Question about IBM ThinkPad T30 2366 Notebook
T30 boot problemos screen.
A small picture of a pad lock appears on screen when i boot my t30 (looks like a dos screen. I removed memory it wouldn't start, i replaced it then removed battery and it went back to the drawing of a lock. press f1 and still would show a drawing of a pad lock? please help
  • kyokick Jul 21, 2008
    no it doesn't start up, how would I put a spyblasxter??? When i turn it on it doesn't boot just shows a padlock in dos format,
Your laptop sounds like it has a password at boot. i had the same thing. look on ebay, there is a guy who you ship your laptop to and he removes that password.
Posted on Jun 03, 2008
    Genius:
  • 1,224 Answers
You have been trojaned hit by spyware
2 main progs. you might want to look for spyware blaster and spybot search and destroy these are freeware and doesnt require signup these will clean your comp of the bugs
Posted on May 26, 2008
Flash bios
You don't want to mess with flashing the bios unless you really know what you're doing.
Also the fact that you don't have a cd drive is another problem in crisis moments like this. Never, Never buy a computer without a cd drive because one day it's going to croak and you'll need the drive.
If you had a cd drive or can somehow get a usb flash drive that you could boot from then you could try the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Also check your memory. It could be your memory chips or one of the memory slots.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 03, 2012 | Computers & Internet
Eee pc with 512mb memory won't boot up after upgrading firefox from v2 to v3
I think you have a memory issue or one of your boot or system files is corrupt.
Try running the check disk utility.
Check for a bad memory chip or memory slot.
Remove the Power Cord, Remove the Battery, Remove the Cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 09, 2012 | ASUS Eee PC 701 Notebook
IBM think pad my screen does not show anything but the cursor
Run the Check Disk UtilityTo run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 14, 2012 | Computers & Internet
MY LAPTOP GOES TO THIS BLUE SCREEN THEN SHUTS DOWN WHY DOES IT DO THIS
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 14, 2012 | Toshiba Computers & Internet
Toshiba A215 Password Removal
I had the same problem and could not find the pictures either. I still figured it out, so here are more detailed instructions. Please use a combination of the previous instructions and mine. This worked for my computer, but I can't guarantee success everytime since I have only done it once. Just do the best you can.
-Pull off the memory cover on the back of your computer.
-Now, take out any memory cards that are present.
-Look at the circuit board under where the memory was. You should see a rectangular black plastic sticker.
-Pull the sticker up.
-Look VERY closely at the circuit board under where the sticker was. You should find two soldering points close together that are labled with "B500."
-Now put one memory card in the slot that is furthest from the circuit board. DO NOT put a memory card into the inner-most slot at this time.
-Carefully hold a very small straight screwdriver over these two points and turn the power on to your computer.
-The Toshiba boot up screen will appear.
-Continue holding the screwdriver over the two points until the Toshiba screen goes away.
-When the screen goes away, pull away the screwdriver.
-Turn the computer off.
-Put the black plastic sticker back in place on the circuit board.
-Put all memory cards back in the memory slots.
-Put the memory cover back on the laptop case.
-Turn the computer on.
At this point I was asked to start windows normally or start using repair wizard. Normally did not work. So start windows using the repair option. It took about 10 minuts for windows to finally open normally.
100% success in my case! Please be careful when doing this repair because I do not know what damage could be done if you do it wrong. But, after 2 months of not using my laptop, it is finally back in operating condition!
Thanks
Aug 18, 2008 | Computers & Internet
Ibm t30
This is not good. It generally indicates that the security chip on the motherboard has malfunctioned. A hard drive failure can also cause this occasionally, but mostly it's the chip. Start by trying a new hard drive, if it works, GREAT, if not then the chip has malfunctioned and locked the system. Your only option is replacing the motherboard.
Jul 21, 2008 | IBM ThinkPad T30 2366 Notebook
Memory upgrade
Usually there will be 2 screws to remove (these may be hidden via rubber pads, or labels). The appropriate panel will have a RAM "picture" next to it.
May 26, 2008 | IBM ThinkPad T30 2366 Notebook
T30 boot problem
Sorry, but probably your T30 (my favorite Thinkpad) has developed a problem with one of it's memory slots. It is an inherent problem with the Thinkpads. The way to tell is topress on the memory cover in a way that pushes the memory (or more to the point, the memory slots) into the motherboard. While keeping pressure on the memory, try to boot up. I use a T30, and have worked on several others, all have at least one slot with this problem. Also try taking out the memory which is closest to the front of the system, and pushing in on the remaining one. Hope this helps. If this is the problem, there are a couple of things you can do to keep it running, but probably with only one ram stick. Goood luck
Oct 07, 2007 | IBM ThinkPad T30 2366 Notebook
T30 led's
a small board that attaches to the mainboard via a small cable has come unplugged. remove the lcd bezel and check connections rto te motherboard itseld from a small daughter card.
Aug 26, 2007 | IBM ThinkPad T30 2366 Notebook
T30 startup problems...
We can start with the easy stuff first. Move the memory chip to the other slot. Remove the small square plate on bottom of the laptop. You'll need a really small screw driver for this. If you have two chips, remove one and see if the laptop will boot-up.
Jun 28, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
139 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
