis doesnt have convergence ICs. You can get that IC at the following link and they will provide free installation instructions and free on line tech support just in case you need assistance. Here is the link.
http://servicemanuals.vstore.ca/
Apr 23, 2008 | GE 46GW947 46" Rear Projection Television
Where is the convergance chip
thats a ctc that doesn't have a convergence chip that model dont it uses a series of amplifier transistors and buffer transistors and you may have to buy a replacement board
Repeated chip failure
are the resisters ok?
i might suggest sending the board into ptscorp.com
Feb 04, 2008 | Zenith Z60Z83R 60" Rear Projection...
It sounds as though you have a convergence problem. This problem is normally a convergence chip ( there are two (2) of them on the convergence board )
If you intend to correct the problem yourself, always remember to practice precautions by unplugging the tv before removing or servicing the set.
To change these chips, carefully follow these tips . I do suggest you change both chips as I have found that when one goes bad, the other one is on the way out also.
Remove the bottom back cover by using the proper screw driver or nut driver. usally a 1/4 inch nut driver or a phillips screw driver is all that's necessary.
When you have the boards exposed to view, notice on the left center of the convergence board ( the convergence board had 2 large ( large being 3X4 inches) chips next to each other. These chips normally are marked with number like STK 3020, STK 3050 etc.( I don't know the exact number on this perticlar set but they are all about the same ) They usally have about 15 pins ( wires ) coming from them. May be 12 or 18 but normally 15.
This board needs to be removed to change the chips, so remove any screws that mount the board and disconnect each wire connected to the board. ( NOTE : I normally mark each wire with some kind of a color code with permanite marker pen as to know exactly where to reconnect the wire to eliminate any mistakes )
With a soldering iron ( normally one of about 25-40 watts works well ) and some de-soldering wick ( can be purchased at most electronic parts stores or Radio Shack ), remove the chips.
Clean all the connections after taking the chips loose from the heat sink ( the heat sink is the aluminum plate the chip is screwed to ). Apply an ample amount of heat sink compound ( silicon grease it is sometimes called) ( can also be purchased at Electronic Parts Store or Radio Shack ) to the back of the heat sink and reinstall the new chips ( make sure the new chips are of exact numbers as the old), being extra careful not to bend the pins. Solder the pins being extra careful not to jump solder across any connections.( if you happen to apply too much solder and do in fact jump lead across the connections, simply use the de-soldering wick and remove any excess solder ).
Reinstall all the wires and screws to the board ( double check for mistakes ) and turn the set on, checking for the correct convergence. You'lle need to do a quick convergence with the magic focus switch after warming the set up for appr. 20 minutes. Reinstall the back of the set.
The set should work fine.
I do hope this helped
Ed
NC Electronic
Mills, Wyoming
Toshiba convergence
There are kits available online, which include the chips and the soldering iron too.......Just a word of caution, convergence chip replaced is more difficult on Toshiba #1 the chips face other boards that must be remove first. the main one is the convergence generator (which the sheild is soldered in placed) Also the signal board (which is what everythings mounted to is very fragile)..............Good Luck
Jan 11, 2008 | Toshiba 50HX70 50" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
236 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
