Question about Canon i80 InkJet Printer
Canon Photo Printer iP4500
What do the error codes 5200 and 5700 mean?
Thanks LED light flashes green and orange, will not print. Printer Status Monitor shows red and says there is an Error 5200.
  • 1 more comment
  • donsa Jun 11, 2008
    i have the same problem what was solution
  • Anonymous Aug 03, 2008
    error 5200
  • Anonymous Mar 29, 2014
    printer does not work
Buy new printer
Posted on Sep 05, 2008
Me too
Posted on Jul 02, 2008
My printer is coming up with the error code 3 which is flashing. can you help please
Clear error codes
First make sure that there isn't anything keeping the carriage from moving freely.
Then follow the instructions below:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Codes:-
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 22, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma IP4000 - Printer on/off button flashing orange light X 5 and then green. I have just re-newed all the ink cartridges Can you help ? will i be able to re-set printer ?
5 times orange means you need to replace the print head.....if the led are Blinking in Orange and Green Alternately you need to replace the sheet feed unit.
Mar 28, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Canon printer IP3000 5 lights flashing
If its just orange led flashing .. You need to replace the print head..
if its cycling 5 times between orange and green than there is a problem with the ASF cam sensor (which means paper feed unit)
Mar 30, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Hi, i geting problem in inkjet printer connon
These are the instructions which worked for me on my Canon pixma ip470 bought August 08:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.
Jan 08, 2010 | Canon Pixma iP4500 InkJet Printer
LED light keeps blinking
That is a service error code, but you need to count how many blinks between the longer green blink, and that tells the error code...
Oct 13, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Nov 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i80 InkJet Printer Logo
835 people viewed this question
old marine
old marine
