Question about HP Pavilion dv1000 Notebook
No power computer quit working when the battery died and am unable to recharge or use laptop on wall power.
  • 207 Answers
Did u change the bat??
check the recharger of the notebook
by just simply plugging it wd out bat and start the comp if it wrk the bat is gone if not
then chek the adaptor or the power supply of notebook
Posted on May 20, 2008
Why is my laptop unable to run off battery power, even though battery shows fully charged and AC is unplugged
It's time for you to replace your battery.
how old is your laptop? and how do u use it - do u leave it plugged into the wall socket all the time? It's common for batteries to die out after a couple of years. however, if the computer overheats or if you leave it plugged in all the time, it's life cycle will decrease. Charge - discharge cycles. That's how you are suposed to do it.
Jul 17, 2014 | Lenovo IdeaPad U550 Notebook
If the unit powers through an ac wall transformer its probably the cause, they burn out
all the time.
Replace it with the same rating that is shown on the unit (input/outpu
hope this helps
Jul 24, 2012 | Acer Aspire One Netbook 8.9" Notebook
I have a dell inspiron 1525. The computer has not been charging correctly lately and most of the time only works when plugged into the wall. The computer now blinks 4 orange then 1 blue light on the...
> blue light on the battery
This is an indicator that the battery has reached its "end-of-life".
There do exist companies that will disassemble the battery, replace the rechargable cells, and reassemble it. Or, look on eBay for a replacement battery.
> the computer will also not boot up
That's a quite-different problem, and probably NOT related to the problem with the battery.
Jul 19, 2011 | Computers & Internet
My MPC Transport x1000 just lost all power. I can't power it up on battery or AC adapter. This happened once before and we took it in for a repair, but by the time the technician got around to working on...
It sounds like the power circuit on the motherboard has stopped working (that would explain why niether battery or wall adapter make it work.) Without a motherboard repalcement, this laptop probably won't work again. Sorry to be the bearer of bad news, but you have gotten quite a few years out of it :)
Jan 18, 2011 | MPC Computers TransPort X1000 Notebook
Dell Inspiron 1000 won't turn on. It is always
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet.
Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Jan 03, 2010 | Dell Inspiron 1000 Notebook
Spot light is unable to recharge with the wall
While it could be the battery, it could also be the internal charger in the spotlight. When you plug it in, it bypasses the charger and uses the connected power. However, it is likely just a bad battery. The batteries only last 3 years in an ideal setting and since these lights are typically only used certain times of the year, the batteries discharge and go bad. New batteries can be found at:
Jul 18, 2009 | Vector 3 Million Candlepower Rechargeable...
160 gb ipod classic won't recharge with the wall charger
Try charging it on the computer or with a different wall charger. The fault may lie in the charger brick. I have seen it happen many times that the wall charger quits working but it still charges on the computer.
Nov 14, 2008 | Apple iPod classic MP3 Player
Hi, My Gateway MX3215 notebook computer no longer powers up with the AC plug. The battery was 5% and the AC plug was connected when the computer died, and it has not come back since. I have plugged in the...
Make sure you have power at the wall outlet (Dumb question, but I have to ask). If your AC power cable is detachable from the laptop transformer, make sure it is plugged in tightly. If there is a LED on the transformer, make sure it is on. If you have a voltmeter, check for DC voltage at the power supply plug where it plugs into the laptop. You should have between about 10 - 14 volts there. If you don't have a voltmeter (or multi-meter), see if you can borrow one.
If your battery was not seated properly or was worn out, then obviously it would not charge, but the laptop should still function off the power supply, so it is probably not a battery issue. If the voltage input and cable condition checks out okay, then it is probably a bad power supply.
Sep 11, 2008 | Computers & Internet
Battery not recharging
All batteries die sooner or later. I believe you have a dead cell.
1) Find another machine that uses the same battery and try it or
2) try another battery or
3) Give up and buy a new battery.
Good luck.
Apr 30, 2008 | Toshiba Satellite M35X-S111 Notebook
HP Pavilion dv1000 Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
