Question about Toshiba TDP-S8U Multimedia Projector
Toshiba TDP-S8U Projector doesnt work
When tested, this projector does not power up. The power light just blinks.
i just purchased this on ebay, and wanted to know what i can do when i get it.
  • 2 more comments
  • j cwff May 20, 2008
    great advise, i will try it when i receive the projector
  • j cwff May 22, 2008
    i just got the projector,, the power light jsut flashes on the projector,,, nothing turns on..?????
  • j cwff May 25, 2008
    i see bubbles.....
    THe power light comes on but it seems like it goes into a standby mode....
    I pressed and held down 3 buttoms on the projector, and the power light, the lamp light, and the temp.. light stays on...
    But the lamp does seem to have bubbles.. in them...
  • Cook7 Jun 21, 2008
    I have the same problem. The power light comes on , but the projector is not running. The lamp trys to flicker , but the fan or lamp will not come on,
  • 563 Answers
Hi j cwff
I would have said to take out the lamp and check for any visible damage , but if there is no response at all , you will most definitely be in for a Mainboard replacement that is going to cost a bit more than you might have expected.
I have however found that some people give the diagnosis of a faulty Projector totally wrong and it might be that the lamp is just blown - in which case the machine will switch on , but the lamp LED will flicker without any light being projected - then you can just get a new lamp for it.
Once you receive the Projector and checked it out for yourself , send me a request with any additional queries you might have and I'll happily assist you.
Thanks for using Fixya and good luck !
Posted on May 20, 2008
  • Marnus Jacobs
    Marnus Jacobs May 23, 2008
    Hi there
    Ok , take out the lamp and check for any irregularities on it like vein like looking marks , white or black marks or even bubbles on the shaft.
Service manual
It is not working for Toshiba TDP-XP2, when I hold three button above and plug the power on, the light at power button is blinking forever.
Any help will appreciated.
Apr 04, 2012 | Toshiba TDP XP2 DLP Projector
It suddenly stoped playing clearly. i can see some extremelly pale picture.my lamp is around 2000 hrs the projector is a 2004 model toshiba TDP-D2.any ideas?thanks panos
You need a new lamp. You can purchase one at:
http://www.shopvsc.com/Toshiba-Replacement-Projector-Lamps-s/143603.htm?searching=Y&sort=7&cat=143603&show=50&page=1&f-TDP%20D2=143381
Oct 25, 2010 | Toshiba TDP-D2 Projector Lamp
TD9-S81 no power when data projector comes on
no leds? bad power supply. leds but no fans? bad button panel or main board. led and fans but no light? colorwheel or ballast.
Sep 18, 2009 | Toshiba TDP-S81U DLP Projector with...
Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Dec 19, 2008 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Dec 29, 2007 | Toshiba TDP-S8U Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8U Multimedia Projector Logo
94 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
