Question about Nikon Coolpix P1 Digital Camera
Turn Off Flash!
Ho do I turn off flash on my Nikon CoolpixP1? I theed an answer right away! Thanks!
See Menu.. you want flash turn off?
Posted on May 20, 2008
Nikon d60 flash will not popup
turn camera on keep the lens cap on and push the button on the side of the camera with the image of a lightening bolt at the same time help the flash door up if that doesnt work go to menu then custom setting then go to braketing/ flash toggle right and turn on builtin flash
Aug 06, 2014 | Nikon D60 Digital Camera
Won't turn on
Ric DonatoSorry to hear that with fresh batteries it will not turn on. If it used to turn on, then now there is something wrong with the flash. Other than using different batteries, making sure they are in the correct order, and still it does not flash it will need to go to Nikon repair. Yes, I would not want to hear that answer, but that may be the only solution.
Nov 28, 2013 | Nikon Speedlight SB-600 TTL Flash
My sb-200 flash won't work with my d200
Go to menu then shooting and turn on ttl
Jan 17, 2012 | Nikon SB-400 Flash
How to install a Nikon SB-700 AF Speedlight Flash for Nikon Digital SLR Cameras
Basically, you put batteries into the flash, put it into the flash mount on the top of the camera, turn everything on, select a flash mode, and start shooting.
The flash comes with a detailed manual describing its operation. There is a section in the camera manual describing the various flash modes. The SB-700 is fully compatible with the Nikon iCLS system, which includes the D3100.
Since you asked a general question, I can only give you a general answer. If you have any specific questions, please feel free to ask them.
Jan 05, 2012 | Nikon D3100 Digital Camera
I have a Nikon Speedlight SB-800. Before I take a picture from my Nikon D70 the flash will click about four times while there are spurts of light coming out of the bulb then the picture will take. Never...
The pre=flashes are for reduction of red eye and also for TTL indormation for camera to wotk properly with flash. Read Flash manual and some info in camera manual
Jan 10, 2011 | Nikon Speedlight SB-800 TTL Flash
Nikon SC-29 REMOTE CORD
Hi Kathy,
Are you ready?
1. Make sure the Nikon SC-29's Red Panel's Lock Switch is set to the Left. Pointing at Left Black Screw.
2. Connect the Nikon SC-29's (Red Panel) to your camera's Hotshoe by pushing it as far as it goes.
3. Turn Lock Switch to the Right (turn CW). This locks down to camera.
4. Make sure Nikon SC-29 (other ends) AF-ILL is set to OFF.
5. Make sure your Nikon SB-800's Lock Switch is set to the left side.
6. Attach your Nikon SB-800 into this Hotshoe.
7. Switch the Lock Switch on flash to the right.
8. When you wants to AF from flash, set AF-ILL to "OFF"
9. For the best results, set AF-ILL to "ON".
I teaches, do repairs, services and modifications on all photographic equipments.
I hope they are helpful to you as well as for any Nikon Photographers using the Nikon SC-29 Cable.
Mine has Autofocus, ITTL, Slave and Wireless Radio Remote Flash.
Truly,
atdlee@netzero.com
Jan 31, 2009 | Cameras
I am not able to find, How to turn of the Flash of Nikon Coolpix 8700. When i need to take pictures without flash, but when i click, it automaticaly turns on the flash, and i tried to figured it out how to...
ok. there is a button on the side of the lens. it has an eyeball and a bolt of lightning, press that button and look in the top right corner of the screen. keep on pressing this button until you see; a lightning bolt with a circle with a line threw it. then "click". if that doesn't work switch your camera to manual and try this again.
Jan 11, 2009 | Nikon Coolpix 8700 Digital Camera
S51 nikon - no flash
Did you try to access the flash mode of the camera and turn on the fill flash then try to take a picture? If the flash doesn't go then and your batteries are strong, then it will likely need service.
Make sure you put it on FILL FLASH and not on auto. Depending on the ISO the flash may not always fire in the auto mode.
Here's a link to the USER guide if you misplaced yours...
http://www.nikonusa.com/pdf/manuals/noprint/S51noprint.pdf
Dec 29, 2008 | Nikon Cameras
Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Feb 13, 2008 | Nikon Coolpix 7600 Digital Camera
Nikon D40X Pictures Flash Black In Playback
You've just turned on the "highlights" option in image review. Press the up arrow on the d-pad to get back to the normal setting.
Dec 24, 2007 | Nikon D40x Digital Camera
Nikon Coolpix P1 Digital Camera Logo
376 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
