Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Opens some files, not all
I hav the Lacie for over a year now. It is giving me problems in opening some files. Others are OK. How can I restore those files. Do I need to defragment the lacie? Is that posible?
Thanks, Sophia
    Sergeant:
    Champion:
  • 317 Answers
Yes, it is. Try running a scandisk or other HD repair software you have on it.
Posted on Sep 28, 2008
Sandisk instructions
Which operating system ?
Encryption is a method of preventing unauthorized access to computer files.
When you apply encryption to a file, the file is altered so that it cannot be read by others, unless you have given them an encryption key.
Windows XP supports encryption through EFS, the Encrypting File System.
If you have encrypted a file on your Windows XP computer, but no longer want or need the file to be encrypted, you can remove file encryption by changing the file's properties in Windows Explorer. Locate the file from which you want to remove encryption in Windows Explorer.
Right-click on the file, then click the "Properties" link in the context-menu.
This opens a Properties window.
Click the "Advanced" button in the attributes section of the Properties window.
This opens the Advanced Attributes window.
Click to uncheck the box next to "Encrypt contents to secure data" in the Advanced Attributes window.
Click the "OK" button to close the Advanced Attributes window.
Click the "Apply" button in the Properties window, then click the "OK" button.
This closes the window and completes the encryption removal process.
Open Encrypted Files
Windows XP supports file encryption through EFS, the Encrypting File System.
You can encrypt files with EFS so that only you and designated users can open them.
You open files that you encrypted just as you would any other files.
However, you cannot open files that another user encrypted with EFS, and other users cannot open files that you encrypted, unless the user trying to open the file has been added to the list of authorized users for that file.
You can authorize users to open encrypted files using the Windows XP EFS management tools.
Click the "Start" button, then click the "My Computer" icon on the Start menu.
This opens the My Computer window. Navigate to the encrypted file for which you want add an authorized user.
Right click the encrypted file, then click the "Properties" link in the context menu. This opens the Properties window.
Click the "Advanced" button in the Properties window.
Click the "Details" button in the Advanced Attributes window.
This opens the Encryption Details window.
Click the "Add" button in the Encryption Details window.
This opens the "Select User" dialog box.
Click the user you want authorize to open the encrypted file, then click the "OK" button.
This closes the dialog box.
Click the "OK" buttons in the Encryption Details and Advanced Attributes windows to close them. Click the "Apply" button in the Properties window, then click the "OK" button to close the window and complete the process.
Apr 09, 2014 | SanDisk 64GB USB 2.0 FlashDrive Cruzer...
Tip
Unable to run executable files (. Exe) on windows platform
It may happen that only executable files aren’t eager open properly: either you have the dialog box "Open With", it opens with notepad or another program.
This problem may be due to a error made on your PC. If this is not the case, then it is necessarily a virus, follow this tip to disinfect your PC.
To correct the problem, follow these steps:
First Solution This solution is valid for XP and 2000 versions.
  • Go to Control Panel and then Folder Options.
  • Select the File Type tab and then click New
  • Type in EXE file extension and click OK
  • The EXE extension is automatically selected, then click Restore
  • Close the dialog box
Second solution This solution works for all versions of Windows
  • Click on Start> All Programs> Accessories> Notepad
  • Select the text below> copy and paste it into Notepad
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\exefile]
"EditFlags"=hex:d8,07,00,00
@="Application"
[HKEY_CLASSES_ROOT\exefile\shell]
[HKEY_CLASSES_ROOT\exefile\shell\open]
"EditFlags"=hex:00,00,00,00
[HKEY_CLASSES_ROOT\exefile\shell\open\command]
@="\"%1\" %*"
[HKEY_CLASSES_ROOT\exefile\shellex]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\{86F19A00-42A0-1069-A2E9-08002B30¬309D}]
[HKEY_CLASSES_ROOT\exefile\DefaultIcon]
@="%1"
  • Then click on File> Save As ...
  • Select All files Type
  • Give a name for the file and add the. Reg
  • Click on Save
  • Close the notebook and then right-click the file. REG> Merge
  • Click YES and OK
on Jun 15, 2010 | Computers & Internet
Restore files
You can have the data removed by a file recovery business, it is costly. They remove the stoarge media and read it directly using special equipment. Unless the hard drive works (you can read it with your computer) that is your only choice
Dec 12, 2011 | LaCie Computers & Internet
My Lacie is actually empty, when I open it there's nothing there, but when I try to drag any folders into it it says that it's full. And also in "Get info" box it says its 0kb free space, how do...
Go into Disc Utility and use the partition option, change CURRENT, to 1. Also check the options box towards the bottom, they have 3 options depending on how you plan to use the drive. Let me know what happens.
Mar 18, 2011 | LaCie Computers & Internet
Won't delete back up files cannot format to full 500 gb
Hello, pmanso, instead of "deleting the files," open the "Disk Management."
  • Click on the "Start" button.
  • Next, {Alt / Right} click on the Computer 'shortcut' select "Manage."
  • In the next 'window that opens, 'open the "Disk Management" in the [Left area] of the 'window.' paul7of9_98.jpg
  • Now, look 'under' the "Volume" tab, paul7of9_99.jpg and find the 'External' [HDD] 'letter' ie: (F:).
  • Next, click on the "Volume" to open, and select to "Delete Volume..."
!Attention: If you are "still" having a 'problem deleting the {Data).
  • Try "Formatting" the Volume.
  • Now, if this isn't working out to 'well,' open the "Properties" from the 'same' location.
  • All {areas} are accessible, by "alt / right click on "Volumes."
  • Restart the Computer when finished!
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 18, 2011 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I have a Lacie wireless space network drive (1TB) connected directly to my router. I'm only using the switch functionality and have my pc connected to the internet through one of the 3 ports on the...
Here is what LaCie suggests about this issue:- first backup any data you have copied on Wireless Space. You can also backup your configuration: from "configuration" tab of "Support" widget, click "save" button next to "Configuration file", it will download a backup file.
- still in "configuration" tab of "Support" widget, tick the third box labeled "Restore device to factory state (data erased)", or any equivalent quote in selected language, and click apply
- the device will reboot, rebuild hard drive image, then reboot on default state. The issue is definitively fixed
- it is recommended to apply latest update downloaded from LaCie website
- you can restore previous configuration in "configuration" tab of "Support" widget, click restore and select previously downloaded backup file
Feb 07, 2011 | LaCie Wireless Space 2TB Wireless Storage...
Myob optimisation gives error in database 3000 5049 even on file that opens ok
MYOB suggestions
It appears that you have a corruption in the data file. This can only be corrected by the technical support team at MYOB. You will need to give them a call. At this time of year you could be on hold for quite some time. From memory a repair of a file is an additional cost to your MYOB subscription.
Another alternative would be to restore a previous backup and ensure that the backup does not have the same error and reenter the missing data.
Jul 18, 2010 | Computers & Internet
No pc manages to read the Lacie external hard drive, I receive a non-formatted message (whereas it contains data). Any ideas?
May be file system got corrupted.
Ok
Try to open it via disk management and see.
You can try to restore your data on it..
there are software like get data back for FAT and NTFS..
I may help you to get these if you need it
Thanks
Uttam
Jun 24, 2010 | LaCie (301144) 120 GB USB 2.0 Hard Drive
Windows vista wont load
Hi I believe that wouldn't be a problem. If you want to do a system recovery, the laptop usually comes with a back up partition where all the files to do system recovery is stored. You can use these files to restore the setting back to the point when you first purchased the item.
REMEMBER: All your datas will be erased when you do the System Recovery.
For me guide you on have to access the files, I need the make and model of your laptop.
NOTE: If the RECOVERY or FACTORY_IMAGE partitions on the hard drive have been deleted OR the files in these partitions have been deleted, these steps will not work. You must use recovery discs.
  1. Turn off the computer.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. Turn on the computer and immediately press the F11 key repeatedly , about once every second, until Recovery Manager opens.
  4. Click Next .
    A Microsoft System Restore screen opens.
  5. Select No, I would like to see other options , and then click Next .
    A System recovery screen opens.
  6. Click Yes , and Next to continue the recovery process.
    The Recovery Manager gives you the option of backing up your data files. To do so, read Backing up your files .
  7. To continue recovery, select No , and then click Next .
    A recovery progress screen opens. Wait while files are restored.
  8. When System Recovery is complete, click Finish
  9. The computer restarts and continues into Windows setup.
  10. Complete the setup screens and wait until the computer finishes the setup.
  11. Turn off the computer, reconnect all peripheral devices, and turn on the computer.
  12. Before using the computer, update and protect it by reinstalling any virus and security software that was installed before the System Recovery.
  13. Reinstall any software applications that were added after purchasing the computer, and replace any files that were backed up.
Please rate this solution.
Jan 14, 2009 | Computers & Internet
Locked Folders
One week ago my LaCie external disk has been locked during a system reinstallation process in which the hard drive was plugged in.  The message was that I had no permission to access it. I thought I would loose for ever all the files I have been backed up for years. But finally I have got the solution for that. There is a sofware called MacPilot (I used version 3.2.6, $20, 15-day trial) that fixes it. Once instaled, click TOOLS, then "Files&Folders" at left, then "Unlock File or Folder", press "Choose", it opens FINDER and then you click LacCie Disk. When the padlock symbol at the botton of LACie disapears, you can finally change the permissions to "read&Record". That's all, and I hope it helps.
I recommend that you always unplug external hard drivers during system reinstallation to prevent that.
Feb 22, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
110 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
