Question about Symantec WinFax Pro for PC
I can no longer scan images to winfax
Up until recently I was able to scan into winfax. Now it still does the scan, but doesn't save it to the fax I want to send. I used to have the option to fast scan but now I only have the photo quality option.
  • wildroot1 Jun 19, 2008
    I have having the same problem. Also, I can no longer Drap & Drop items. When I do it sends them somewhere else.
It turns out that I had the wrong port identified. By changing ports the problem vanished!
Posted on May 20, 2008
Winfax sending and receiving
Do you have a fax modem? A "DSL" modem does not work.
WinFax Tools has many fixes for WinFax that are automated.
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Feb 19, 2009 | Symantec WinFax Pro for PC
Restoring sent and received faxes to fax logs
That's not the way to backup your logs. You copied only the fax images, and not the logs to go with them. This is a common error that is made quite often. Unless you have the original log structure, your data (logs) that link to the actual fax images (fxds, fxrs, etc.) are lost.
Troubleshooting WinFax suggestion:
Jan 02, 2009 | Symantec WinFax Pro for PC
I can't send to certain fax machines with WinFax Pro
Yes, some modems might have problems with Service Pack 3. You might need to update the Windows modem drivers.
Alternatively, there might be problems with the settings in WinFax for your specific modem.
You'll need to post more information on the fax modem you are using.
http://www.getfaxing.com/forums
Jul 28, 2008 | Symantec WinFax Pro for PC
How to send a fax
Honestly there is no software that came with the scanner to give you option to scan to fax, here are some info's for the scanner and things that you can do with it, try this link
http://files.support.epson.com/htmldocs/pr125_/pr125_u1/index.htm
If you are using windows there is an application that you can use though the WINFAX application, but you will have to call microsoft to configure it for you.
Hope this help.
Apr 14, 2008 | Epson Perfection 1250 Flatbed Scanner
Program Setup in Winfax 10.03
I posted a probable solution for this under a user named Floopstick.
Check that out. But if you only need to fax once in a while Faxzero is free. You would need to scan in your data if you are not creating it on your machine. Tango.
Dec 15, 2007 | Symantec WinFax Pro for PC
Receiving Fax Line always 'busy'
Installing fax software can be tricky, particularly if you want to import phone-book listings from an existing database or PIM, such as Microsoft Outlook. But WinFax Pro proves easy to configure. A series of introductory screens walks you through installation; you just click Next to accept the default configuration. In our tests, WinFax Pro accurately detected our fax modem and seamlessly imported our contacts from Microsoft Outlook. By comparison, competing fax programs either don't import directly from Outlook or make the process trickier than it needs to be. you can try to look on website and there will explain to you. http://reviews.cnet.com/e-mail/winfax-pro-10-0/4505-3536_7-1536745.html
May 28, 2007 | Symantec WinFax Pro 10.0 for PC
How To Import Individual WinFAX files? .FXR and .FXD
Hi You can go to:: http://www.getafreelancer.com and post this request. I've seen it there before you wil need some third party app. Look for Project Number 138099 this will give you more info. Have a Great Day!!
Apr 12, 2007 | Symantec WinFax Pro for PC
Winfax pro problem
This is a solution that was suggested for an earlier edition of the Winfax Pro, but there is no reason why it shouldn?t work on this one as well: 1. Close Winfax and any other program that has anything to do with it, delete all the temp files that yo don?t need. 2. Run Scandisk and fix any problems that may come up. 3. Run delfix.exe which is located in the winfax folder in the status files. 4. Run delfix-rebuild and delfix-optimize and check if the problem is solved. If the problem reoccurs there is another possibility- to change the name of the WinFax\data folder and create a new one which you will transfer the address book file, status files etc. from the old folder. Note that there might be some information that wouldn?t go through.
Feb 22, 2006 | Symantec WinFax Pro for PC
Symantec WinFax Pro for PC Logo
26 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
