Question about HP Deskjet F335 All-In-One InkJet Printer
When the printer boots up it gives paper jam error
Well intially my 12yr old son changed the print cartridges and they are the right cartridges, however the printer never worked afterwards. I tried to go and back and re-install the HP Deskjet F335 All-In-One, but every time i try to print the alignment page to set-up. The print cartridges go back and forth a couple of times. Then it gives a paper jam error and there is no jam help!
  • Anonymous Oct 22, 2008
    i have the same prob but pressing the copy button does not work!!
Press the copy button
hope that helps
Posted on Jul 14, 2008
HP 4100dtn Tray 2 picks the paper NON-STOP?
Step 1:Check with another cartridge
Step 2:Switch off the printer take out tray 2 casette, swich on the machine check while intializing the printer tray 2 pick up roller rotating?.. If its rotating check solnoid which is located right side under the main moto assembly, clean the solnoid as shown in the anap shot..fix it back.
Step 3:Open right ,left & top covers.., close cartridge access door check is it driving the laser scanner shutter?, if not check the sccess door knotch broken/bend.
Nov 20, 2011 | HP LaserJet 4100dtn Printer
Printer suddenly stopped printing - alarm light is on continually, even though I pressed resume button - also sounds as if it is trying to send paper through printer.
Turn off the printer for about 5 mins then turn it back on. Can you provide the model number of your printer as well as any error codes on the screen if you see any.
Aug 27, 2008 | Office Equipment & Supplies
Does not print, responds with paper jam. No paper jammed. Clean sheet of paper passes through. Could a buildup of dust be the problem and its age. Tried cleaning roll by command and changing the ink. I...
What you could try is let the printer to reset.
Remove both ink cartridges.
Close cover and turn off printer.
Unplug printer from electrical outlet.
Wait 15 minutes. This will let the printer to clear memory.
Plug printer back in.
Turn on printer, printer would cycle to the start position.
E5 error would appear.
Install ink cartridges.
If nothing is in the printer that prevent the printer from recycling.
There should be no paper jam error.
Jan 04, 2011 | Canon PIXMA MP170 All-In-One InkJet...
/*mp250 error code p03 alarm and on light flashing, color ink light on. trying to change cartridge but cartridge head will not go to the center so i can change it. help
manual replacing the print cartridges --> try rotating the left white gear back and forward releasing the mechanical lock of the print head it is a small plastic peace in the back of the of the head ...replace the cartridge as you need ...
about the error p03 it indicates a mechanical jam (head carriage - paper jem - paper pickup mechanizm - head cleaning mechanizm ) also clean carfully all sensors from inside ... it can give you a mechanical jam if blocked
Dec 09, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Jam inside top cover 13.05.00 also change fuser assembly
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
Nov 26, 2010 | HP LaserJet P3005 Printer
Paper jam light on permanently, printer is jammed
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Feb 15, 2010 | HP LaserJet P3005n Printer
HP psc 1310 - gave paper jam and print cartridge error. There was not paper jam and paper jam message went off. My son changed one of the print cartridges, although it still had ink in it. The error...
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Oct 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
HP Deskjet F335 All-In-One InkJet Printer Logo
137 people viewed this question
Seeker5211
Seeker5211
