Question about GE 3.2 cu. ft. Washer
Machine isn;t getting power.
My washer stopped and is full of water. The machine ins't getting power. Do washers have fuses ?
  • 1 more comment
  • 3monkeys51 May 20, 2008
    Are you kidding me??? This appears to be a canned response .
    For the money it cost i was hoping for a direction on what to look for .
    My apologies i did not see the solution # 2 and 3 . The breaker did not trip and the outlet is getting power . Do these machines have fuses ?? When it comes to electric my knowledge is limited .
    Thanks.
    The washer is 8 years old and has never given us a problem. I will check the switch. Thanks for your help.
    Genius:
  • 2,035 Answers
IF it machine is within one year the company will repair the washer for you oe get it check by service center ......
or you may contact
GE Appliances Website ge.com
Have a question or need assistance with your appliance? Try the GE Appliances Website 24 hours a day,
any day of the year! For greater convenience and faster service, you can now download Owner’s Manuals,
order parts or even schedule service on-line.
Schedule Service ge.com
Expert GE repair service is only one step away from your door.
Get on-line and schedule your service at
your convenience 24 hours any day of the year! Or call 800.GE.CARES (800.432.2737) during normal business
hours.
Real Life Design Studio ge.com
GE supports the Universal Design concept—products, services and environments that can be used by
people of all ages, sizes and capabilities. We recognize the need to design for a wide range of physical and
mental abilities and impairments. For details of GE’s Universal Design applications, including kitchen design ideas
for people with disabilities, check out our Website today. For the hearing impaired, please call 800.TDD.GEAC
(800.833.4322).
Extended Warranties ge.com
Purchase a GE extended warranty and learn about special discounts that are available while your warranty
is still in effect. You can purchase it on-line anytime, or call 800.626.2224 during normal business hours.
GE Consumer Home Services will still be there after your warranty expires.
Parts and Accessories ge.com
Individuals qualified to service their own appliances can have parts or accessories sent directly to their homes
(VISA, MasterCard and Discover cards are accepted). Order on-line today, 24 hours every day or by phone
at 800.626.2002 during normal business hours.
Instructions contained in this manual cover procedures to be performed by any user. Other servicing
generally should be referred to qualified service personnel. Caution must be exercised, since improper
servicing may cause unsafe operation.
Contact Us ge.com
If you are not satisfied with the service you receive from GE, contact us on our Website with all the details
including your phone number, or write to: General Manager, Customer Relations
GE Appliances, Appliance
good luck...................
Posted on May 20, 2008
  • 3,037 Answers
The circuit breaker wasn't tripped, correct? The board is the only thing that would cause everything to stop working otherwise. First check power in the outlet and then check for power in the rest of the machine and let me know if anything else is still working so that we can narrow down this problem. Please post here with an update.
good luck
  • Benjamin Patri
    Benjamin Patri May 20, 2008
    The lid switch may be defective and if it is, then it may cause the machine to not operate at all. Only a few washing machines even have a fuse which would be near the lid switch and inside the control panel. Please first make sure there is power in the outlet by plugging something else in before trying to fix the machine.If you press the button to start it and it doesn't run, then the control board may also need to be replaced if the switch is ok.
    If you press the buttons and it sounds like it is trying to go, then there is a problem with a different part of the machine but most likely the board is fried or the switch broke.
  • Benjamin Patri
    alright, sounds good, please keep me updated with this
    Sergeant:
  • 406 Answers
Its main logic circuit needs to be dried in sun and fix it again. Else check the motor or replace the main printed board assembly with new one.
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Washer filled with water then stopped working, still full of water. Drier works just fine. Happened durring an electrical short in my house, but the fuse that was blown was not linked to the same part of...
You state you had a short in the home. Since the washer is on 110V system, you can try a different outlet and see if the machine works. Although you state that it isn't on the same part of the panel as the washer/dryer, and the dryer works, the dryer is on a different breaker, and it may indeed have had some effect on the panel that hooks to the washer. Try my first option, and let me know how you make out. I believe you'll find that to be the trouble
Joe
Sep 07, 2011 | Frigidaire FEX831CS Top Load Stacked...
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
I have a series 90 washer and it just stopped and is full of water. It will not power up. where should I start?
must be overload trip. drain water first. reduce load. restart. if doesn't work, check CB or fuse inside the machine
Mar 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washer stopped in the middle- and wont turn back on- full of water right before the spin cycle! I have checked the breaker, unplugged it, pulled the knob and tried to recycle it- NOTHING! it is only 7...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer full of clothes and water and stopped- how to reset?
According to my experince let the machine stop and complete shut power and try after 10 minutes
Oct 03, 2009 | Maytag PAV2300 Top Load Washer
I started working with the Karcher KB4040 pressure washer and all was well for 1-2mins, then it sputered a bit and all power died. All hoses were still attached properly, it hadn't blown a fuse in my house...
if the water is in anyway impeded, like kink in hose the unit turns off and goes into protection mode. That it it shuts down for a pewriod of time depending on how hot it may have got.
When its rested try it again ensuring you definitely have water flow.If the solenoid has failed it costs about !60-200 to fix as they replace all seals regardless
Jul 22, 2009 | Karcher 1750 psi Electric Pressure Washer
Hotpoint , no power, full of water
Turn off the water supply to the machine
Take the drain hose off the back of the machine and drop it into a bucket , you will need to do this several times.(Take off any clips that stop it from being laid flat on the floor)
Once all of the water is out of the machine try powering it up again, if it lights up do a spin to get the clothes dry , leaving the outlet hose in the bucket.
If that works then once the machine is dry try turning on the water supply with the machine turned off , if water runs into the machine then you have a faulty fill valve.
If that is ok then check the pressure switch and Air Bell which sits on the back of the main drum you could have a soap ball in the Air Bell which will false out the machine and cause overfilling
If there is no power check the mains supply to the wall outlet then the plug top wiring and any fuse fitted inside the plug top
After that it is down to a man with a test meter
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer machine cylce stopped in mid cycle
  • No power
  • Lid switch
No power
Lid switch
 check these, if still the problem persists then let me know for further help.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
GE 3.2 cu. ft. Washer Logo
278 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
