Question about Sony KP-46WT510 46" Rear Projection HDTV
46wt510 Did you ever get your sony tv fixed? Mine is starting to do the same thing.
Yes. My convergence was all out of whack. I was not about to tackle this job on my own and was afraid of getting screwed. After much research, I found a Sony specialist in Dallas who came out that day and fixed the convergence ic's and it cost me less than 2 bills. I can't remember the guys name, but I have his card. It is A Plus TV Service at 7000 Independence Pkwy #160 in Plano, TX 75025 (972-322-2988).
Posted on May 23, 2008
I have a new smart blue ray player and am trying to set it up using a hdmi cable to my sony KP-46WT510 tv and I have video but no sound?
Two things come to mind. !. are your cables plugged in right? Yellow->yellow, red->red, white->white? 2. Is the sound on the TV itself turned up?
Nov 28, 2013 | Sony KP-46WT510 46" Rear Projection HDTV
My sony tv model # KP-46WT510 the picture bows to the middle i tried fixing the convergence and it does nothing what else should i try
If the convergence feature did not fix the issue then you will need to install a convergence repair kit. Your model uses the Sony type 1 convergence repair kit which is available from www.tvrepairworld.com and includes the parts and the CD with instructions.
Aug 28, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or...
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Jan 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Problems with Sony KP-46WT510 46 in. Rear Projection HDTV. The Colors are not lined up correctly (Good in the middle of the TV and 2" off on the sides, top and bottom). What do I need to do to fix it?
Ur convergence is dead.U must know how to solders?Must replaced 2 convergnence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Trepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 06, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
There is a big black spot on my tv it is a sony hd plasma tv what is it and how can i fix it
where is the black spot located on the tv please explain in details the problem with your tv if you want help.
Mar 01, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Rear Video Projector model # KP-46WT510 and it started acting up. It is a double picture when we try to watch TV. Can this be easily fixed?
Unfortunately it is a job that will require an experienced TV technician,
You have 2 large 18 pin ICs called convergence amplifiers who's job is to insure beam alignment of the three picture tubes in your TV set (Red, Green & Blue). One of the 2 chips have shorted and more than likely cause damage to the 2nd one as well. This involves removing the board where the ICs are mounted then rmoving the ICs by a process called desoldering & resoldering during the replacement process. They are not a plug in Ics.
Hope this helps.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony wega and i get 4 blinking red lights
4 blinks code shows problem in Vertical Deflection section of TV. Of course it worth to be repaired. If you are not familiar with TV repair then call TV tech to fix it. And if you are tech person, let me know to help you out with tech info.
Jan 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 wont turn on
8 blinks means that the High Voltage Block is shorted - part# 8-598-955-32 (about $80)
Sep 10, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
